Old 09-27-2010, 02:41 PM   #1
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
Default 2011 WRX headlight Bulbs
Hey guys,
I have a 2011 wrx hatch and I bought some headlight (low beam) blue colored bulbs for it. I installed one and i get a really bad smell, like melting wires. It's the same H11 55W 12V as the stock one is except for the bulb is blue rated at 4300k.
With the temp gun..after 30 seconds of being on for each
Stock Bulb Blue bulb
Outside of Headlight 110F 150F
Connector of bulb 105 107
Wires 108 108
Inside projector housing 107 110
so based on that, the temps seem good especially at the wires, connectors and inside the housing...so what the hell am i smelling....and its smells very strong...even after 30 secs with the blue bulbs. Like i said, the new blue bulbs are just regular H11 bulbs not xenon or hid or anything of the nature. I used this company before on many other cars and never had this issue.
subiebosch is offline   Reply With Quote
Old 09-27-2010, 11:23 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Get rid of those crappy blue-coated bulbs before they overheat and damage your wiring and lights. Even though they are rated at the same wattage they will run hotter.
Read this-
http://www.danielsternlighting.com/t...blue/blue.html
Old 09-28-2010, 08:03 AM   #3
subiebosch
Member#: 155548
2015 2500 Dmax
thanks. I took those out immediately anyway....never ran with them.
Old 10-01-2010, 09:17 AM   #4
2K11WRXKnightRider
Member#: 258472
I just got my '11 WRX and just to clarify the low beam headlight bulb is an H11?
2K11WRXKnightRider is offline   Reply With Quote
Old 10-01-2010, 01:17 PM   #5
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
It is an H11. H9 bulbs can be modified to fit and at 10 watts more than the H11 they pose very little danger of overheating the assemblies and melting wires. I've done this for my Mom's '09 2.5i Impreza using regular stock(not blue) H9s with great results so far-no burning smell and no charred wires after 8 months. Again-I did not use blue coated or higher wattage H9s and would not reccomend doing so. I'm speaking from my own experience-if you try this you do so at your own risk.
Old 10-01-2010, 03:02 PM   #6
2K11WRXKnightRider
Member#: 258472
Thanks! I just ordered my HID's and was hoping that I was right cause I already paid for them and told them I wanted an H11. Thats a load off my mind now, now if I can only be patient enough to wait for them to get here!! I feel like a feind! I have soo many things I wanna buy for this car
Old 10-02-2010, 06:13 AM   #7
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
And now I suggest canceling that order. HIDs cannot be run safely/correctly in your stock headlights. If you want to run HIDs your ONLY options are a complete retrofit, STI headlights, or WRX Premium headlights.
Byzantium is offline   Reply With Quote
Old 10-02-2010, 11:44 AM   #8
subiebosch
Member#: 155548
2015 2500 Dmax
yeah HID will run worse then regular according to my research as well. Not to mention the higher temps.
Old 10-02-2010, 12:34 PM   #9
iKickUrLunch
Member#: 253715
2010 WRX
Spark Silver Metallic
Read the daniel stern site. It tells you why it is bad putting in HID bulbs into non-HID projectors. There are also recommended halogen bulbs on his site. There are some good H11 halogens out there like the Osram Nightbreakers. I have those and they are much better than stock.
iKickUrLunch is offline   Reply With Quote
Old 10-02-2010, 02:42 PM   #10
PleiadesSTi
Member#: 194132
2009 WRX Sedan
SSM
HID's are fine in the stock projectors. Do the "squirrel finder" modification and be done with it.
PleiadesSTi is offline   Reply With Quote
Old 10-02-2010, 03:06 PM   #11
2K11WRXKnightRider
Member#: 258472
What's that and do u have a link to what to do? Thanks in advance! I'm pisses about this. Can someone post a link to the article as to why u can't.
Old 10-02-2010, 03:47 PM   #12
PleiadesSTi
Member#: 194132
2009 WRX Sedan
SSM
Granted the stock projectors are made for halogen lights, you "can" get away with HID's in a halogen projector. It's not the best light output and spread. You do get glare and hotspots, but it's not as bad as everyone says it is imo. There is a thread about the squirrel finder mod on here you'll have to search for it. Good luck.
Old 09-29-2011, 10:15 PM   #13
jege41
Member#: 280754
Hi
Is the low beam H11 also running the Day Time or is that off the high beam 9005?
THX
jege41 is offline   Reply With Quote
02-03 WRX headlight bulb replacement rukkie Electrical & Lighting 8 04-19-2011 12:52 PM
05 wrx headlight bulbs v8eaterWRX SWIC Private Classifieds 4 02-14-2007 12:49 PM
05 WRX headlight bulbs DeKaP Newbies & FAQs 4 09-28-2005 08:45 PM
WRX Headlight Bulbs Flexx999 Canada Region Forum 8 04-12-2004 01:40 PM
WRX headlight bulb ? H8YNERS North West Impreza Club Forum -- NWIC 4 05-23-2002 01:31 AM
