Old 09-27-2010, 07:15 PM   #1
sureshot007
Member#: 142405
#716 G2 OBS
Default Physical ECU Burn???
I have a 98 Forester, and after some troubleshooting, I have discovered that the ECU has some damage to it internally - specifically the diode at D602 has a crack around the center, and the trace on the board leading too it has flaked up and cracked. So my question is does anyone know that system is related to this diode, or maybe help me figure out what pin it leads to? I'm pretty sure there is a short somewhere on the chassis that caused this, but it would be nice to figure it out before burning another ECU.
sureshot007 is offline   Reply With Quote
Old 09-29-2010, 01:05 PM   #2
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I'm not really sure about anything you just said, but have you checked the factory service manual? You can try tracking it to a pin as well...
Usually, there are safety measures to prevent shorting damaging the ECU, and this usually means that the ECU was shorted/damaged relatively near the ECU.
Water getting in the ECU is a definite possibility. Any bad storms, offroading, puddle-swimming?
formula91 is offline   Reply With Quote
Old 09-29-2010, 01:09 PM   #3
sureshot007
Member#: 142405
#716 G2 OBS
Using a voltmeter, I was able to trace the circuit on the board back to the pin that corresponds to the neutral switch, in case anyone else is every curious.
Fried my ECU today and burned up my motor. 06STi General Community 0 10-10-2006 11:18 PM
Attn: Physics guru wannabes. Physics question ahoy! Argh, matey! Asinine Off-Topic 53 12-28-2005 11:11 PM
Lean burn on oem ECU - use PIC to offset O2 sensor? ahains Engine Management & Tuning 23 09-13-2005 01:18 PM
SRT4 forums physics lesson..."HOTTER AIR BURNS TEH BETTAR!!" RaceCarRiot Off-Topic 17 01-27-2004 06:27 PM
Chip burning/ECU tuner DonkeyPunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-26-2002 07:27 PM
