Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 09-27-2010, 09:24 PM   #1
meo
Member#: 206936
Default Tips on fixing manifold broken mound
the friggen mount just broke off when i was putting it on my block. now hoping for some suggestions on how to fix this
meo is online now   Reply With Quote
Old 09-27-2010, 10:08 PM   #2
Deathclutch
Member#: 232012
ouch casting... i hate trying to weld cast! sometimes i have good results... most of the time not! hopefully someone can give you better information than i!
Deathclutch is offline   Reply With Quote
Old 09-27-2010, 11:23 PM   #3
FlannelWagon
Member#: 209998
2007 Fxt
Urban Grey Metallic
you will have to have it welded, and then taked to a machine shop. and have BOTH sides Milled flat to the same specs.
FlannelWagon is offline   Reply With Quote
Old 09-28-2010, 01:31 AM   #4
wrxsubaru
Member#: 65133
JB weld. save some money buy some beer and let it set up. Or like some others have said you could try get some one to weld it and machine it to even out the surface.
wrxsubaru is offline   Reply With Quote
Old 09-28-2010, 12:11 PM   #5
Darcros
Member#: 196496
2006 STI
preheat and tig weld it. should be no prob iv done a few sti ones in the past. its a clean cast.
Darcros is offline   Reply With Quote
Old 09-28-2010, 11:58 PM   #6
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Yeah the intake casts are pretty darn clean, with so much surface area in the crack JB wouldnt be a bad fix really, then u could clean it up pretty well.
Token-Negro is offline   Reply With Quote
Old 09-29-2010, 12:17 AM   #7
meo
Member#: 206936
thanks guys
Old 09-30-2010, 11:11 AM   #8
eg33GC
Member#: 206851
56 Belair
Pro Street
preheat, take a stick Ni rod and break the coating out of it, and tig it shut.
eg33GC is offline   Reply With Quote
FS : ...... meo Engine/Power/Exhaust 0 09-27-2010 03:36 PM
Tips on fixing cars on your own rcdrivercrl Vancouver Impreza Club Forum -- VIC 4 03-04-2008 05:26 PM
broken plastic tip on Perrin modded injectors: can it be replaced? Mojambo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-05-2008 08:45 AM
Question on torque spec on exhaust manifold gopsu Newbies & FAQs 7 05-20-2006 07:30 PM
Need tips/info/help on fixing dents and sanding/painting hood Evil-Mastermind Southern California Impreza Club Forum -- SCIC 5 05-02-2002 10:39 PM
