Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 06-25-2002, 06:10 PM   #1
slowme
Member#: 12235
2006 WRX Limited
Red
Default How hard is it...
How hard is it to install an anti-lift kit and what is the best way t go about the install on a GC8? Also do I need to allign the front end after I install it?
Bill
Re-Alignment is a MUST!! After installing the ALK, the toe angle changed to Toe-in...not good!!
slowme is offline   Reply With Quote
Old 06-25-2002, 06:14 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
I have never done one, but I hear its easy to do on a GC8
sorry that probably doest help much
jay
Old 06-25-2002, 06:24 PM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
It's a PITA on the WRX, but it's not as difficult on the GC8 becasue there's less to remove. The Hardest part is getting the control arm bolts loose. It's a straight forward install, but some of the bolts are a pain to get loose.
Old 06-25-2002, 07:36 PM   #4
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
It was pretty easy. As mav1c said there are a couple of bolts that are really torqued on there but a breaker bar or your foot (if you're just on jack stands) helps a lot. Just make sure you get lots of grease on the bushings when you install them. Pulling the control arm down was kinda tough but I was able to do it by myself. I had to remove the OEM "skidplate" bolts to get the clearance to remove the OEM part.
Depending on where you live you might want to look into the ALK with the "comfort bushing". A bunch of us had some complaints about how harsh the ride can be on sharp edged bumps (which there seemed to be a lot of in San Francisco and Michigan). So Whiteline produced a new bushing expecially for us that had a softer durometer than the regular kit. I installed the softer one (after having the regular one for 6 months) and loved it. OEM comfort levels but with most of the ALK handling improvements.
If you want more detailed info on the kit there was a HUGE thread on the ALK. Just search for Anti Lift Kit. I think I started that thread.
Oh, the best info is in the Modification section up at the top there. There are step by step install instructions for the ALK with pictures.
You should have the car realigned after the install.
Arnie is offline   Reply With Quote
How hard is it to install an SPT Short Throw Shifter? joserpm Transmission (AT/MT) & Driveline 5 06-20-2007 11:50 AM
How hard is it to install a rotated turbo kit? anthongy817 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 10-05-2006 12:02 AM
How hard is it to install an AVCR in an sti? STI1981 Electrical & Lighting 1 09-01-2006 06:49 PM
How hard is it to install, use and tune an S-AFC? BrysImpreza New England Impreza Club Forum -- NESIC 2 07-13-2002 08:08 PM
How hard is it to install an EBC and power meter? PrinceWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-23-2001 09:32 AM
