Old 08-10-2008, 04:47 PM   #1
guciodog11
Member#: 160264
95 20G'd EJ255 GC8
Default Is there any mod that enables windows to be rolled up without needing the key?
i was just wondering if there was any way to do this. on my friend's is300, his driver's side window is capable of being rolled up without having to turn the key to acc. is there some kind of a window motor relay that i can run a wire to from the battery?
THANKS!
guciodog11 is offline   Reply With Quote
Old 08-10-2008, 07:25 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Your friend's car has a body controller and retained accessory power that allows for accessory use with the key inserted but not turned on, or for a set period after the car is turned off. Your car does not have this, and it can't really be added after the fact with factory-like functionality. It might be possible to kluge something up with relays and additional circuitry but not worth it IMO.
Old 08-10-2008, 10:20 PM   #3
guciodog11
Member#: 160264
95 20G'd EJ255 GC8
so any attempt at trying this will be a lot of work? i was just thinking that there might be a procedure like the foglight mod where you could bend a pin on the relay and connect it to 12v. o well there goes that idea...
Thanks for the help!
Old 08-10-2008, 11:12 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
You should be able to do that pretty easy. Find a fuse that is hot all the time under the dash. Then run a switched wire from there to the window fuse lead. This will tie power to the windows but also backfeed power to any other circuits tied to that point so you need to watch out and see what is connect there also at that point.
Cougar4 is offline   Reply With Quote
Old 08-10-2008, 11:35 PM   #5
guciodog11
Member#: 160264
95 20G'd EJ255 GC8
you mean like one of those make-a-circuit thingies as in the foglight mod? what if i ran that cable to the battery?
Old 08-11-2008, 12:48 AM   #6
Cougar4
Member#: 53443
Winestone
If I was doing this I would use a couple fuse taps and a switch. Nothing to really install except the switch to cross the circuit over. Just thinking here, by using a single pole-double throw switch and some in line fuse holders you could make a setup so power wouldn't backfeed to other circuits.
Old 08-11-2008, 01:05 AM   #7
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Instead of that switch I believe he can use a diode.
The real trick is going to be making this work for the windows going up only, as probably they way the switches work is completing the circuit in the right direction, so you'll probably be able to put the windows up too.
Be sure to put a timer on this too... It would suck you for if a car thief came, flexed your frameless window out, then put your window down for absolutely silent entry.
Abnormal is offline   Reply With Quote
Old 08-11-2008, 01:26 AM   #8
Cougar4
Member#: 53443
Winestone
The purpose of the switch I was thinking about was to isolate other circuits on the same power buss as the window circuit. The windows would work normally as they do now.
Old 08-11-2008, 07:14 PM   #9
guciodog11
Member#: 160264
95 20G'd EJ255 GC8
you're right about how easy it would be to break into the car.....
today i went to pick up some beer for my moms restaurant, and locked my keys in the car while i took the cab to my house, one of the guys opened it via the front drivers door, but now i think the internal mechanism is messed up. the window makes grinding noises like a bar was scraping up against it, and the lock won't work. now im gonna have to rip apart the whole door and see what happened.....from now on im hiding a spare key in my wheel well.
well there goes that idea.....it would be just too easy to break in.
Old 08-11-2008, 07:50 PM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There is a big difference between a true retained power system and just rewiring the windows to work with the key off all the time. That is why I said it isn't practical to duplicate what your friend has in his Lexus. His windows won't work any more once the set amount of time has passed or the car is locked, that is done by the built-in logic in the car's electronics.
Old 06-30-2009, 11:23 PM   #11
JoKerNZ
Member#: 140342
1998 Legacy GTB JDM
Yes (JDM) insert a jumper in relay under dash and thats it...
unscrew panel near knees, unplug the 12v relay and insert the red wire in pic (needs spade terminals)
done = always on windows
now can someone point me to the windows "upper limit" reset procedure thread?
JoKerNZ is offline   Reply With Quote
Old 07-01-2009, 02:52 AM   #12
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Does this mean they work on the first "click" of the ignition switch? Or always (no key in car)?
-noobile
Old 07-01-2009, 03:00 AM   #13
Cougar4
Member#: 53443
Winestone
Anytime.
Old 07-01-2009, 10:15 AM   #14
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
This is a bad idea for two reasons-
1. Safety- If there are kids around they will be able to operate the windows and possibly get hurt or worse. Pretty sure that here in the US it's a DOT requirement that the windows not be functional all the time, for this reason.
2. Security- With the car locked entry could be easily gained by poking a rod past through the frameless window and hitting the window switch on any door. Of course this is in addition to the already vulnerable power locks which are always active.
And also note that you are replying to a thread that's almost a year old.
Old 07-06-2009, 01:07 AM   #15
JoKerNZ
Member#: 140342
1998 Legacy GTB JDM
know its bad - but OP asked and without a relay it's the easiest way - it was listed in a workshop manual of some kind...
suppose ther is no reason why you couldn't put a relay in with the ACC switch... (duh make use of existing relay and wire it to ACC not ON)
Old 04-07-2010, 01:26 PM   #16
biebs96
Member#: 238035
Is this under the dash on an 06 2.5i??
I'm interest for my gf's car!
biebs96 is offline   Reply With Quote
Old 04-07-2010, 03:09 PM   #17
Xawn
Member#: 214441
2012 STi
Xawn is offline   Reply With Quote
Old 04-07-2010, 03:29 PM   #18
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
you could replace the regular relay with a relay with a delayed shutoff and it would keep power to the windows for however long the relay is set to. DONE.
ProdriveDreams is offline   Reply With Quote
Old 04-07-2010, 03:41 PM   #19
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
http://www.headsetzone.com/tdr-1.html
these do dads aren't too cheap but if you shop around you can find a decent price.
What you want is a delay-off timer with a coil voltage rated at 12VDC
Also if you re routed power to the delay relay with a diode and wire hooked to ACC power, windows would work when the key is in ACC or ON, and would continue to work for the preset amount of time after you turn the key to OFF
Old 04-07-2010, 03:45 PM   #20
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
Alternatively it would be slightly more complicated to do the american style thing where you could install a circuit known as a latched relay. Basically what happens is once power is applied to the relay it stays in the "on" position until you trigger it to go off, even if supply voltage is cut to the relay it will stay on till it is triggered. You could then tie the trigger into the door ajar light so that you could have it switch off upon the door opening. a little less simple, but still fairly easy. like 20 bucks at radioshack and an afternoon under the dash
Old 04-08-2010, 01:26 AM   #21
rkramer
Member#: 118209
2015 WRX Limitec
**deleted**
rkramer is offline   Reply With Quote
Old 06-04-2010, 06:52 PM   #22
Shimmer
Member#: 247939
2006 STI
Has anybody done this with their 02-07 WRX? The picture from above seems to be from an older model as I can't find that relay anywhere underneath the steering column or inside the driver's side door.
Shimmer is offline   Reply With Quote
Old 09-22-2010, 02:20 PM   #23
Shimmer
Member#: 247939
2006 STI
I've finally had some time to have another look at this and figured out how to have power to the windows without the key in the ignition.
Remove the panel under the steering colum. This is the relay that you'll need to remove.
Make a short jumper to replace the relay these pins on the relay.
Replace the jumper to cover two of the pins from the relay.
A problem I've noticed with this is that the lights on the window switches remain on. I don't think that this should be a huge problem as the current drawn is quite low.
Old 09-22-2010, 03:46 PM   #24
Cougar4
Member#: 53443
Winestone
Even if the extra current draw is only 100 milliamps it will make a significant drain on the battery. Not a good thing in my opinion.
Old 09-22-2010, 05:08 PM   #25
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not to mention that you've just made the car a LOT easier to break into.
Are there any programs that enable you to download hotmail? Tainted Off-Topic 22 02-05-2008 11:16 PM
Is there any place that sells the S203 Recaro seats to fit a 2005 STi? flicky30 Interior & Exterior Modification 15 03-11-2005 05:37 PM
Is there any car that is easier to work on than a Miata? zoomfactor Off-Topic 28 04-16-2003 05:08 PM
is there any turbo that will work with the hks d/p? 2002whitewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-04-2003 05:35 PM
