Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 02-04-2011, 02:03 PM   #1
OneManArmy
Member#: 36154
2004 WRX Wagon
Default ej255/ej205 hybrid?
I'm finding a ton of info bad/good/mixed on ej257 but very little on 255.
I spun a rod bearing and I'm trying g to decide what to do. I'm leaning toward using as much of my ej205 (04 wrx) as possible. I really want to run a built ej255 block but I keep reading all these hybrid issues and its got me rethinking just stroking my 2.0.
This will be a daily driver with reliability first priority and torque second.
Any info would be helpful. I am Good on using custom pistons but want to use a regular head gasket and I'm not sure about the head reworking.
Info please!!!
OneManArmy is offline   Reply With Quote
Old 02-04-2011, 02:06 PM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
pretty much the same thing as using the 257
if using older 255, then same thing
using newer 255, if using the stock 255 pistons, cr will be lower.
if using custom pistons, both 255/257 are going to be the EXACT same.
Nuke209 is offline   Reply With Quote
Old 02-04-2011, 02:14 PM   #3
OneManArmy
Member#: 36154
2004 WRX Wagon
Probably going to use a piston ment for hybrid use but all thus chamber porting talk has me confused. So many people live and due by it and some are against it. If its so great why isn't everyone doing it and why can't I find more data on it?
Old 02-04-2011, 03:11 PM   #4
Ryan314
Member#: 82989
Hybrid EJ257
JE makes a "hybrid" specific piston to lower CR if you are not planning on opening up the CC on the EJ205 heads. People have had success doing this but you still have head overhang and the possibility of hot spots leaving the heads unmatched. The safer more reliable bet is to get the heads opened up and get stock CR pistons.
Ryan314 is offline   Reply With Quote
Old 02-04-2011, 08:34 PM   #5
RexWagonWA
Member#: 221945
Default CNC Hybrid Heads
From your location, a field trip to EQ Tuning in Fairfield may be in order. I have some of their heads on my hybrid engine from Maxwell Power Services. It is a much cleaner combustion chambers. They have worked well to give a wide range of power. My tune is conservative. I probably will do E85 in the future.
Good luck on your build.
RexWagonWA is offline   Reply With Quote
FS : Ej255 Ej205 hybrid swap HiCompwagon Engine/Power/Exhaust 3 08-25-2010 11:16 PM
FS : Ej255 Ej205 hybrid swap HiCompwagon MAIC Private Classifieds 1 07-31-2010 04:23 PM
Timing Belt for Ej255/205 hybrid Loomin Built Motor Discussion 3 07-13-2010 01:43 PM
FS Mass 20G Turbo FMIC ej255 ej205 engine motor lots for sale here 02WRX1989 Engine/Power/Exhaust 78 07-17-2009 08:34 AM
Any WI ej205 hybrids? stevepius Mid West Subaru Owners Club Forum -- MWSOC 4 06-09-2005 12:20 PM
