Old 09-28-2010, 01:40 PM   #1
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Default Should I port and polish heads.. Is it worth it
So I am doing BC 280 cams and valve train.
I am wondering if porting would be worth the cost! please let me know.
renosubby is offline   Reply With Quote
Old 09-28-2010, 02:00 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
At what HP/$ ratio is worth it to you?
Old 09-28-2010, 02:12 PM   #3
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
if im going to gain 15-20 whp then yes it's worth the price.. but if its 5whp no way
Old 09-28-2010, 02:26 PM   #4
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Off topic
What are you going to do to keep the HGs in place? ARP Studs, o-ring the block?
I would say that porting and polishing the heads is worth it with a nice set of cams, how much will you gain? no one knows
Old 09-28-2010, 02:30 PM   #5
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Originally Posted by juanmedina View Post
Off topic
arp studs
Old 09-28-2010, 04:39 PM   #6
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Need more info. What turbo? How much boost? What fuel? HP target?
alcoolaid is offline   Reply With Quote
Old 09-28-2010, 04:43 PM   #7
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Fp red, forged internals, and all supporting mods
500 on c16. now at 465 on 110
on pump i make about 395 i was hoping for 415 on pump
24 psi pump
29-30 race
Old 09-28-2010, 08:57 PM   #8
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
I assume that you are going to run bigger sized valves, the best bang for the buck port you can do to your heads in blending the bowls its cheap and thats where your are going to get most of your power.
ASU is offline   Reply With Quote
Old 09-28-2010, 09:35 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
from someone who ports heads and has spent lots of time on the flowbench, I completely agree. Massaging the neck/bowl only will save time and money and give a nice gain. Unless you are going for an insane goal or record, don't sweat a full port job.
Old 09-28-2010, 09:47 PM   #10
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Crystal Grey Mettalic
i say just get the mahcine shop to show your heads a little love nothing too crazy...after all the way to make more power is to flow more air and add more fuel
Daniel's05WRX is offline   Reply With Quote
Old 09-28-2010, 09:57 PM   #11
ASU
Member#: 164551
2006 Brotastic STi
I had a Head melt down, they where fully ported actually crazy ass porting. Now I have a new set of heads that where cut for valves and just blended bowls. So it goes on the Dyno on Weds so Ill report on the HP loss which I will see some loss but I dont think anything big. Setup exactly the same except for heads.
Old 09-29-2010, 04:52 AM   #12
apalos
Member#: 191761
It definitely worths porting and polishing.Depending on how much boost
you plan to use ,you ll see proportional gains.
apalos is offline   Reply With Quote
Old 10-19-2010, 11:37 AM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
any update on this???
FuJi K is offline   Reply With Quote
Old 10-19-2010, 12:18 PM   #14
ASU
Member#: 164551
2006 Brotastic STi
About a 10 whp loss nothing big.
Old 10-19-2010, 12:43 PM   #15
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
how was the power curve?
Old 10-19-2010, 05:37 PM   #16
hobbesnapoli
Member#: 221436
02 WRX vf39
10whp sounds pretty low for something making 562whp -- Even with most of the gains being in the bowls / valve upsize. 2% power gain =(
hobbesnapoli is offline   Reply With Quote
Old 12-01-2010, 03:11 AM   #17
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
ASU what turbo was that on and what cams?
10HP at $1000 of Labor doesnt sound good to me!
Bariga is offline   Reply With Quote
Old 12-01-2010, 10:53 AM   #18
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I dont just look at PEAK power when a port job is done... I also look at power curve.
Old 12-01-2010, 10:55 AM   #19
Homemade WRX
Member#: 33782
96 bastard child
^^^truth. I also look at the trend of the torque curve.
Old 12-01-2010, 01:02 PM   #20
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
im thinking ASU had small cams,
Old 12-01-2010, 03:01 PM   #21
xmel012
Member#: 265661
sorry.can you explain me about porting??? what is it??
xmel012 is offline   Reply With Quote
Old 12-01-2010, 03:03 PM   #22
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
porting is when you port your exhaust tip for more flow, make it a potato shooter
Old 12-01-2010, 03:45 PM   #23
Homemade WRX
Member#: 33782
96 bastard child
^^^^nice
but really, it is when you cut/grind away material inside the exhaust and intake ports to increase flow capacity and flow characteristics...not for noobs to do. You can do more damage than good.
Old 12-01-2010, 04:45 PM   #24
Red_Wrx
Member#: 158658
I'm a noob and I did it? my aluminum bit is my friend. I deshrouded my heads, I forgot the grit number but ported my runners. But not to contradict you homemade I've read alot of your words and I stand by alot of what you say, and I agree . I actually hit a few valve seats and ended up going with 1+ because of it but it's a blessing in desguise.
I figure if u don't got it in the car. Might as well do what you can while you can. It's all worth it.
Red_Wrx is offline   Reply With Quote
Old 12-01-2010, 05:20 PM   #25
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
I'd like to think i did a good job with the bowl, I wish i went with +1 oversize valves.
NITROS is offline   Reply With Quote
What should I port and polish on the td04? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-31-2005 05:38 PM
port and polish heads? 93subi Normally Aspirated Powertrain 20 10-06-2005 02:47 AM
Socal ported and polished heads, Sard, Cusco, Sti, 350 hp package, gfb, and more! Turbo Juice Private 'For Sale' Classifieds 45 07-28-2005 04:55 PM
Ported and Polished heads redhat778 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-22-2004 07:27 PM
ej22 ported and polished heads 4sale dreromeo Private 'For Sale' Classifieds 1 12-13-2003 02:28 AM
