Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 09-28-2010, 05:17 PM   #1
TopSpeed
Vendor Sales Rating: (5)
Member#: 78884
Go faster
at TopSpeed
Default TopSpeed Motorsports AMS GT30R\GT35R Turbo Kits (A TopSpeed Exsclusive)
We are now the exclusive dealer for the AMS GT30R and GT35R turbo kits.
As some of you may know AMS no longer produces their turbo kits with Garrett turbos. We here at TopSpeed Motorsports feel that the performance and quality of the Garrett center section along with the Tial V-Band hotside is unmatched. Therefore we have worked an exclusive deal with AMS to bring back the GT30 and 35R.
These will be available only through TopSpeed Motorsports. These introductory prices will not be available after this initial group buy. We will be selling 5 of these kits at the special pricing below!!
Get your order in now before these prices are gone!
Full TopSpeed Motorsports 30/35r kit by AMS:
Group Buy Close Please Check new thread or PM for Pricing
Kit Details:
In our opinion, there isn't another kit on the market that even compares.
We tested some of the first kits with AMS, and can tell you that they perform great. Fit and finish is amazing, spool and power are honestly as uncompromised as it gets. Our owner and tuner Doug Wilks has one of the first 08+ 35r kits on his car. The car makes 492whp and hits full boost @ 3700RPM (see graph below)
The AMS Subaru Rotated Mount V-band Turbo Kit is the new benchmark in Subaru performance. Designed to meet the demanding needs of road race, drag race and street cars alike, we have successfully achieved unparalleled drivability, response, and horsepower. Our unique design has been tested and refined for over 1 year to provide reliability, OEM like fitment and options never available in a Subaru turbo kit before.
The AMS kit brings some new ideas to the table…
•V-band housings
Each AMS Subaru Turbo Kit incorporates the latest V-band exhaust housings with options for .63, .82 or 1.06 a/r. The Tial Turbo V-band housings not only provide the most horsepower and save weight but they eliminate the need for gaskets and are easier to install. No more annoying exhaust leaks and no gaskets to replace!
•Intake Pipe Solutions
While a unique 3” cold air intake pipe is standard we also provide an option for pull-through or push-through MAF applications.
•Cast Stainless Steel V-band Up-pipe
Implementing CAD and Casting designs we are able to produce not only an extremely strong and reliable piece but one that is not limited to the restrictions of a hand fabricated up pipe. Smooth transitions, optimal pipe diameter and solid construction make the up-pipe another key component to the AMS Subaru Rotated Mount Turbo Kit.
The AMS 30\35R is the perfect choice for street, road race and drag racing and are great all around turbos on pump gas.
Each AMS Subaru Rotated Mount V-band Turbo Kit is hand built here at AMS with a meticulous attention to detail. We know what it’s like to install a turbo kit so we provide all the necessary hardware and detailed instructions for a hassle-free installation.
On a GT30R kit with a top mount intercooler, fuel and exhaust upgrades we were able to put down 485 whp and over 500 ft. lbs. of torque! This same simple combination netted an 11.3 quarter mile time in a full weight 2007 STI on stock tires!!!
Features
•2” ID rotated V-band cast stainless steel up-pipe for optimum flow and durability
•5/8” thick flange on up-pipe to ensure a proper seal
•Turbo support bracket maintains turbo kit reliability under any condition
•304 stainless steel TIG welded construction
•Lifetime Limited Warranty on the up-pipe*
•True Garrett Dual Ball Bearing GT series turbo with ported shroud compressor covers to prevent compressor surge
•Tial Stainless Steel V-band exhaust housing with choice of .63, .82 a/r ratios
•Your choice of a genuine Tial 44mm or 38mm V-band wastegate to ensure proper boost control
•Wastegate feed strategically placed on the Up-pipe for precise boost control
•10” stainless steel external wastegate dump tube
•No gaskets needed for the turbo to up-pipe, up-pipe to wastegate or turbo to downpipe
•Your choice of true 3” cold air intake pipes to suit a pull through or 3” blow through mass air flow sensor intake pipe
•Bolts up to any stock or aftermarket header that fits the factory up-pipe
•Downpipe fits AMS & most other aftermarket cat-back exhausts
•Kit Utilizes 4 ply silicone tested up to 50 psi of boost!
•New coolant lines for your coolant expansion tank for a clean engine bay
•DEI heat insulation to protect OEM wiring from excessive heat
•Kit includes ALL necessary fittings and hardware for installation
•Class 10.9 fasteners & 4 ply silicon couplers. We use the best hardware and silicone so that it goes together right the first time
Kit Includes
•Cast stainless steel Up-pipe
•AMS spec Precision Turbo GT series dual ball bearing turbo with ported compressor cover and Precision V-band turbine housing
•Genuine Tial 44mm or 38mm V-band wastegate
•Integrated turbo support bracket
•AMS high-flow off-road test-pipe (high-flow steel core catalytic converter optional)
•DEI Heat insulation for your electrical wiring
•New lines for your coolant expansion tank
•Stainless steel 3” downpipe with integrated Stainless steel flex section
•Stainless steel oil feed line (fittings for both WRX and STI included)
•Custom AMS stainless steel oil return line
•4 ply silicone 2.5”” turbo outlet pipe, intercooler and intake couplers
•Top quality hardware package including nuts, bolts, fittings and clamps
•Polished aluminum 3” cold air intake pipe with K&N air filter for blow through MAF (pull trough MAF optional)
•Detailed installation guide
Options
•Your choice of .63, .82 a/r exhaust housings (no additional charge)
•3” Pull through MAF intake pipe (optional) or 3” Blow through MAF intake pipe (standard)
•High-flow catalytic converter
Applications
•2002-2011 Subaru STI/WRX
•Fits USDM Models (JDM and European Models yet to be determined)
Purchase these Exclusive kits here
AMS \ TopSpeed GT30R Turbo Kit[/url]
AMS \ TopSpeed GT35R Turbo Kit[/url]
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 09-29-2010, 12:31 PM   #2
TopSpeed
Member#: 78884
Go faster
at TopSpeed
This deal won't last long...if your looking for a turbo kit, or know someone who is then give us a call!
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 10-01-2010, 11:27 AM   #3
Boost!
Member Sales Rating: (1)
Member#: 201148
2006 Impreza WRX STI
Bump since I am the only one on the list so far .
Boost! is offline
Old 10-06-2010, 04:49 PM   #4
Phatron
Member Sales Rating: (50)
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
work with TMIC? like a spearco?
Phatron is offline
Old 10-07-2010, 09:33 PM   #5
JDOG
Member#: 41775
2004 STi
UPGRADING
Will this kit work with an APS 3.5in T.B. exhaust?? Interested.
JDOG is offline
Old 10-12-2010, 10:30 AM   #6
TopSpeed
Member#: 78884
Go faster
at TopSpeed
What Ty said below
Yes sir it sure will!
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 10-12-2010, 12:01 PM   #7
AMS
Vendor Sales Rating: (4)
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
We offer a silicone piece to connect to the OEM STI y-pipe at no additional charge for the TopSpeed exclusive 30r kits. The 35r features a 2.5" outlet and this top mount silicone is not quite ready for shipment.
AMS is offline
Old 10-12-2010, 06:03 PM   #8
02fastWRBLUE
Member Sales Rating: (4)
Member#: 52590
two great companies, one great kit. Wish I was lacking the warranty and had the funds for this on my 08!
02fastWRBLUE is offline
Old 10-13-2010, 10:26 AM   #9
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Ty thanks so much for jumping in here with that info!!
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 10-19-2010, 11:14 AM   #10
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Bumpage
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 10-20-2010, 01:05 AM   #11
Built07
Member Sales Rating: (3)
Member#: 191635
do these turbo's have the HTA wheel? if not how much more for that option?
Built07 is offline
Old 10-20-2010, 11:04 AM   #12
TopSpeed
Member#: 78884
Go faster
at TopSpeed
The HTA wheel is something specific to FP turbos. It is not a Garrett product.
I could call FP and see what they would charge me to install the wheel if you like.
~Cicio
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 10-21-2010, 10:35 AM   #13
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Bump Page
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 10-25-2010, 11:52 AM   #14
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Bump for AMS!
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 10-26-2010, 07:09 AM   #15
dnorton
Member Sales Rating: (51)
Member#: 218997
07 WRX Mikey Tuned
JE/FSR built,35r 1300c
Cicio, Please review the post I sent you and the email about maybe you swapping out my motor for one of your SS1 motors. I really need to put something together soon since I'll be working in your area the 3rd of Nov. This way I can drop off the car with you and the other thing I hate to keep driving using so much oil and scared the next thing to go would be the ring coming apart then doing head damage. Thanks,
dnorton is offline
Old 10-26-2010, 10:12 AM   #16
TopSpeed
Member#: 78884
Go faster
at TopSpeed
PM Replied
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 11-01-2010, 11:06 AM   #17
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Bumpage
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 11-04-2010, 10:19 AM   #18
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Goodmorning Bump
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 11-08-2010, 01:18 PM   #19
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Bump Page
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 11-12-2010, 10:29 AM   #20
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Friday Bump!
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 11-17-2010, 10:55 PM   #21
Bariga
Member Sales Rating: (32)
Member#: 179846
07 STi Limited
EFR 7670 TS
i wish ams made a EL v-band headers to go with this kit, i would love to get it
Bariga is offline
Old 11-22-2010, 11:56 AM   #22
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Bump for AMS
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 11-30-2010, 10:59 AM   #23
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Goodmorning Bump
__________________
~Team TopSpeed
PH: 1-866-94 SPEED
TopSpeed is offline
Old 11-30-2010, 11:17 AM   #24
NITROS
Member Sales Rating: (27)
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
WHOA, this is an awesome deal. Wish this was around when I was piecing my 30r kit together.
NITROS is offline
Old 12-01-2010, 01:05 AM   #25
shu_chen4
Member Sales Rating: (25)
Member#: 12182
89 S52 E30
What are we looking at in terms of install/tune cost and timing?
shu_chen4 is offline
Closed Thread
TopSpeed Motorsports AMS GT30R\GT35R Turbo Kits TopSpeed Engine/Power/Exhaust 9 11-04-2010 10:21 AM
AMS 35r turbo kit rooobaru NESIC Private Classifieds 54 08-08-2009 09:41 AM
AMS GT30r Turbo Kit - 2005 STI - 475whp, 520wtq AMS Proven Power Bragging 44 03-07-2009 12:06 AM
Ams rotated turbo kit is out!!! EvosSti Mid West Subaru Owners Club Forum -- MWSOC 0 02-01-2009 01:26 PM
