Old 09-28-2010, 06:37 PM   #1
leg1999
Member#: 201993
99 legacy 30th anv
Low and slow, RIP, 97 LGT
Default 97 LGT fuel trim code
Last night I was driving on the freeway and my car started spurrting. It's been running funky for the past couple of weeks, in which I changed out the HG's and cleaned the IAC. The car was running at a low idle when I bought it 8k ago and the IAC cleaning didn't help the idle.. Instead of low idle now, the cars idle jumps up and down from about 2 or 300 to 1000 rpm. it also doesn't want to free up it's power, it will bog for a second and then jump to normal power and it will continue this throughout the time driving it. Any ideas to if this may be a weak fuel pump or if it sounds like I am loosing an injector? Forgot to mention it's running rich, fuel can be smelt through the exhaust.
leg1999 is offline   Reply With Quote
Old 09-28-2010, 08:10 PM   #2
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Check the spark plugs. That could explain why you are running rich and why you are sputtering at low rpms. I had a fouled plug and it was causing backfire through my intake and ridiculous sputtering in the low rpms.
Jessekrs123 is online now   Reply With Quote
Old 09-28-2010, 08:49 PM   #3
leg1999
Member#: 201993
99 legacy 30th anv
I just got a check engine light for a misfire in cylinder 2, i'll be checking the plugs!
Old 09-28-2010, 09:18 PM   #4
leg1999
Member#: 201993
99 legacy 30th anv
Checked spark plug number 2 and it wasn't fouled. Maybe injector??
Old 09-29-2010, 02:50 AM   #5
leg1999
Member#: 201993
99 legacy 30th anv
I'm also thinking it could be a worn out IAC valve?
Old 09-29-2010, 11:20 AM   #6
Jessekrs123
Member#: 236927
1984 BRAT
The IACV wouldn't cause a physical misfire, it would just cause your idle to be funny. What did the spark plug look like from cylinder 2? You will be able to tell how your engine is misfiring by the condition of your plug. Check your spark wires, check the coil that goes to cylinder 2.
Old 09-29-2010, 01:52 PM   #7
leg1999
Member#: 201993
99 legacy 30th anv
hmm, The spark plug looked fine. I've had fouled plugs in my other legacy and this plug was in almost perfect condition. I pulled the wire off the ign. coil and spark was going from the coil to other stuff not the wire and the car dropped idle as well. I believe that means both are functioning properly right?
97 LGT Raw Fuel Smell gathermewool Service & Maintenance 0 05-19-2009 09:53 PM
97 LGT - Fuel delivery problem - possibly related to gas fillup problem? GTWagon_Phreak Legacy Forum 2 05-25-2008 11:07 PM
WTB: 97 LGT (or comatible) MAP + radio trim piece gathermewool Private 'Wanted' Classifieds 3 04-15-2008 08:22 AM
CEL: Code P0170 Fuel Trim Malfunction Takashi Normally Aspirated Powertrain 2 04-29-2003 01:55 AM
('93-'01) My service today: P170 Fuel Trim Code??? RacerinLSL Impreza Forum 10 07-19-2001 04:01 PM
