Old 09-28-2010, 08:11 PM   #1
kamilitaryman
Member#: 228284
Default EJ25 rebuild - need advice from RS veterans
Ok here's the story:
My 2000 Impreza 2.5 RS is losing coolant. It overheated badly about a month ago and it's been "sipping" coolant every time I drive it. I changed my oil last week and found that it was chocolate/cream colored meaning that coolant is definately getting into my block. I'm suspecting a bad head gasket that's been pushed past it's limits as the EJ25 SOHC had a head gasket issue straight out of the factory. This is my 2nd rodeo with engine tear downs, here's my 1st (still in progress) - I'm in the middle of another build that's being put on the back burner http://www.ka-t.org/forums/viewtopic.php?t=40793&start=0
Anyways, this weekend I want to take the motor out, tear it down and rebuild it. This is where I ask you RS veterans to chime in:
Eventually, and I mean in about 2 years or so I will turbocharge this motor with a small turbo @ 5-7psi. Quick spool with little extra pep for daily/winter driver. I want to rebuild this motor to be able to handle boost but at the same time keep the components stock or as close to stock as possible so when I install the engine back in the car it will be a drop-in, fire-it-up affair for N/A driveability for about 2 years (until I turbo). This will give it plenty of time for brake-in.
I want to at least replace the pistons with forged ones to give myself a little peace of mind for when I actually turbo it. Can I keep stock compression for 5-7 psi? How do you guys think the rods will handle 5-7 psi?
How about rebuild kits? What is the best place on the net to purchase the EJ25 rebuild kits (seals, bearings, gaskets etc etc) and how much do they run for? Any known and reputable brands that you guys swear by? How about timing belt kits?
I want to make this motor reliable and fun once I turbo it. Help a brotha out! I will continue my search as well, I dont expect to be spoon fed info here
kamilitaryman is offline   Reply With Quote
Old 10-22-2015, 07:00 PM   #2
jonathan9586
Member#: 432396
2002 2.5RS
not much of a veteran on this as i am in the process of rebuilding my 2002 2.5RS. the best rebuild kit that i have came across is from the full rebuild kit from rockauto.com, $450 (full gaskets, bearings, seals, pistons, oil pump, timing belt) + new head bolts (need em).
i was just scanning through the forums to get some torque specs from assembly once i get the halves & heads back from the machine shop. i will go ahead and subscribe to this. i need all the info i can get also.
jonathan9586 is offline   Reply With Quote
Old 10-22-2015, 11:37 PM   #3
Andrewxxcarlson
Member#: 316415
2006 WRX
I just got done rebuilding my 01 rs.
I saw rockauto gasket set but passed due to not knowing DNJ very well. I went with a felpro head gasket set, comes with headgaskets, valve cover, intake Mani and exhaust gaskets, valve seals and cam seals, for like 120. I bought OEM from Subaru water pump and gasket, and every gasket in the block, and spark plugs. Everything was in spec at the machine shop so I bought a standard size set of acl main and rod bearings from rallysportdirect. Reused my pistons and rings as I didn't not have my walls honed. Sti rods and pistons will handle 7 psi. BTW gates timing belt kit, rockauto got a solid price.
Andrewxxcarlson is offline   Reply With Quote
Old 10-24-2015, 08:38 PM   #4
keyoutback
Member#: 432846
2001 Outback
I second RockAuto for the Gates belt kit, and Summit had the best prices on the Felpro MLS headset.
keyoutback is offline   Reply With Quote
Old 11-11-2015, 03:01 PM   #5
landoficensnow
Member#: 332534
2013 WRX Hatch
Is everyone cool with going with Gates? I've heard the blue belts have caused issues.
landoficensnow is offline   Reply With Quote
Old 11-12-2015, 02:36 AM   #6
Andrewxxcarlson
Member#: 316415
2006 WRX
Go gates, don't get the racing belt though.
Old 11-12-2015, 10:44 AM   #7
GEE-OTTO
Member#: 201277
2009 Legacy GT
Go gates but go with a OEM thermo as the gates one is trash.
GEE-OTTO is offline   Reply With Quote
Old 11-12-2015, 01:32 PM   #8
razor7
Member#: 433899
2000 RSTI
Pretty much this.
Gates belt, OEM water pump, OEM idlers, tensioner, pulleys.
I'd also recommend STI MLS head gaskets. If you do a search, you can get more info. I forget the cutoff for when they switched over to MLS head gaskets, but they are much less prone to seeping and oil leakage. I updated mine on a 2000 2.5RS and have had it running strong for ~60k miles - definitely worth it.
-TC
razor7 is offline   Reply With Quote
Advice from Outback Veterans grambo Outback Forum 4 11-19-2007 12:56 AM
ej25 rebuild. need part numbers for SOHC belts! opious Normally Aspirated Powertrain 3 09-17-2007 04:10 PM
Warranty work needed on a "Brand New Car." Need advice from SoCal people. Jelphree Southern California Impreza Club Forum -- SCIC 49 05-17-2006 12:36 PM
Advice from RS-T owners? gould9184 Normally Aspirated with bolt-on Forced Induction Powertrain 44 05-20-2004 03:26 PM
need advice from someone who knows 98 rs lotion Normally Aspirated Powertrain 5 09-12-2002 05:06 AM
