Old 09-28-2010, 09:30 PM   #1
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
Crystal Grey Mettalic
Default cracked 2.0 head
ok so i tore down my 2.0 this week and have been planning on doing a hybrid set up... ive read that typically a cracked 2.0 head is very common...mine is cracked in the typical spot starting out by the spark plug heading towards the valve, and not sure if i goes past the valve or not. before the tear down the car ran very well other then the spun bearing and didnt consume oil, so my quesion is what are my options? do i get the head cleaned, get a valve job and resurfaced or do i try to find some 2.5 heads or a set of uncracked 2.0 heads if such a pair exists?
Daniel's05WRX is offline   Reply With Quote
Old 09-28-2010, 10:55 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
get it welded and machined or buy the pair that I have sitting in my man cave..
Old 09-28-2010, 11:08 PM   #3
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
What would u want for them?
Old 09-29-2010, 05:51 PM   #4
nizwrx
Member#: 145600
2003 Wrx impreza
You can get them fixed at the machine shop. It would probably be cheaper. Uncracked heads are hard to find. They are redonkulas expensive from Subaru. If you wanna sell them let me know. I would buy them.
nizwrx is offline   Reply With Quote
STI cams in 2.0 heads on 2.0 block? OUScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-06-2010 10:05 PM
Sti shortblock, 2.0 shortblock, 2.0 heads needawrx13 NESIC Private Classifieds 8 01-11-2010 09:28 AM
cracked 2.0 heads, worn sti crank, good/bad sti upjeeper Engine/Power/Exhaust 5 04-06-2009 07:46 PM
2.0 head crack at plug hole short block Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-08-2006 05:25 PM
2.5 shortblock w/ 2.0 head?'s AK'S REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-22-2002 06:01 PM
