Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 09-29-2010, 06:14 PM   #1
builtsubie
Member#: 226788
Default piston clearence
i have problem the ******* that did my machinework lost the paper that comes with the pistons. i just need basically the piston to wall clearence on 100 mm pistons thanks there weisco pistons
builtsubie is offline   Reply With Quote
Old 09-29-2010, 09:47 PM   #2
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
I suggest you just call Wiseco or look at the website for the clearance they "suggest".
If you want to be a bit smarter about it, spell out your power goals, other engine related tolerances and specs, and then choose a piston to wall clearance based on what has been known to work with those specific pistons, in concert with the rest of your build plans.
Team Scream is offline   Reply With Quote
Advanced Piston - Bore Clearence ?s for a DD Bad Noodle Built Motor Discussion 61 10-27-2011 03:47 PM
Piston to wall clearence measurement question Bad Noodle Built Motor Discussion 32 02-15-2011 03:16 PM
Cosworth pistons on Hybrid block valve clearence? SubieStylez Built Motor Discussion 10 03-06-2008 07:11 PM
Home clearence ImprezaTs Vancouver Impreza Club Forum -- VIC 15 03-04-2002 03:11 PM
Tweeter Kit Clearence!!!!!!!!!! HIHO Legacy Forum 5 08-22-2001 10:07 AM
