Old 09-29-2010, 07:31 PM   #1
matthewlikewhoa
RIP 8/20/11
Member#: 159949
2005 2.5RS sedan
Crystal Gray
Default 1997 outback sport interference or not?
I might be able topick up a 1997 outback that the timing belt snapped on and I have searched on line and some things say the motors are interference motors and some places say they are not. I will be paying next to nothing for the car and fixing it up and most likely reselling it. Any help would be appreciated
matthewlikewhoa is offline   Reply With Quote
Old 09-29-2010, 08:17 PM   #2
cmiovino
Member#: 134005
2004 WRX Premium
I had the same question when I was doing the belt on my '98. I came to the conclusion that...
SOHC engines became an interference type in 1997, when compression ratio was increased, along with other changes.
Here is my thread:
http://forums.nasioc.com/forums/show....php?t=1996047
The SOHC EJ Subaru boxer engines were non-interference engines through 1996, run by a single timing belt driving both cams (both sides of the engine) and the water pump. Because they are non-interference engines, if the timing belt fails, the engine of the models up to 1996 will not be destroyed. The oil pump is driven directly from the crank shaft and the waterpump by the timing belt. All DOHC and 1997-up SOHC EJ engines are interference engines, if the timing belt fails the engine will likely be destroyed or the valves & piston will be heavily damaged.
I've researched it hardcore before and found it's '97+ models and all DOHCs.
Old 09-29-2010, 08:56 PM   #3
matthewlikewhoa
RIP 8/20/11
Member#: 159949
2005 2.5RS sedan
Crystal Gray
Thank you
'09 Outback Sport - Moonroof or not? Zillon Impreza Forum 3 12-27-2008 10:53 PM
1997 Outback Sport lighting VWVancouver Electrical & Lighting 0 03-10-2005 05:53 PM
98, 2.2L, Outback Sport, Interference of no? hymalaia Service & Maintenance 3 09-15-2004 08:33 AM
CA: 1997 outback sport wrxben Private Vehicle 'For Sale' Classifieds 4 06-06-2004 08:03 PM
2.2L (EJ22) 1997 OBS Interference or Not? fourwheeldrift Service & Maintenance 1 11-16-2001 03:41 PM
