Old 06-26-2002, 01:34 AM   #1
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Default Went back to the track....
My previous best run was a 9.430 @ 74 MPH... tonight I ran this..
Mods: MBC, Uppipe
Finally learned how to drive her, well sorta.. need to work on those 60ft times. Car was making a WEIRD WEIRD sound around 6000+ rpms.. anybody know what it could be? Was like a rev limiter sound, but not nearly as loud...
Jay
Diversion is offline   Reply With Quote
Old 06-26-2002, 07:58 AM   #2
VetteVert
Member#: 5961
2005 STi
CGM
Not sure what the sound might be, but nice improvement
VV
VetteVert is offline   Reply With Quote
Old 06-26-2002, 09:05 AM   #3
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
detonation maybe? like a popping sound... real faint sometimes, usually from the passenger side bank...
what do you have done and what boost are you running? A stock car with no fueling adjustments running higher boost WILL detonate rather easy... especially in this hotter weather.
def
dug-e-fresh is offline   Reply With Quote
Old 06-26-2002, 11:02 PM   #4
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
It definately wasn't a popping sound, more like a vibration sound.. it could have been the combination of an unbolted muffler and really bad exhaust leak in the uppipe region.
I'm running 15.5 psi in 5th gear... I doubt that would cause detonation, since I only get to 3rd in the 1/8th mile, I'm MAYBE hitting 14.5 PSI.
Since then i've bolted my muffler back on and the sound isn't apparent anymore.
VetteVert: Thanks man! There was a bone stock WRX out on the track with me, he was running 9.0s!! Obviously my launching needs work!
Jay
Old 06-27-2002, 07:57 AM   #5
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
Just curious, when does a rev-limiter sound like a vibration? Before, you compared the sound to the likes of a rev-limiter... and now just a plain exhaust vibration. Thats a big difference... just curious how you came up with those descriptions... at any rate I am glad to hear that you have narrowed down the issue and that most likely its not det.
def
Old 06-30-2002, 04:40 AM   #6
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Ok, I've figured out what that strange sound was, it was my exhaust leak. Me and some friends finally fixed it completely and the car runs like a champ. No strange sounds all the way to redline..
Scary what an exhaust leak will do your head.. heh, I thought my motor was knocking.
Jay
Old 06-30-2002, 04:13 PM   #7
STEALTH-WRX
Member#: 7822
Multi layer snot green
how come my times are close but my trap speeds are like 84 and 85. i am getting consistant 8.7's at 1.8 0-60 foots. why are my traps higher, and if they are higher why am i only getting 8.7?
STEALTH-WRX is offline   Reply With Quote
Old 06-30-2002, 08:38 PM   #8
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
Stealth Wrx - Good Launch if you are consistant 1.8's and your trap speeds are @85? - could you be shifting too soon?
Sordid Philosopher is offline   Reply With Quote
Old 06-30-2002, 09:03 PM   #9
STEALTH-WRX
Member#: 7822
in first gear i shift at 7k and second and third 6500rpm.
Old 06-30-2002, 11:22 PM   #10
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
What do you have done to your car, Stealth?
Your .2 faster times should land you into the 80s. So that's probably right.
Jay
Old 06-30-2002, 11:46 PM   #11
STEALTH-WRX
Member#: 7822
stock turbo
stock ecu
stock injectors
up pipe
down pipe
stock exhaust
samco turbo inlet
cut up injen intake
blitz front mount intercooler
boost set at 13 psi until i get a bigger turbo, injectors, and ecu
18 inch dronnel wheels (heavy) with 225/40/18
Old 07-01-2002, 03:59 AM   #12
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
With those mods, your time sounds about right.. don't worry, your car is fine. =)
Jay
Old 07-01-2002, 01:36 PM   #13
STEALTH-WRX
Member#: 7822
cool. i just wanted to make sure i was not drving a lemon.
Went back to the local 8th-mile tonight... UltimateLurker Proven Power Bragging 31 10-10-2006 03:41 PM
Finaly made it back to the track... jetfan8178 Motorsports 5 07-01-2006 10:16 AM
Back to the track again.... Chad W Proven Power Bragging 6 11-01-2005 05:07 PM
So I sold the 10D and went back to the D30 mattjk Off-Topic 13 09-10-2004 10:09 PM
So I went back to the Chicago Auto Show and... mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 2 02-13-2003 07:22 PM
