Old 09-29-2010, 09:32 PM   #1
grant696
Member#: 259105
2007 N/A 2.5i
Newport Blue
Default HID question
I just recently bought my n/a 07 impreza 2.5i sedan and installed hid's in the stock headlights. I disconected the DRL's from behind the glovebox and also undeneath the hood. I still keep getting the cel and flashing cruise control light. I know that there are endless threads on this but I can't seem to find the exact answer that I need. Do I need a relay? Please respond back.
Thank you, -Pat
grant696 is offline   Reply With Quote
Old 09-29-2010, 10:19 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You won't get a CEL from disconnecting the DRLs. Either you disconnected the wrong thing, or it's a coincidence that the light came on at the same time.
Go to Autozone and get the code read to see what it is telling you.
Old 09-29-2010, 10:27 PM   #3
grant696
Member#: 259105
2007 N/A 2.5i
Newport Blue
Ok thank you. I actually tried to send you a private message but your inbox was full. The CEL came on before I disconnected them. It comes and goes.
Old 09-30-2010, 02:15 AM   #4
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
When putting HIDs on a car that didn't come with them, you absolutely need a relay harness. The stock wiring is not designed for the 10 or more amps drawn by the HIDs when they are starting up. STis with factory HIDs have 14 or 12 gauge wire going to the headlights. Your car has 18 or 20. It might work out OK for a while, but eventually something's going to melt, or worse catch on fire. Then again the crappy Chinese ballasts or bulbs could very well catch on fire at any moment. It's happened before.
The other things that you absolutely need when installing HIDs, are HID optics, which you do not have either.
FourOnTheFloor65 is offline   Reply With Quote
Old 09-30-2010, 07:07 AM   #5
grant696
Member#: 259105
2007 N/A 2.5i
Newport Blue
Okay thank you Four, I greatly appreciate you responding. Also, what are HID optics?
Old 09-30-2010, 08:49 AM   #6
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Thank you, -Pat
For 2007, Subaru changed the way the DRL's were controlled. This means there no longer is a relay behind the RH side of the glove-box to disconnect to disable the DRL's.
If you disconnected the resistor that is under the hood, which is mounted to the passenger's side strut-tower, then leave it disconnected. But, whatever you unplugged from behind the glove-box, reconnect it (with the car off).
Old 09-30-2010, 10:46 AM   #7
grant696
Member#: 259105
2007 N/A 2.5i
Newport Blue
Okay I will. Thanks for the input.
Old 09-30-2010, 04:27 PM   #8
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
Optics are simply devices that control light. With headlights these would be either reflectors, or in your case, projectors. HID and halogen projectors are very different. You cannot just mix match light sources in a given optic. Light is emitted from an HID capsule totally differently than it is from a halogen bulb. Just because the rebased HID capsules that you bought physically fit in the back of the projector, doesn't mean they are appropriate, safe, legal, or even an upgrade over the stock halogens.
Read these...
http://forums.nasioc.com/forums/show...ight=handsdown
http://www.danielsternlighting.com/t...dvantages.html
http://www.danielsternlighting.com/t...nversions.html
It is probably good to read them in that order. Hopefully after that you will reconsider the HID kit, and put your halogens back in.
HID and NON HID question samg00dy06STI Interior & Exterior Modification 2 04-17-2009 06:33 PM
STi's in Niagara Falls, NY or Michigan ? HID vs non-HID question/content... SportyBry STi Forum Archive 3 07-26-2003 03:37 PM
HID question? AudioFan Interior & Exterior Modification 3 02-08-2002 07:32 AM
HID question and advice leungl Bay Area Impreza Club Forum -- BAIC 1 01-06-2002 12:43 PM
('93-'01) HID question Billy Impreza Forum 2 07-16-2001 02:11 AM
