Old 09-30-2010, 10:38 AM   #1
SubbyOBS
Member#: 124035
99 LOB and RS
Default Car choking under heavy rain?
My subaru 2.5L NA, 1999 RS was driven today under the heavy rain. The road is not ponding water, but it surely had around 1-2 inches of water.
When idling at the light, I noticed that the RPM was dropping suddenly to nearly "0" and then back up. The battery and the charging system is working because the car was service and checked two weeks ago.
Then when I accelerated the car, the RPM started to "choke", then when it runs to around 1 or 1500, it goes back to smooth. I haven't experienced this thing before...
So after I head back to the garge, opened the hood and check for wiring, everything seem to be connected, but some water did got on the air-intake (OEM), and the intake pipe due to the scoop that was designed for that year.
I am wondering could that be the water touched the ignition coil (the black box) and cause this?
Or if not, what cause such unstable choking under the rain. On a regular day, the car is fine and smooth.
SubbyOBS is offline   Reply With Quote
Old 09-30-2010, 04:47 PM   #2
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
Yes. If your ignition wires are on the old side, getting wet could definitely have them shorting out. Get a spray bottle of water and mist over the coil, if you sputter you've found your answer.
motohippy is offline   Reply With Quote
Old 09-30-2010, 11:43 PM   #3
rob17san
Member#: 259519
Do you have your inner fender wells intact?
rob17san is offline   Reply With Quote
Old 10-03-2010, 08:54 AM   #4
SubbyOBS
Member#: 124035
99 LOB and RS
My 1999 had the cover comes with it already. I guessed when I purchased the car, the dealer put that cover on.
Heavy rain today and open sunroof / thanks God for co-workers Marcin Mid West Subaru Owners Club Forum -- MWSOC 68 08-15-2005 05:31 PM
Heavy Rain = Flooded Car: HELP! acsWRX Interior & Exterior Modification 16 08-14-2004 03:24 AM
car keep stalling under heavy rain and thunder starBug Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-13-2004 02:45 AM
Azenis + a day of heavy rain = doobie Tire & Wheel 17 05-01-2003 11:49 AM
My DIY intake tested in heavy rain... 8Complex Technical Forum Archive 6 07-21-2000 09:36 PM
