Old 09-30-2010, 10:49 AM   #1
polskaboys
Member#: 221147
2011 STI LIMITED
WHITE
Default Hybrid swap, purchasing stuff this week need help
So after spend 6 grand an getting my 2.0 motor rebuilt by a company my motor only lasted 1200 miles before getting a rod knock on the dyno, so going a diff route this time, heres everything im purchasing this week an i need help to know if im missing anything or if im doing something wrong etc in doing this hybrid swap,
Heres the list
2009+ STI EJ257 Shortblock with Nitride Treated Crankshaft
2008 USDM STi 11mm Oil Pump - Kit
OEM complete gasket kit with Cosworth 1.5mm Head Gasket (to lower compression)
OEM Oil Cooler
Im assuming ill be able to use everything else to bolt on since there still new with 1200 miles, Timing belt? water pump etc? Let me know please any help will help an im all EARS to learn more about this swap as i did my research etc. im not trying to go all crazy with this swap since i lost 6 grand last month on my 2.0 rebuild.
polskaboys is offline   Reply With Quote
Old 09-30-2010, 11:01 AM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
you got the turbo?
Sounds good, I would recomemd sticking with OEM head gaskets and getting ARP head studs
GL
Old 09-30-2010, 11:07 AM   #3
polskaboys
Member#: 221147
2011 STI LIMITED
WHITE
Originally Posted by juanmedina View Post
you got the turbo?
GL
Yea came in yesterday (sorry for bugging you for it), but BAM ROD KNOCK on a fresh rebuilt motor so now im doing what i should of done from the beginning, im not trying to go crazy with this built since i just lost 6 grand an doing the swap on my owen when i finally get home, would everything else bolt on to the ej257 from the 2.0 sb? timing belt, water pump, etc? hoping the vf39 will do good with the ej257 sb
Old 10-01-2010, 10:26 AM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
to keep new motors running after a rod failure or pistons failure of the current engine means you need to make sure the oil cooler get replaced, clean out the oil pump, clean the oil galleys on the block AND heads. The turbo will survive if the car was shut off as soon as you heard it. If ran too long the turbo will die and a new one needed.
These are important measures that's all. It's good that you're getting a new one for the next build. All the things will just need to be bolted onto the next shortblock.
So no warranty on the 2.0L??
FuJi K is online now   Reply With Quote
Old 10-01-2010, 02:12 PM   #5
polskaboys
Member#: 221147
2011 STI LIMITED
WHITE
Everything was replaced brand new since everything was destoryed with metal, Brand new 11mm oil pump, oil cooler, water pump complete Head gaskets, Used oem turbo with low miles, redid the heads chances are im missing something. I bought the rebuilt shortblock from (no name company since i wont deal with the drama) an they bought it from someone else so they wont warranty it. I know im getting Screwed with since im not HOME to deal with this an currently in Afghanistan for the last 2 years. so now im doing what i should of done from the beginning an going with the hybrid swap
Old 10-02-2010, 09:37 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
that block must have not been cleaned.. must have had shavings in the oil galleys.... that's my guess.... good luck with the new build though!!
Just purchased an 03 WRX. Need Help! DHusidic Newbies & FAQs 1 06-27-2009 01:51 PM
emissions test this week...need advice. sc00by4life North West Impreza Club Forum -- NWIC 15 09-13-2007 08:06 PM
Having a cage built this week, need some advice MattSTi Motorsports 12 06-27-2006 10:08 PM
Car PC anyone? Just got a buncha stuff and I need help. JjSwee Car Audio, Video & Security 4 11-12-2005 08:41 PM
Checking out a WRX this week...need advice RedlineRacer Newbies & FAQs 6 05-10-2005 10:31 AM
