Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Closed Thread
Old 09-30-2010, 12:42 PM   #1
AWD P & A
Vendor Sales Rating: (2)
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Default New Products at AWD P&A
This thread will be updated periodically with new products so if its been bumped that means there's a new product to drool over
All products will be listed in the Vendor Classified section as well.
HKS has released a handful of new items. First and foremost they released a new 02-07 WRX/STi exhaust with a full titanium tip, and fuel upgrade kits for the 08+ STi.
AMR has released a new bigger and badder turbos for the Subaru community. The new CXR turbo comes loaded standard (gaskets, lines, ported, coated). This turbo flows 80lbs/min and is rated up to 750hp.
Product: CXR750 Bolt-On Turbo
Fitment: 02-07 WRX / 04-11 STi
Power: 550+whp (93 Octane)
Features:
• 80lb/min Compressor
• 8cm Exhaust Housing
• 3" Compressor Inlet
• Ported Compressor Housing
• Ported Exhaust Housing
• Oil & Water Cooled
• High-Temp Coated Exhaust Housing
• Wrinkle Red Compressor Housing
• Includes all oil and water lines
• Includes all gaskets
• 90 day warranty against defects
Cometic has released new gaskets!
Subaru EJ street pro gasket kits (which are priced well below OEM).
Subaru EJ205 DOHC 02-05 93mm Complete Gasket Kit (OEM # 10105AA560)
Subaru EJ257 DOHC STI 04-06 101mm Complete Gasket Kit (OEM# 10105AA590)
PM for prices
ARP has released a new fastener assembly lubricant which outperforms EPL, Moly, and Oil. ARP Ultra-Torque gets you within 5% of the required pre-load on the first pull and stays consistent with each subsequent cycle – race prep, machining, pre-assembly and final assembly!
ARP Ultra-Torque was developed to:
• be more consistent
• be more repeatable
• have no harmful contaminants
• and achieve the target preload ON THE FIRST TORQUE CYCLE
ARP Ultra-Torque Repeatability Data
• Specifically designed as a fastener assembly lubricant for high performance engines.
• Repeatable: 1 stud –10 torque cycles: within 5% of target preload
• Consistent: 10 studs –1 torque cycle: all within 5% of target preload
• Better physical properties melting point, corrosion prevention, elimination of galling and seizing
0.5 oz. Blister Pack
1.69 oz. Tube
10 oz. Brush-top Bottle
__________________
[SIGPIC][/SIGPIC]
[COLOR=Black]New Website:
[/COLOR][COLOR=Black]
Email:
[/COLOR][COLOR=Black]OR[/COLOR]
[COLOR=Black]Send a PM!![/COLOR]
AWD P & A is offline
Old 10-11-2010, 02:45 PM   #2
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Thermo Tec Formed Turbo Cover
Thermo Tec has released a new turbo cover. This cover increases spool up, reducing turbo lag problems, and reducing overall under-hood temperatures. Dual layer construction increases performance and durability over comparable products already on the market. The kit includes grommets and wiring for easy installation. Help customers improve horsepower and performance by maintaining temperatures inside the turbo with this “Made in the USA” product.
AMR WRX/STi Turbo Inlet
AMR has released a turbo inlet hose for the 02-07 WRX / 04-11 STi. It is only available in a wrinkle red finish but includes both a standard size turbo and three inch inlet turbo coupler so this product can be used throughout a customer's upgrade path from stock turbo to turbo upgrade.
PM now for a ridiculous low prices
__________________
[SIGPIC][/SIGPIC]
Email:
Closed Thread
Pioneer unveils NEW products at 2010 CES [Video Coverage] PostRelease Interior & Exterior Modification 0 01-19-2010 12:59 PM
New Products at Promotional Pricing, Lateral links, End Link, and Collars PolTec Inc Suspension/Brakes/Handling 40 11-01-2004 10:55 AM
Even more new products at our store... MPREZYA Southern California Impreza Club Forum -- SCIC 0 11-14-2001 12:11 AM
Sneak Peek of New Products at APS/Cobb show at Modern Garage on Oct 6th t-bone North West Impreza Club Forum -- NWIC 0 09-24-2001 10:11 PM
