Old 09-30-2010, 01:26 PM   #1
schrack
Member#: 241576
2002 WRX Stage2
Sodona Red
Default Installing Guages ?
Am getting ready to install a dash pod on my 2002 wrx, & have a couple questions. First, is how do most hookup for oil temp & oil pressure, do you use a sandwich adapter, or do you use the oil gallery plug on the block & T it? How does everyone hookup the water temp gauge, where do you install the sensor. Any help appreciated. Thanks
schrack is offline   Reply With Quote
Old 10-01-2010, 09:08 AM   #2
rkramer
Member#: 118209
2015 WRX Limitec
Originally Posted by schrack View Post
Am getting ready to install a dash pod on my 2002 wrx, & have a couple questions. First, is how do most hookup for oil temp & oil pressure, do you use a sandwich adapter, or do you use the oil gallery plug on the block & T it?)
If you install a galley plug with hose & T, there won't be any oil in the hose under normal conditions! You will be measuring air pressure, which is being pressurized by the oil. That's fine for pressure, but won't work for temp. Temp HAS to be in contact with the oil, so if you want both sensors, the temp needs to be a sandwich or oil plug adapter.
Old 10-01-2010, 09:13 AM   #3
MY EJ20T
Member#: 133324
2002 MBP Stg 2 Rally
MBP
sandwich is the best way to go!
MY EJ20T is offline   Reply With Quote
Old 10-01-2010, 09:32 AM   #4
schrack
Member#: 241576
2002 WRX Stage2
Sodona Red
Got the sandwich, so whats the best way to mount the water temp gauge?
Old 10-01-2010, 10:06 AM   #5
littlewhitewagon
Member#: 103068
11 STI sedan
The easy way? Hose adapter block. You cut the hose somewhere and fit the adapter in. Some aftermarket radiators have bung locations.
littlewhitewagon is offline   Reply With Quote
Old 10-01-2010, 12:07 PM   #6
schrack
Member#: 241576
2002 WRX Stage2
Sodona Red
Really don't want to have to cut the hose, could care less if it wasn't silicone. Any other way to mount it?
Old 10-01-2010, 01:31 PM   #7
rkramer
Member#: 118209
2015 WRX Limitec
either the two options above, thats about it if you want reliable readings. you MIGHT be able to remove one of the two plugs on the bottom of the block and find an adapter you could screw a sensor into.
FS/FT : 02wrx wheels - jdm sti guage Lazaride SWIC Private Classifieds 12 11-04-2010 12:28 PM
Installed Up and DP now... jahsun145 Newbies & FAQs 22 10-01-2010 01:16 PM
Anyone installing guages in their 08/09 STI? 2fas4u Electrical & Lighting 2 10-23-2008 09:44 PM
Any reputable tuner in NNJ that can install guages? rommel Tri-State Area Forum 9 04-04-2006 09:33 PM
Questions on Installing Guages..Please help! blindclown General Community 3 07-06-2002 12:00 AM
