#1 |
Member#: 487
TXIC
Vehicle:1998 /2005 STunIcorn Acadia Green RS-T |
http://forums.nasioc.com/forums/show....php?t=2063079
seems that its close to 50/50 chance of normal/abnormal wear per responses so far. ![]() what do you built guys think? the vertical striations on the 'bottom' of the cylinder sleeves is what is in question. thanks
#2 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
wear pattern looks odd.
did you pull the pistons yet? |
#3 |
Member#: 115070
Vehicle:2002 2.1L 20G WRX 08 Audi Q7 4.2 Prm |
Nope, it's not normal wear. How are the exhaust valves? How's the compression on it?
#4 |
Member#: 65916
Vehicle:1996 Impreza WRX |
Are those forged pistons? Did the block get honed for proper clearances?
#5 |
Member#: 487
TXIC
another member posted this in 2.5L Powertrain Forum
CN's: i believe he just replcd HG's on a stock motor......the pistons are OE as far as i know (he stated that his heads were lifting during heavy boost??????) no warp to deck or heads engine wasnt smoking, but he doesnt specify if was overheating i am interested in the wear pattern if it is normal or not so far: half the amt of members say normal half the amt of members say its f******up ?????? information is purely for myself if i ever encounter this sort of scoring in any engine cyl sleeve thanks again steven |
#6 |
Member#: 149114
of the several stock motors i've torn apart, none had scoring like that....
#7 |
Member#: 487
TXIC
^^^the vertical scores correct?
even i have seen the criss cross ones b4. |
| Thread Tools | |
| Display Modes | |
| Issue or normal? Center or rear diff? | talvai | Transmission (AT/MT) & Driveline | 5 | 11-18-2009 06:56 AM |
| baby, srsy...WTF are you wearing? or melonpants or bloody leopard | SQ3.0dotJP | Off-Topic | 18 | 09-27-2008 01:08 PM |
| Cam wear or worse? | cueball89 | Normally Aspirated Powertrain | 15 | 05-28-2007 08:58 PM |
| Tire wear, or do I just suck? | ratt_finkel | Motorsports | 13 | 07-27-2005 06:18 PM |
| Re-92 Abnormal wear ?? | Deznuts05 | Brakes, Steering & Suspension | 6 | 02-19-2001 12:27 AM |
