Old 09-30-2010, 06:15 PM   #1
mtcs
Member#: 180640
2000 FF Drag Impreza
6765,PPG,brakeman,Chute
Default Let's talk aftermarket Head Studs
Hey,
well my block and heads should be on their way back to me in the next few weeks. There are a few loose ends on my build that I want to finalize before I start assembly.
I currently have a set of ARP std head studs in the garage that I was going to originally use on my build, but have decided against it.
A few motors ago, I stapped a std arp in half. Lets just say I wasn't too thrilled with ARP at that point. Apparently, I was told that once in a while there are freak head studs that break. Id really rather have 100% confidence in my studs than hope that they don't fail at high boost.
I have been searching online and have come accross a few aftermarket studs that seem promissing.
Rigoli 14mm head studs ($650 new. Pretty damn expensive. But is it worth it?)
P&L 13mm head studs
ARP L19 head studs
Cosworth 11mm head studs
Anyone have good/bad luck with any of these?
Anyone else make oversized studs for the subaru besides the ones in the list above?
mtcs is offline   Reply With Quote
Old 09-30-2010, 06:33 PM   #2
dap
Member#: 214798
2011 Fully Built STI
Originally Posted by mtcs View Post
Hey,
P&L 13mm head studs
ARP L19 head studs
Staying with the stock size have you thought about ARP 625+ aged? Were your previous ones ARP2000's?
dap is offline   Reply With Quote
Old 09-30-2010, 07:32 PM   #3
berdugo
Member#: 163108
07 EuroDM STi 2.5L
berdugo is offline   Reply With Quote
Old 09-30-2010, 07:55 PM   #4
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
unless you expect to see 40+ psi I would go with arp L19's,14mm require lots of work on the block and heads,I don't know if its the same for p&l 13 mm also.
john 1badSTI is offline   Reply With Quote
Old 09-30-2010, 11:23 PM   #5
mtcs
Member#: 180640
I forgot about Roger Clark head studs...
The block just came back from darton and hasn't been assembled yet. So I don't think it should be too bad tapping the block for the studs. I know the P&L kit comes two taps. One for starting and one for the bottoming. the head on the other hand might be a little trickier but I rather be safe than sorry.
Old 09-30-2010, 11:40 PM   #6
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
you know, i had a ppg 1st gear break on me just outside of break-in and ZERO launches (not even slipped launches) when i was only making 340wtq. does this mean that i should never trust a ppg gearset, do you think it means that either there was a build quality issue in just that particular set, or maybe it was an install issue when the gears were installed in the case? my point is that ARP is correct in stating that sometimes there are freak things that happen when manufacturing things in large quantities (and sometimes even small quantities). sometimes things just break when they shouldn't. i see it all the time on aircraft engines. we could have a bad part, order a new one, and then find out that the new part is bad right out of the box. does that mean we should find another manufacturer? not necessarily...obviously if it happens more than not, it is a problem, but most the time it is just one of those things that happens.
amalgrover is online now   Reply With Quote
Old 09-30-2010, 11:49 PM   #7
mtcs
Member#: 180640
I just don't know if the std arp studs are up to the task of keeping the heads on the shortblock when I start raising the boost.
Old 10-01-2010, 12:01 AM   #8
amalgrover
Member#: 183480
2009 Forester XT
i haven't had any problems running 28psi with an fpred...14,000miles strong right now...
Old 10-01-2010, 02:01 PM   #9
mtcs
Member#: 180640
I forgot about AMR's 9/16 big boy head studs. Thing is though, they are as expensive than the Rigoli 14mm studs...
Also, apparently these don't taper at all.
Any idea if the other brands use a taper or not?
Old 10-12-2010, 01:56 PM   #10
cnstman
Member#: 9548
2004 WRX STi
PSM, 10.741 @ 126.29
how much boost / hp do the standard arp head studs typically support before head lifting becomes an issue?
cnstman is offline   Reply With Quote
Old 10-12-2010, 02:06 PM   #11
hobbesnapoli
Member#: 221436
02 WRX vf39
plenty... when's the last time you heard otherwise?
hobbesnapoli is offline   Reply With Quote
Old 10-12-2010, 02:27 PM   #12
mtcs
Member#: 180640
The STD ARPs don't fail too often. The only reason mine failed was because apparently I had one freak stud.
Ive seen cars making over 600wheel and still using the 11mm std stud.
Old 10-12-2010, 02:57 PM   #13
cnstman
Member#: 9548
2004 WRX STi
That is what I thought.
Old 10-12-2010, 04:45 PM   #14
Prevent
Member#: 149114
sometimes **** happens..
i have ARP 2000's
Prevent is offline   Reply With Quote
Old 10-12-2010, 04:48 PM   #15
alcoolaid
Member#: 134949
'07 SWP STi
Twinscroll ViPec Anti-lag
Im using the std arp studs as well.
alcoolaid is offline   Reply With Quote
Old 10-12-2010, 05:36 PM   #16
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Contact AMR in Mamaroneck, NY. They have some beefy studs they manufacture in house
PhatBotti Tuning TKR is offline   Reply With Quote
Old 10-12-2010, 06:44 PM   #17
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
turbo record holder 11.4
Get the P&L Kit you will not regret it.. I have used them on the last 5 motors we have built. They work awesome and are a quality arp2000 stud with ARP hardware. They also come with the taps needed install them.
I have them in my own motor and so does OverBoostin. I know they are used in the P&L drag STI, drag GC, Fast Eddies 139mph street car and a few other very fast cars.
Jr
Junior2JZ is offline   Reply With Quote
Old 10-12-2010, 06:46 PM   #18
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
FWIW, I don't think you can run a OEM block dowel with the 14mm kits. If you can you will have to machine them down to nothing to fit the stud through them. I wouldn't feel to great about not having block dowels..
Old 10-13-2010, 03:45 AM   #19
STIV6
Member#: 27458
2003 STI
STIV6 is offline   Reply With Quote
Old 10-13-2010, 07:44 AM   #20
tuspace
Member#: 57959
1998 GC WRX
Red
^^^^ PBMS and the other ones I can think of are PMS (Perfourmance - http://www.pms.net.au/ )
tuspace is offline   Reply With Quote
Old 10-13-2010, 07:26 PM   #21
mtcs
Member#: 180640
Well, im going against my better judgement and am cutting a corner. I don't really want to waste anymore time waiting on machine shops to complete a tap/helicoil or timesert job on an assembled shortblock. If it were just the bare block, then it would be a different story.
So I have decided to go with some 11mm L19 studs. They have clamping of 260,000 so that should be more than enough for my build. I hope...
Old 10-14-2010, 02:26 AM   #22
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
I'm wondering if anyone thinks standard ARP's will be good for 45 psi and around 700-800whp? lol
project_skyline is offline   Reply With Quote
Old 10-14-2010, 09:28 AM   #23
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
Yea been there by accident. They held on decent, but it did push water even with orings
Jr
let's talk aftermarket subframes Phil Jr. Brakes, Steering & Suspension 165 10-29-2007 07:11 PM
Let's talk head studs/bolts..... bboy Factory 2.5L Turbo Powertrain 43 09-27-2006 05:57 PM
Let's talk aftermarket batteries jblaine Factory 2.0L Turbo Powertrain 6 01-03-2003 12:52 PM
Let's talk heads and bottom end MiXer Factory 2.0L Turbo Powertrain 2 05-02-2002 08:25 PM
Message Board Statistics All times are GMT -4. The time now is 11:38 AM.
