Old 09-30-2010, 11:50 PM   #1
rob17san
Member#: 259519
Default New Member W/ Power Steering Problem 95 impreza 1.8
So my girlfriends car, (1995 impreza L 1.8L Coupe 160k Miles Manual) has been leaking power steering fluid for quite some time now. I bought a rebuild kit for it, and replaced most of the o-rings and gaskets, etc. Put everything back together smoothly, no leaks.
Now, my problem is that the power steering doesnt work? Its real tight when steering. I was curious what I should do from here. I tried everything.
__________________________________________________ __________
TRIED:
Filled it up, and turned the steering wheel to full lock, left and right, over 200 times. Still nothing.
Replaced the hose line clamps on the low pressure line. Nothing.
Drove it 15 miles on the highway, Nothing.
__________________________________________________ _____________
Everything was assembled correctly as far as I know, everything reinstalled correctly, all lines are tight, and the unit holds fluid. It does make a buzzing sound, that I hear could be from air in the system. Everytime I did full lock, the fluid in the reservoir bubbled, but never completely stopped spitting little bubbles while turning the wheel. It does stop bubbling when I don't turn the wheel. I did the full lock (left to right on the steering wheel) over 100 times.
Any Ideas? would a fluid flush also be considered a bleeding if I took it to a shop with the machinery? The pump worked fine before, just leaked. So it shouldn't be a bad pump, and there is very little chance I put it together wrong.
when under the car, when its off, and having the steering wheel turned, the steering rack seems to bubble internally as well.
THANK YOU!
rob17san is offline   Reply With Quote
Old 10-01-2010, 02:19 AM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Possible outer tie rod end is binding. This will cause the rack to work extra hard to try and move the wheels and cause additional noise in the rack.
PhilSine is offline   Reply With Quote
New member looking into getting 93-95 impreza MadeInPhilly Newbies & FAQs 4 10-12-2009 12:35 PM
Diagrams: Underhood Fuse Box Circuit, 95 Impreza 1.8 t3hWIT Electrical & Lighting 0 01-17-2007 07:18 PM
95 impreza 1.8 to jdm ej2.0t help! dooba33 Subaru Conversions 21 05-28-2006 01:50 AM
95 Impreza 1.8 suddenly not running right Impretzle Normally Aspirated Powertrain 14 01-31-2006 06:45 PM
Will a wrx aftermarket exhaust fit on a 95 impreza 1.8 NewbyScooby Normally Aspirated Powertrain 3 05-22-2003 03:32 AM
