Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 10-01-2010, 03:11 AM   #1
dome24
Member#: 111845
97 RUBAsU Tall2dr
04 FXT VF22/COBB AP
Angry Compression Check=OPERATOR FAIL!
SOLVED!! SEE BELOWW
97 Brighton 1.8ECU and electronics-94 2.2 sohc longblock 2.5 years semi-trouble free.
My Front engine seals have been leaking for awhile and last week before i was headed into the shop to fix them 'i figured Id run a quick CC to see if it was even worth fixing the seals if the motor was crapped anyways. It had been dogging a bit lately anyways.
172 165
172 150
After i got the 150 I went backwards back around to check my work and got the same numbers again.
But the wierd thing was on all but the drivers rear cylinder I had a different kinda huffing noise.
I thought about it a bit and reinstalled the plugs, wires and injectors, started it up and it was bucking and chugging and freaking out at idle. CEL was on for a sec then it went out under load and i thought it was ok so I went for a drive, It was a bad idea. CEL starts flashing and going nuts, car is not happy and sounds like @$$
I'm thinking bent or broken valve? but why would the compression still be fine on that cyl when the 150 was the opposite side?
Am I totally screwed? I can turn an wrench and do teh mechanical side of a swap but the dynamics of an internal combustion engine still baffle me...
dome24 is offline   Reply With Quote
Old 10-01-2010, 03:22 AM   #2
dome24
Member#: 111845
97 RUBAsU Tall2dr
04 FXT VF22/COBB AP
I did run cat-less for awhile and am thinking maybe the lack of backpressure helped this failure along?
Old 10-01-2010, 03:39 PM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Sure you plugged everything up correctly? I've forgotten to connect a spark plug wire after a compression test.
Old 10-01-2010, 03:54 PM   #4
dome24
Member#: 111845
97 RUBAsU Tall2dr
04 FXT VF22/COBB AP
Yes, I triple checked my wires and they were all on tight both plug side and coil side.
And on the injectors, j just unplugged them from he harness for the test and plugged them back in after.
Old 10-01-2010, 10:21 PM   #5
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Are you sure you didn't crack a plug when you put them back in? The flat four engine design makes changing plugs a little awkward. If you take them back out look for cracks. Also look for any dark lines on the side of the plugs. It's called carbon tracking and it happen when the spark finds a way to go down the side of the plug instead of through the electrode. If that happens you need new plugs and wires as the arc burns a trail on both that can't be fixed.
Wrencher86 is offline   Reply With Quote
Old 10-02-2010, 12:35 AM   #6
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
ib4backpressurenazis
formula91 is offline   Reply With Quote
Old 10-02-2010, 06:34 PM   #7
dome24
Member#: 111845
97 RUBAsU Tall2dr
04 FXT VF22/COBB AP
OPERATOR FAIL!!!
My tester has a small extension that came off after the first cyl test, that's what te rushing noise was. Installed the plug into the extension instead of the actual head.
Removed the plug and it all came out as one piece, installed new plugs all around and it runs like before. Still ticking and pizzin oil but no more misfires.
Old 10-02-2010, 06:46 PM   #8
181stLeader
Member#: 184183
1996 Impreza RSTi
V8 EJ207 Aerosim Carbon
Yeah that would do it. I cant imagine it would run well like that.
181stLeader is offline   Reply With Quote
Old 10-02-2010, 11:54 PM   #9
grafton
Member#: 187936
07 WRB STi
that's one hell of an "anti-fouler" lol
grafton is offline   Reply With Quote
Need someone to come to me and do a compression check and leak-down test - $$$ mindchatter Rocky Mountains Impreza Club Forum -- RMIC 1 09-30-2010 01:51 PM
STG2: Flashing CEL but no CEL code mvitic AccessPort 1 08-10-2006 09:43 PM
compression check/leak down check tribalwrx Alaskan Impreza Club Forum -- AKIC 13 09-06-2004 09:01 PM
Multiple cylinders missfire, flashing CEL something to check hotrod Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-15-2004 03:01 PM
Flashing CEL vs. Solid CEL Quick WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-15-2003 11:01 PM
