Old 10-01-2010, 04:03 AM   #1
Saintsp
Member#: 249258
Default 102bore
planning to run 102 bore on my 2.7 stroker,anyone on this?What gasket to use?
Saintsp is offline   Reply With Quote
Old 10-01-2010, 05:14 AM   #2
MartinSTi05
Member#: 145145
2006 wrx STi
Used a Cometic MLS gasket on mine with a stainless oring machined into the top of the sleeve. Worked great.
MartinSTi05 is offline   Reply With Quote
Old 10-01-2010, 04:36 PM   #3
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
I ran Cometic as well. In fact there are onnly 2 choices if I remember correctly Cometic and Cossie...
Sinister redlines is offline   Reply With Quote
Old 10-01-2010, 05:33 PM   #4
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
I assume your sleaving this? if not 102mm bore is getting the wall pretty thin.
rexworx is online now   Reply With Quote
Old 10-01-2010, 09:15 PM   #5
Saintsp
Member#: 249258
Yep its sleeve.I thought cossie only comes in 101mm?
Old 10-01-2010, 10:06 PM   #6
sidewayz
Member#: 5810
2001 S366 2.5RS
Brian crower stroker is 102
sidewayz is offline   Reply With Quote
Old 10-01-2010, 11:35 PM   #7
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Pretty thin.. We played around with a spare block to see how far the stock liner can be bored, after 102.XXmm it just peeled back and was useless.
I did a 103mm bore and Used cometics. They were special order and took 2 weeks to get. I would recommend getting 2-3 sets so you wont have down time if you need to tear it down.
Junior2JZ is offline   Reply With Quote
Old 10-02-2010, 02:44 AM   #8
Saintsp
Member#: 249258
Other than cometic?Not really comfortable with cometic.Hows the 103 bore?Is it alot better in term of smaller bore size?
Old 10-02-2010, 10:37 AM   #9
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Gasket wise you can get SCE Titans upto 103mm if you want and you can get the Cometic Phuzion which is 102mm.
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
jkopinga is offline   Reply With Quote
Old 10-02-2010, 01:59 PM   #10
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
SCE Titans are available HOWEVER copper head gaskets are highly recomended to retorque every once in awhile and usually require it. In our cas I dont feel like pulling the engine tearing the timing apart removing the cams every time to retorque. Just me?
Old 10-03-2010, 12:10 AM   #11
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Cosworth will make you 103 gasket.. The Cometics are great gaskets though.
It is a rally car, so the 103mm was used to up displacement and get us more mid and low end TQ
Jr
