Old 06-26-2002, 08:42 AM   #1
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
Question Best camber settings for Auto-x/street?
Who knows what the best camber settings are? I want a better auto-x car without hurting daily driving.
How does this sound?
Front -1.5
Rear -1.0
Patrick Olsen what do you suggest?
HIHO is offline   Reply With Quote
Old 06-26-2002, 10:41 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Man, alluva sudden I've become the Alignment Expert. Two people have PM'd me lately asking for alignment advice, and now HI HO is asking for my thoughts, too. I rule!
OK, I would say those numbers look just fine. What kind of suspension do you have? Do you have rear camber bolts? Rear camber isn't adjustable unless you've added camber bolts, so whatever you get back there you're stuck with. Up front, unless you're running an aftermarket suspension, you probaby won't get much more than about -1.0deg, maybe -1.2deg if you're lucky. If the car is lowered then you might be able to get to where you want it to be.
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is online now   Reply With Quote
Old 06-26-2002, 11:23 AM   #3
HIHO
Member#: 7624
BD5; family sedan
Hey, how many Legacy owners have ran in the One Lap of America? C/D has a good article this month about it. Looks like a ton of fun, but, also very hard.(to stay awake). They have a picture of a Diablo on a dirt oval, interesting to say the least.
Ok back to topic. I have stock suspention so the rear is as is. I will have the front set to -1.0/1.2. I am currently saving for a coilover system. I hope to get it for Christmas from my wife. I haven't read up on the Legacy coilovers yet but I think you have the DMS Golds right? What system do you suggest? PDM has the AGX+Eibach Prokit for $575. I know they are not coilovers but it is a good deal. I need to read up on this subject some more.
Any comments, guys?
Old 06-26-2002, 11:31 AM   #4
froggert
Member#: 768
OB, legacy, 911,
ram 1500, 1098s, m620
i'd go with whatever maximum equal negative camber is obtainable up front, whether it's -1.0, -1.4, or whatever.
what sort of toe settings are you looking at?
froggert is offline   Reply With Quote
Old 06-26-2002, 03:35 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Actually, I did the Open Track Challenge, a different and way cooler event.
What system do I suggest? Not the DMS Golds. I removed mine for good two weekends ago and sent them back for a refund. Too many problems with quality control. Right now I'm looking into either a new set that Rallispec is supposed to start selling soon, or Koni inserts with Eibach coil-over sleeves. We shall see.....
Yeah, that's what I tell the guy at the alignment shop. I should have explicitly said that was what I recommend. So, HIHO, tell them what froggert said. You might end up with just -1.0deg or you might get -1.4deg, it just depends on the car.
As for toe, I run 0 up front and right now I'm running 1/16" out in the rear (to encourage the car to rotate at auto-x events). With the Golds on the car I ran 0 front and rear because I could tune the car's balance with the damping adjustments, plus I was running a mix of open track and auto-x events and didn't want the toe out on the track.
Pat
Old 06-26-2002, 04:55 PM   #6
richeich
Member#: 1353
2001 Impreza 2.5RS
I've got H&R Sport springs, STi Ver5 struts, Cusco front strut tower bar, and SPO Motorsports 3-way adjustable rear sway bar kit for my suspension mods. Last week, before the autocross, I had the alignment adjusted for the first time with autocrossing the main priority. I had picked these numbers off the forum here sometime last year when a similar question came up, and saved them, so I would have a reference point. I'm now running -2.0 deg camber up front, and -1.5 deg camber in the back, with zero toe all around. I must say the difference is fantastic. With the rear bar set at 21mm, the balance is great. Now, I don't have any miles on this setting for street use, so I don't know how bad tire wear will be. I don't expect them to get chewed off immediately or anything. I'll keep an eye on it, though.
Good luck!-
Rich
richeich is offline   Reply With Quote
Old 06-26-2002, 05:00 PM   #7
richeich
Member#: 1353
2001 Impreza 2.5RS
Oh yeah, on the street the improvement is wonderful. On the highway at speed, it's definitely more sensitive to your inputs, but not darty or squirrely or anything like that. I just don't know if you should drive with your knees anymore.
Rich
Old 06-26-2002, 06:02 PM   #8
HIHO
Member#: 7624
BD5; family sedan
Oh
Yeah I read some of your post about the problems with the Golds. I have also read some stuff about the Koni inserts. A bunch of WRX owners love them. Well whatever you do please keep us informed. Hopefully by the begining of next year I will have an idea of what works.
OK I will tell Gene the most negitive up to -1.5. I have read that
-2.0 will cause uneven tire wear.
Rich, please let us know how the -2.0 wears.
Old 06-26-2002, 07:11 PM   #9
froggert
Member#: 768
OB, legacy, 911,
i've been running -1.6 degrees up front and 0 toe and have been wearing the outer edges of the tires faster than the inner ones.
toe, tire pressures and rotation are going to be major contributors to uneven tire wear as well.
Old 01-21-2003, 09:43 PM   #10
richeich
Member#: 1353
2001 Impreza 2.5RS
Heh heh...
I was doing a search for something else, and came across this old thread. Just wanted to update everyone on my tire wear. They actually wore on the outside edge faster. I would say this is from the autocrosses. I ran about 6 events, 8 runs each, on a large concrete surface with this alignment. Our courses are usually pretty open, with higher speeds (needed 3rd gear a few times). Anyway, the tires are fine, other than the abuse I've heaped on them. Other than the outer edges, tire wear has been even. There is no cupping or weird wear patterns on the tread. I've put approximately 10k miles on the alignment, with a total of about 13k on the tires. I'll be able to get through the first one or two events this spring with them before they need replacing.
Rich
(And yes, I'm running zero toe, keep up with air pressures, and have rotated them pretty frequently.)
Best camber settings for my '04 WRX wagon Biznessdude Brakes, Steering & Suspension 7 12-30-2005 05:47 PM
Prodrive or OEM: Which is best alignment setting for street dman918 Brakes, Steering & Suspension 11 10-20-2004 12:51 AM
camber settings for FWD L DoinkMobb Brakes, Steering & Suspension 5 08-12-2004 12:10 PM
Anyone know the stock camber settings for our cars? gtguy Legacy Forum 7 02-06-2001 07:21 AM
Stock camber settings for Legacy GT? gtguy Brakes, Steering & Suspension 0 02-04-2001 09:49 AM
