Old 10-01-2010, 03:13 PM   #1
grafton
Member#: 187936
07 WRB STi
Default semi-balanced internals?
I am in the final stages of prep before my high compression build:
ej251 honed to 3.9180" on all four cylinders
4 New oem "A" pistons PTW clearance is in the standard range for all 4
new ACL race main & rod bearings
sti 10mm oil pump
MY95 EJ22e dual port heads gasket match intake port and polish, ~1mm port and polish to exhaust side, short side radius and bowl work on IN/EX
New valves
Delta 200 grind cams
Solid lifters
Lite weight crank Pulley
my question is how closely are the stock internals balanced?
the closest i can get it is within 0.3g on one set of cylinders
the way i believe it should be set up:
#3 1162.8g - #4 1163.1g <- 0.3g off of each other
#1 1163.2g - #2 1163.2g
thoughts, suggestions, different piston/rod combo's?
grafton is offline   Reply With Quote
Old 10-01-2010, 03:21 PM   #2
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
have you measured the pistons and rods seperately? Swapping around pistons and rods may yield results closer to what your lookin for, if you havent already.
rexworx is offline   Reply With Quote
Old 10-01-2010, 03:36 PM   #3
grafton
Member#: 187936
07 WRB STi
yeah that's the closest i could get, the FSM says nothing about weighing pistons & rods i just want a smooth as possible motor using what i've got.
because i forgot to add it in the first post:
pistons:
P1 545.4g
P2 545.2g
P3 545.5g
P4 545.4g
rods (id'd via engravings)
LV 617.3g
LW 618.0g
LZ 617.7g
MC 617.8g
combo's
rod-piston
LV-P3 1162.8g
LZ-P1 1162.1g
MC-P4 1163.2g
LW-P2 1163.2g
Old 10-01-2010, 05:10 PM   #4
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
holy crap justin, you almost sound semi intelligent.
heheheh
imo .3 is close enough unless you are going to turn really high rpms
gald to see its coming together
nhsilversti is offline   Reply With Quote
Old 10-01-2010, 11:38 PM   #5
grafton
Member#: 187936
07 WRB STi
heheheh
rofl, thanks ted, did all the final tolerance checks today, assembly begins tomorrow. The motor wont spin past my lovely stock red-line of 6250, Just looking for every little gain i can make with what i've got to work with.
Old 10-02-2010, 11:34 AM   #6
DSM_Outback
Member#: 56345
93 Swapped L
Green
Nice, try adding rod bearing weights too.
Most of the phase II cranks I've spun up were within a couple grams front to back.
DSM_Outback is offline   Reply With Quote
Old 10-02-2010, 12:14 PM   #7
grafton
Member#: 187936
07 WRB STi
the crank is a cobb balanced, from a 2.0 stroker kit
i was more worried about my used rods/new pistons&rings
its going together this afternoon, this whole motor building thing is fun but i wouldn't want it as a day job
Balancing Rotating Assembly and or Internals only???? jaironsti Built Motor Discussion 14 09-03-2012 12:51 AM
Balancing Internals elsuicida New England Impreza Club Forum -- NESIC 12 01-18-2010 10:24 AM
Recommendation for a shop to balance engine internals. not8player Tri-State Area Forum 0 05-31-2006 05:53 PM
US ej20, internal or external balanced? motorcitywrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-16-2003 02:44 PM
