Old 10-01-2010, 05:25 PM   #1
polskaboys
Member#: 221147
2011 STI LIMITED
WHITE
Default 272 cams etc let me know what you think
Im purchasing this for my Hybrid build... this weekend
2.5 brand new shortblock with Wiseco 99.5 mm pistons (STD bore)
11mm oem oil pump
oil cooler
BC 272 cams
Cosworth valve springs set
looking for the right head gasket kit (help)
an any imput will help this is all going into a 2004 wrx
currently ill be runnin a vf39, dw750 injectors, walbro 255fp injen cold air intake, injen fmic, hks exhaust an dp. will upgrade parts once the funds come in
polskaboys is offline   Reply With Quote
Old 10-01-2010, 05:30 PM   #2
rexworx
Member#: 103232
MY05 GDA, MY04 FXTI
2.5ltr,PPG,Front LSD,4.44
IMO BC's arent nearly as aggressive as advertised and most people think.
What are you trying to figure out? What do you do with the car? What kind of powerband are to looking for? "now and down the road"
rexworx is offline   Reply With Quote
Old 10-01-2010, 05:31 PM   #3
sense of nature
Member#: 112759
02 Srp STi...
R ur Boltz to long????
Oem gaskets are the way to go IMO .. You could use the 1996-1998 EJ25D gaskets & help lower the compression a bit
If you can get the GSC cams they are a much better cam IMO ...
sense of nature is offline   Reply With Quote
Old 10-01-2010, 05:39 PM   #4
polskaboys
Member#: 221147
2011 STI LIMITED
WHITE
Just seeing if im heading to the right direction with this build. ill be happy to make 300hp or more for now till i upgrade the trans an go with a bigger turbo down the road, reason for doing this swap is i just spend 6 grand on a rebuild that didnt last 1200 miles cause the shop FAILED. what would be the ratio going oem gasket? wouldnt the higer ratio cause more det?
Old 10-01-2010, 07:57 PM   #5
kasra007
Member#: 225361
2006 wrx sti
beige
gsc or crawford.
kasra007 is offline   Reply With Quote
Old 10-01-2010, 10:08 PM   #6
sidewayz
Member#: 5810
2001 S366 2.5RS
Bc cams are fine but are more like 264's
sidewayz is offline   Reply With Quote
Old 10-02-2010, 02:19 AM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
OEM HG. Search for Cometic HG failures here. I bet you find at least as many as stock HG failures, and there are THOUSANDS more OEM HGs out there than Cometics.
You really do not want to lower compression with the gasket. get the compression back by having a machinist take a few ccs out of your heads by moving the sides out to ~99mm or with piston dish if you don't already have pistons.
Concillian is offline   Reply With Quote
First log, let me know what you think and whats going on. wrxracer519 Open Source Reflashes 5 01-09-2008 01:51 PM
I think I'm done! At least for now! Let me know what you think. VajraTLR Member's Car Gallery 29 10-20-2006 01:20 AM
check out my car and let me know what you think socal Member's Car Gallery 69 04-30-2002 05:53 PM
MY98 OBS pics...let me know what you think! IMPREZAmike Member's Car Gallery 6 06-21-2001 11:18 AM
Let me know what you think Naturally Aspirated New England Impreza Club Forum -- NESIC 17 06-21-2001 08:11 AM
Message Board Statistics All times are GMT -4. The time now is 07:10 AM.
