Old 10-02-2010, 02:02 PM   #1
subiman2005
Member#: 151686
2004 GTP Comp G
99 Legacy Sold
Default Hard Start Issues after sitting 20min
Hey guys having this problem of when the car is warm but has sat for around 20-30 min it turns over 8 to 10 times before it will fire and seems to be flooded which is weird. I have replaced cam crank and temp sensor and still have the same issue. It starts normal when it is cold and when it is hot and has been running in the last 10 min or so. The only other thing I can think of is a leaking injector. Any thought?!!! 99 Legacy Phase II ej22
subiman2005 is offline   Reply With Quote
Old 10-03-2010, 02:39 PM   #2
sol_tegra
Member#: 259406
02 WRB WRX
no MIL? check your fuel trim as well.
you may have a spark problem as well!
sol_tegra is offline   Reply With Quote
Old 10-03-2010, 09:15 PM   #3
RaineMan
Member#: 256727
2007 2.5I Wagon
Probably fuel related... it doesn't take nearly as much fuel for a warm start as it does for a cold start.
RaineMan is offline   Reply With Quote
Rough initial idle and hard start problem after injector install Tronner Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-23-2009 09:32 AM
Hard start issue in '94 EJ22, any ideas? Subarutex North West Impreza Club Forum -- NWIC 11 12-25-2007 06:13 PM
hard-starting wrx after Stage 1 AccessECU chipster Engine Management & Tuning 12 01-02-2004 06:37 PM
Hard start issues. kevin02rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-07-2003 06:17 AM
Car not starting well after sitting for a day... heat? New battery? remarcable Normally Aspirated Powertrain 17 07-13-2001 05:34 AM
