Old 10-02-2010, 02:11 PM   #1
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Default WRC Turbo Placement
Anyone know what's up with the WRC car turbo placement? I know it partly helps them in lowering the center of gravity, but I'm just wondering if it benefits anywhere else?
Any thoughts?
u2_m4r1n3 is offline   Reply With Quote
Old 10-02-2010, 02:30 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
They put them there so everything can be serviced easily. They need to be able to get the trans out as quickly as possibly and change turbos as quickly as possible.
Old 10-02-2010, 02:43 PM   #3
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Hence why there is probably no practicality to it, as far as a wide market of turbo set-ups?
So other than that, there is no real benefit then. Well... that was more simple than I thought. I thought there was a lot more to it, lol. Being that the up-pipe and DP were basically straight to it, seemed like it might help performance, but IDK, more of just a guess.
Old 10-02-2010, 02:48 PM   #4
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
I believe it actually lessens the amount of turbo's you can mount.
You have more room , but not al turbo's like having their center cartridge rotaded almost 90 degress.
Dutch Scooby lover is offline   Reply With Quote
Old 10-02-2010, 02:53 PM   #5
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Oh, well, so really it's just not a great idea in general... unless you have that turbo, lol. I wonder what turbo that is, it's gotta be expensive.
Old 10-03-2010, 01:24 AM   #6
phlegmon
Member#: 26223
2012 GTR - on E85
07 STi twinscroll XTR
The Subaru WRC turbo used to be (and may still be) an IHI RX6 variant. Last one I saw (rebuilt) listed for $12,000 That's not a typo... twelve thousand dollars. That's for a USED (albeit rebuilt) turbo!
Keep in mind, the WRC turbos use MarM 247 (an exotic superalloy that costs ridiculous money- think $2000 plus for just the turbine shaft) and have speed sensors in them. No boost gauges... they are regulated by the actual shaft speed (think 100,000rpm+).
As for the horizontal placement, the WRC turbos were typically replaced after every rally. A normal car turbo has to live 100,000+ miles. If your turbo was placed like that, it would be puking oil/dead in no time flat. When you replace (rebuild) your turbo every 100 miles or less, you can afford to position it in any way you like. I'm sure horizontal placement was advantageous for weight, convenience, performance or a combination thereof.
phlegmon is offline   Reply With Quote
Old 10-03-2010, 08:23 AM   #7
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Haha... holy cow! 12k.
Well. that's some good info right there, thank you for that; definitely all makes sense now. Just crazy the stuff they do in these cars and the abuse it takes!
Old 10-03-2010, 02:25 PM   #8
MartinSTi05
Member#: 145145
2006 wrx STi
Yep, I think things would be different with our cars if we had their budget and time between overhauls.
MartinSTi05 is offline   Reply With Quote
Old 10-03-2010, 04:55 PM   #9
Dutch Devotion
Member#: 145985
A placement like this also allows you to be plumbed up to your airbox directly, mounted in the location whare the tmic for road going cars use to be , think there benefits to do so as well !
Dutch Devotion is offline   Reply With Quote
Old 10-04-2010, 01:05 AM   #10
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
SO.... unlimited funds is what I need...
Old 10-04-2010, 01:33 AM   #11
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Or plumbed directly to the hood scoop and deletes having a bend off the exhaust housing on the down pipe.
methaddict is offline   Reply With Quote
Old 10-04-2010, 11:37 AM   #12
al82
Member#: 177913
2011 WRX STi PBP
I would think spool time. The exhaust flow has less bends than over the engine....the shorter distance the exhaust flow has to travel the more spool time you would have...idk
al82 is offline   Reply With Quote
Old 10-05-2010, 05:12 AM   #13
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Header pipework is reduced to a minimum as are all the bends of the up and downpipe. As mentioned before don't expect the center cartridge to like this kind of angles.
Prodrive uses Mar-M 247 for the shafts and turbine wheels. The turbine house itself is made of inconel as is the entire exhaust manifold. The air/fuel intake directly to the headers can be seen where forced air from the turbo is fed directly into the headers together with a nice squirt of fuel which goes BANG in the up-pipe. You can imagine the amount of mayhem going on in there. Not to mention they run almost 4 Bar (60 PSI) at the low RPM to have more than 700Nm of torque at 3k revs. Uptop ofcourse there's almost no boost available as it's heavily restricted with the 34mm restrictor.
Due to this the WRC cars have an almost flat HP curve. They use extremely high boost to max out the air flow of the restrictor at the low end and continue to do so at the high end which means very little boost. Ignition timing can be as low as 5 degr. when full boost hits and upto 30 degr. at the high end.
Regarding the turbos price it comes in at around 15k pounds for a new one!!
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
jkopinga is offline   Reply With Quote
Old 10-05-2010, 06:03 AM   #14
Prevent
Member#: 149114
I would say easy access to it or parts around the turbo
Anyone have any idea what fuel they use?
Prevent is offline   Reply With Quote
Old 10-05-2010, 06:38 AM   #15
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
102 Octane is the maximum permitted octane in the WRC.
Jasper.
Old 10-05-2010, 08:31 AM   #16
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
Now, that's a really good explanation. Must suck to be as limited as they are. But don't they also run like 8 injectors, rather than our normal 4? that turbo and engine is insane!
I'll be really happy when I can be pushing 350 to the wheels.
Old 10-30-2012, 06:19 PM   #17
pooster.online
Member#: 120461
2004 WRX STi JBP
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
Thought you guys might want to read the article by Eric Hsu detailing the fuel/uppipe "rocket"
http://www.motoiq.com/magazine_artic...preza-sti.aspx
pooster.online is offline   Reply With Quote
Old 10-31-2012, 12:29 AM   #18
WhatTurboLag?
Member#: 243992
2006 WRX TR
Tr30r Aswell
WhatTurboLag? is offline   Reply With Quote
Old 10-31-2012, 05:53 PM   #19
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
I work with an ex- WRC Subaru mechanic. He was on the team in 2001 and 2002. I showed him the thread and he said the placement makes it easily serviceable. He said a swap occurs in 10 minutes MAX!
ckyguy68 is offline   Reply With Quote
Old 10-31-2012, 11:23 PM   #20
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
sick antilag setup!
Bariga is offline   Reply With Quote
Old 11-02-2012, 09:57 AM   #21
derkahn
Member#: 123160
05 obxt
gtx3071r e-85 wagon
That rocket article is awesome... I wish more articles like that were floating around... like how about the local boys... vermont sports car.. going through every little bit and bob they have on their motors... The rocket is awesome... but.. if rumors are to be believed won't we just be able to spool up our electric assisted turbos soon ?
derkahn is offline   Reply With Quote
Old 11-02-2012, 03:00 PM   #22
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Beat me too it lol.
yeah that things basically a friggen turbine engine. Id assume you dont want that up pipe bent too much so it can do what it needs too. But im no rocket scientist
wrxsubiemod is offline   Reply With Quote
Old 11-02-2012, 03:59 PM   #23
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Moore Performance has a few cars with a very similar turbo placement. The owner Ryan has an oiless comp turbo so thats not an issue. My setup will be like his also. Less bends in the uppipe and the compressor outlet goes directly into an air to water intercooler, so the exhaust and after turbo piping length is reduced. I dont happen to have pics, i thought i did.
slowgenius is offline   Reply With Quote
Old 11-02-2012, 06:53 PM   #24
WhatTurboLag?
Member#: 243992
2006 WRX TR
I really like that ihi turbo. I want to really try to get my hands on one
Old 11-02-2012, 09:41 PM   #25
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
You can contact this company,but be prepare to spend
http://www.subaruwrcspares.com/11.html
Price list
http://www.subaruwrcspares.com/35.html
Jura
jura11 is offline   Reply With Quote
eBay: 04 wrc turbo & 96 sti turbo M E R C U R Y Engine/Power/Exhaust 0 11-20-2007 10:16 PM
serious, serious issues... need help ASAP with turbo placement silentt Normally Aspirated with bolt-on Forced Induction Powertrain 25 09-03-2007 06:53 PM
a bit of the old radical turbo placement? sick1.8t Off-Topic 88 06-07-2004 02:27 PM
STi / WRC turbo wrx182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 04-11-2002 11:57 AM
WRC turbo detonation..possible in aftermartket? DoctorNick Normally Aspirated with bolt-on Forced Induction Powertrain 13 12-16-2001 02:55 AM
