Old 10-03-2010, 03:48 AM   #1
Cervantes
Member#: 219252
2000 STi w/S203 swap
Default need help identifying loud engine noise
had my midpipe and downpipe installed yestrday. today, while i was driving, i started hearing a hum, then after a while a rubbing noise, then a clicking sound, than a loud banging sound. this was all within an hour and a half. when i come to a complete stop, the car want to die. here is a video:
Cervantes is offline   Reply With Quote
Old 10-03-2010, 03:50 AM   #2
Cervantes
Member#: 219252
Old 10-03-2010, 10:08 AM   #3
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Bye Bye motor. Spun rod bearing maybe? Whatever it is, it's not good and I'd recommend that you do NOT start up your car anymore, you'll just do more damage.
Pretty legacy though.
Frogsthatmoo is offline   Reply With Quote
Old 10-03-2010, 10:31 AM   #4
Cervantes
Member#: 219252
someone else said the same thing...spun rod. they said it can be fixed, but its going to be expensive.
thank you, glad you like it...i just hope i can bring it back to life
Old 10-03-2010, 12:39 PM   #5
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
sounds super loud.... hmm after exhaust installation?
remove exhaust and see if the sound is still there... it does sound like a bearing/rod issue though... but if it was fine before the exhaust.. mm :|
oil level do you ahve it? What kind were you running?
kirbykirb is offline   Reply With Quote
Old 10-03-2010, 08:17 PM   #6
Cervantes
Member#: 219252
im running royal purple
Old 10-03-2010, 08:22 PM   #7
Cervantes
Member#: 219252
the reason im not too sure about the spun bearing is that i just had the pipes put in...it just seems to make more sense since i just changed my oil
Old 10-03-2010, 11:28 PM   #8
Cervantes
Member#: 219252
yeah...my engine is done....just got back from the mechanic...
p.s. thank you
Old 10-04-2010, 10:08 AM   #9
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
after a downpipe install? who did the work? did they take it for a "test drive"?
don't let him rebuild it, just go for a swap.
LatentWagen is offline   Reply With Quote
Old 10-04-2010, 10:46 AM   #10
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
You're welcome, sorry about your car :-(
Time to upgrade the internals while you're in there!
Old 10-04-2010, 10:57 AM   #11
Cervantes
Member#: 219252
i'm thinking it has something to do with the oil cooler i had....itt probably didnt allow the oil to flow properly
Old 10-04-2010, 10:58 AM   #12
Cervantes
Member#: 219252
i thought about putting a different engine in there and doing some upgrades, but i just want to get it fixed...it had some serious balls already before it died. 280hp stock...i had an intake, TBE, boost controller, and some other stuff done to it.
Old 10-05-2010, 01:56 AM   #13
rougeben83
Member#: 115154
2005 Outback XT
White on grey
ej207 (jdm sti) or ej257 (usdm sti) for the extra displacement?
rougeben83 is offline   Reply With Quote
Old 10-05-2010, 07:14 AM   #14
Cervantes
Member#: 219252
i would have to do more searching around, but im just trying to get it on the road again
Old 10-06-2010, 06:47 PM   #15
LatentWagen
Member#: 50315
if we get them over here for decent money on ebay, im sure you can find a good replacement motor for your car for a fraction of what an engine rebuild would cost you.
need help identifying this engine... Vizzionz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-01-2010 11:47 PM
Need help identifying a noise in the right rear cnk Brakes, Steering & Suspension 14 02-03-2005 03:59 PM
Need help identifying noise PoopRSkupe Brakes, Steering & Suspension 1 09-21-2004 06:56 PM
Need help identifying noise (Not a normal noise) jarelee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-17-2004 04:34 PM
Need help with an engine noise! blkscooby Newbies & FAQs 0 09-29-2003 10:56 PM
