Old 10-03-2010, 03:14 PM   #1
50trim
Member#: 239826
2004 wrx-Hybrid :)
Default Oil Leak Help Pic Inlcluded!!
hey whats up nasioc for awhile now my wrx has been leaking oil. i brought it subaru and they said it was my valve cover gasket. i got it changed and i still keep an eye on it and i think it still leaks alot through the gasket i have included a picture to show you guys to see if it would help
i started the car up and about 2 minutes later it started to accumilate oil in the corner of the valve cover gasket which you can see in the picture. it builds up on the corner of it and drips from there any suggestions? or maybe something else it might be? thankss
50trim is offline   Reply With Quote
Old 10-03-2010, 03:15 PM   #2
50trim
Member#: 239826
2004 wrx-Hybrid :)
o yeh and i forgot to mention this is a hybrid motor as well i have a 2009 sti block and stock wrx heads if that makes a difference just wanted to throw it out there
Old 10-03-2010, 06:45 PM   #3
50trim
Member#: 239826
2004 wrx-Hybrid :)
anyoneeee
Old 10-03-2010, 07:02 PM   #4
fobiawrx
Member#: 91074
04 sti
white
check the plastic half-moon pieces on the back of the head. they get it some times putting in a up pipe and can crack and leak.
fobiawrx is offline   Reply With Quote
Old 10-03-2010, 07:38 PM   #5
50trim
Member#: 239826
2004 wrx-Hybrid :)
i have stock uppipe soo would that be outa the question?
Old 10-04-2010, 06:46 AM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
check all valve cover bolts..half moons as mentioned prior.
but on driver side head...no oil lines..so valve cover gasket..
Old 10-04-2010, 07:53 AM   #7
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Same as above. Perhaps add some RTV silicon to the gaskets next time for better sealing although it shouldn't be necessary if properly torqued.
Cheers,
Jasper.
jkopinga is offline   Reply With Quote
Old 10-04-2010, 09:25 AM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
spray down that oil with brake cleaner. ALL of it. spray the sides, top, and bottom then start up the car and watch.
FuJi K is offline   Reply With Quote
Old 10-04-2010, 06:06 PM   #9
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
bingo
nhsilversti is offline   Reply With Quote
Old 10-04-2010, 06:29 PM   #10
50trim
Member#: 239826
2004 wrx-Hybrid :)
ok cool yeh ill have to look at the half moon pieces is there a possiblitily that the guy at subaru didnt do the job well? its under waranty so ill bring it back to them and have them do a new gasket again and see what happens and ill ask them about the half moon pieces thanks for all the support guys and girls
Old 10-04-2010, 07:06 PM   #11
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
What he said ..
sense of nature is offline   Reply With Quote
EJ22T Built motor oil leak w/pics mikescar Built Motor Discussion 7 08-08-2009 09:31 PM
Oil Leak Help Help Help blackbeast Built Motor Discussion 3 05-25-2007 10:22 AM
Oil Leak!!! W/ Pics Please Help! brando3wagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-30-2006 06:22 PM
Oil leak, help needed msdavis4 Service & Maintenance 6 12-22-2003 02:38 AM
Oil leak... help! ElDuderino Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-28-2002 05:14 AM
