Old 10-03-2010, 04:50 PM   #1
submaster08
Member#: 218016
2002 subaru WRX
white
Default 02 WRX Wagon HYBRID Build. 2005 Legacy Block+02 2.0 Heads
Car- 2002 Wrx wag 126k on chassis
Engine- 2005 Legacy GT Turbo shortblock, legacy internals, new rings+bearings
2.0 Wrx heads
Stock Turbo
Catless up/dp stock catback
tial 38mm/ e cut out off dp
Goal- Daily RELIABLE driver with nice power (drive 300+ miles a week)
Would like to get tuned by EastCoast Swappers when finished
Headgasket- .050 Metal 3 layer head gasket
I have never built a hybrid or seen a hybrid motor in person but i have lots of expierence with building all types of subarus. Ive searched on NASIOC for a build with a 05 gt 2.5 block but cannot seem to find any. I was just wondering if anyone out there has done this. I dont know what the compression level is going to be. I do not want to build a crazy motor, would like stock wrx turbo to be used.
I have just started reassembling the motor and will be posting pics up every step.
This is my first hybrid build ANY ANY ANY advice insight does/dont positive negative just say it
Thank you
submaster08 is offline   Reply With Quote
Old 10-04-2010, 05:43 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
your compression should be around 8.8~8.9:1
if you have built other subaru motors before this should
not be a big deal.
Old 10-04-2010, 12:49 PM   #3
theonlygreat
Member#: 65916
1996 Impreza WRX
That turbo will run out of breath quickly on the 2.5. It will be rather torquey down low though.
theonlygreat is offline   Reply With Quote
Old 10-04-2010, 02:45 PM   #4
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
I got the best results by opening up the combustion chambers in the 2.0 heads to match the 99.5mm bore of the 2.5 and using OE head gaskets then took it to the best tuner that I could find.
slowmike is offline   Reply With Quote
Old 10-06-2010, 01:04 PM   #5
submaster08
Member#: 218016
2002 subaru WRX
white
hybrid guys would you suggest using sti turbo?
anyone with numbers or a chart with the stock wrx turbo
thank you
Old 10-06-2010, 04:08 PM   #6
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Hybrid or not a TD04 on anything is worthless.
2.5 with TD04 is horribly mismatched. Just a waste of money. I'd get a VF39 or VF34 if you aren't looking to spend much but something bigger would make more sense.
project_skyline is offline   Reply With Quote
Hybrid 2.0 head/ sti block jwangs14 Subaru Conversions 3 09-18-2009 02:57 PM
Feeler: 2.5 STI Short block and 2.0 heads ryan_west06 Engine/Power/Exhaust 49 04-05-2009 10:04 PM
04 STI Block WRX 2.0 Heads Hybrid HELP PLEASE!!!!! kidwitdawrx Built Motor Discussion 3 11-12-2008 06:39 PM
Swapped 2.5 block useing 2.0 heads. Jumpy from 3k to 5krpm MY2ND04WRX Built Motor Discussion 29 06-01-2007 10:26 PM
2.5 sti block with 2.0 regular wrx heads serious Normally Aspirated with bolt-on Forced Induction Powertrain 21 08-03-2003 12:36 PM
