Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 10-03-2010, 06:14 PM   #1
TT4ME
Member#: 241428
07 Impreza
Default Oil Capacity
The manual says 4.5q. I've put 10k on my 07 2.5i and for each of it's 3 oil changes, it has taken 6.5 quarts.
When I bought it used from a Subaru dealer, it was underfilled almost 2 quarts. I assume they used the book numbers to fill and never checked the dipstick. ref: avoid Lakeland Subaru in Sheboygan, WI.
My car appears stock with the exception of wheels. Was a high capacity pan an option on these cars? Does anybody have pics, links, or a way to identify these pans? The previous owners' father worked at a Subaru dealership.
Thanks for any help.
TT4ME is offline   Reply With Quote
Old 10-03-2010, 06:50 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
How are you determining that it takes 6.5qts? Unless you have some sort of magic oil pan, you're overfilling it.
Old 10-03-2010, 06:52 PM   #3
nairbmik
Member#: 220259
09 2.5i
SSM
Why did you put 6.5 qts in it?
nairbmik is offline   Reply With Quote
Old 10-03-2010, 06:54 PM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
6.5 quarts is WAY too much for an OEM pan. Take a peek underneath to see if it's OEM.
It should look like the bottom right one in this pic.
KillerBMotorsport is online now   Reply With Quote
Old 10-03-2010, 09:18 PM   #5
TT4ME
Member#: 241428
07 Impreza
I use something known as a dipstick. 5 quarts doesn't even wet the tip of it.
Old 10-03-2010, 09:19 PM   #6
TT4ME
Member#: 241428
07 Impreza
Because that amount put my car into operating range.
Old 10-03-2010, 09:33 PM   #7
TT4ME
Member#: 241428
07 Impreza
Can I get any intelligent responses on this forum?
Thanks
Old 10-03-2010, 09:48 PM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I posted pictures above... Check your pan!! An OEM pan is filled to the brim with ~5 quarts. You're WAY over that. I wouldn't even start a car with that much oil in it with an OEM pan.
So here are the possibilities:
1) You have an aftermarket pan and it's filled just fine with 6.5 quarts.
2) You have the wrong dipstick.
3) You have the wrong dipstick tube.
What oil are you using and how do you check the oil; hot, cold?
Old 10-03-2010, 10:13 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Can you provide us enough meaningful information so that we can provide you with intelligent responses? KillerB has pretty much laid out the only options. Well, the other option is that you don't know how to read a dipstick.
I have the old style N/A oil pan (top right in the picture KillerB posted). My stock capacity was 4.7qt. I now use a shorter dipstick (from the turbo oil pan that has a big chunk of the sump missing), so that the oil level is higher in the pan. I only use about 6qt.
Pat Olsen
Old 10-03-2010, 11:47 PM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
First of all, you're an even bigger jerk than I am and that's saying something. Get over yourself and start listening to people like Pat.
Second, you've been shown what an OEM pan looks like. Go look at yours.
Third, the oil requirement for your car is in your owner's manual. It'll say 4.7 quarts.
Fourth, we have an 06 2.5i. It takes exactly 4 quarts to bring it dead center on the dipstick every oil change.
Fifth, you're fracking something up or you have non-stock parts.
Old 10-03-2010, 11:55 PM   #11
msingell
Member#: 153097
2012 CRZ
PWP
double check all the things you "think" you know for certain. maybe theres something you're missing. assume nothing.
tell us your oil change procedure.
^lol ty, youre not a jerk dude. you dont even have to respond to threads in an attempt to help ppl. nor do you have to answer my calls and share in my misery of receiving incorrect parts, which sucks HARD.
msingell is offline   Reply With Quote
Old 10-04-2010, 12:14 AM   #12
nairbmik
Member#: 220259
09 2.5i
SSM
Thanks
Nice going, idiot. Try listening to the advice given to you, and try not to be a bitch who thinks he's entitled to everything.
Old 10-04-2010, 01:12 AM   #13
GT11
Member#: 128002
0000 four door sedan
Poop color
The only option you have left is to do some ken block drifts in a school zone during school hours.
GT11 is offline   Reply With Quote
Old 12-26-2010, 08:33 PM   #14
TT4ME
Member#: 241428
07 Impreza
My first post was errant. It takes 5.5, not 6.5q. It's painted black and has the drain plug in similar/if not the same location as bottom left & right on KillerB's post.
I have almost 15k on my Subaru now. Using 5.5-6.0q hasn't seem to affect anything. +the dipstick level is right where it should be.. I check every 500 miles.
Old 12-26-2010, 08:39 PM   #15
TT4ME
Member#: 241428
07 Impreza
Still confused + I appreciate everybody's help.
Old 12-27-2010, 01:23 AM   #16
subydaddy
Member#: 95977
92 Leggy
If I were you I'd post some pics of your oil pan and dip stick/tube. Then measure the length of your dip stick and the dip stick tube. Post those up and maybe somebody with the exact same car will be nice enough to take some measuremnts of theirs.
I remember back when I had my 06 2.5i wagon it took right around 4 qts, maybe 4.2 qts, I forget the exact number, it's been a while.
You're checking the stick with the engine off right?
subydaddy is offline   Reply With Quote
Old 12-27-2010, 09:49 PM   #17
TT4ME
Member#: 241428
07 Impreza
Yep. I've checked it under almost every condition. Sitting a week/ run for 500 miles in a day/ and everything in between.
Measurement of dipstick is next.
Oil Capacity 2001 GT? eastbaysubaru Legacy Forum 10 02-11-2002 12:21 AM
WRX Mt Tranny Oil Capacity? Imprezer Transmission (AT/MT) & Driveline 2 10-24-2001 11:01 PM
02 WRX rear diff. oil capacity? bikerboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-12-2001 11:00 AM
WRX oil capacity harrydog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-30-2001 07:59 PM
Oil Capacity [Q] Peaty General Forum Archive 8 02-24-2001 12:53 AM
