Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 10-03-2010, 07:26 PM   #1
Tglazed
Member#: 231216
Default Bad Turbo???
I had my car tuned recently and was hitting 16 pounds. I had to take my battery off to change my headlights and now I cant go above 9 pounds of boost. I checked for leaks all over the front mount and there isn't any. I didnt touch anything besides the headlights and battery when I changed my bulbs. Is it time to replace my td04? Help please.
Mods: Fmic (with tial 50mm bov), Short Ram Intake, turbo back exhaust (no cats or resonators), Perrin uppipe.
Tglazed is offline   Reply With Quote
Old 10-03-2010, 07:40 PM   #2
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Tuned with what? You might have to reload the map.
car_cursed is offline   Reply With Quote
Old 10-03-2010, 07:49 PM   #3
Tglazed
Member#: 231216
It was tuned with opensource, sorry should have stated that. I am going to see logan to see if he can reload the map tommorrow to fix it. hopefully it does.
Old 10-03-2010, 08:14 PM   #4
EsubaruJ
Member#: 200008
03 wrx
TE72 wagon, Legacy wagon
Usually when you unhook the battery, that resets the ECU. Seems like you may have found the culprit. As stated above, see if you can get someone to reflash your ECU. EDIT: Stock boost is more than 9psi, so you may have another problem. Maybe your BCS is dead, they sometimes go out randomly. Seems like it could running off the wastegate(7-9psi). You have a restrictor pill right?
EsubaruJ is offline   Reply With Quote
Old 10-03-2010, 09:33 PM   #5
Mush04
Member#: 191705
2007 Limited STi
Swp
I think when you load a base map that is your map even if you disconnect the battery. I've had my battery taken out for the same reason before and it goes back to the map that it was tuned for. but depends how your tuner did it too though maybe. I have a stock bcs if you need to try that and see if that's it. let me know.
Mush04 is offline   Reply With Quote
Old 10-03-2010, 09:35 PM   #6
Anub1s
Member#: 81106
2014 Baby Mobile
Whitey White
Did you make sure your terminals are seated properly? A poor ground connection can make your car freak out in many ways. Take off the terminals, and reseat them to make sure they're all good and on there.
Anub1s is offline   Reply With Quote
Old 10-03-2010, 09:36 PM   #7
Anub1s
Member#: 81106
2014 Baby Mobile
Whitey White
If it's an opensource map, there's no way that a battery disconnection will remove the map or revert it back to stock. It's flashed to the ROM and is permanent until it's flashed again. The only time a map would be removed is if it's a runtime map, and opensource doesn't currently support this. Just for future reference
Old 10-03-2010, 09:39 PM   #8
EsubaruJ
Member#: 200008
03 wrx
^^ Thats what I was thinking too. I wasn't sure how opensorce worked, because I know when you load a realtime map with an AP, when you disconnect the battery it will erase the realtime map. Anyway.. It sounds like its running off WG pressure to me.
Old 10-03-2010, 09:46 PM   #9
Mush04
Member#: 191705
2007 Limited STi
Swp
yeah that's what I belive I heard thanks for letting me know for sure though man! I figured that was the case cause I disconnected it to reset the ecu when I changed out my bcs to see if that was my issue from before haha.
Old 10-03-2010, 10:10 PM   #10
godfather2112
Papi Chulo
Member#: 53794
2005 BMW M3 - 6spd
2007 Denali Land Yacht
Why are you running a fmic with a td04?
godfather2112 is online now   Reply With Quote
Old 10-03-2010, 10:12 PM   #11
Tglazed
Member#: 231216
So you guys thing its the boost control solenoid? Mush if its cool can you pm me your number and we could find a day this week to swap them out and see if that is the problem?
Old 10-03-2010, 10:12 PM   #12
Tglazed
Member#: 231216
I was going to go vf 39 but I decided to sell my car. Its more of a support mod for the future
Old 10-04-2010, 01:31 AM   #13
EsubaruJ
Member#: 200008
03 wrx
The BCS in an 06 may be different than the one thats in an 04. I could be wrong. But it might be something to take into consideration.
Old 10-04-2010, 03:13 AM   #14
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
It could be the rom to some degree, when it gets reset the IAM drops back to 8 or .5 depending on the ecu, less timing will hinder boost building to some degree(depending on how he sets up his maps).... However, i don't think that is whats causing your issues, it's either something mechanical (depending on what you changed) or a tune issue if say it wasn't set up for colder weather etc...
907Bum is offline   Reply With Quote
Old 10-04-2010, 10:24 AM   #15
Not-EWRX
Member#: 158043
2013 Wrx Hatch
This. And if your tuner says different.... You need a new tuner.
Not-EWRX is offline   Reply With Quote
Old 10-04-2010, 12:25 PM   #16
homemade
Member#: 235937
88 supra
ALL: be advised he has a downpipe with a blocked off internal wastegate flapper. in other words its meant for an external wastegate but (last i saw anyways) he did not have an external wastegate.
this means that something is stopping you from hitting max boost. what would that be.
boost control solenoid. but if it cannot open the flapper of the internal gate then how is it stopping from maxing out boost.
homemade is offline   Reply With Quote
Old 10-04-2010, 12:27 PM   #17
godfather2112
Papi Chulo
Member#: 53794
2005 BMW M3 - 6spd
Sounds like anOther ghetto setup?
Old 10-04-2010, 12:32 PM   #18
True Tune, LLC
Vendor
Member#: 259639
We'll be able to tell what is issue is, when he stops by the shop later. The map he has is conservative, with the parameters set to adjust to temp. changes. We have extra BCS's and will be able to diagnose if there is a mechanical issue, which is possible.
True Tune, LLC is offline   Reply With Quote
Old 10-04-2010, 01:34 PM   #19
Mush04
Member#: 191705
2007 Limited STi
Swp
^^looks like they might be the place to go man, depending on how much they are going to charge you.
as far as the bcs I actually am running a 06 sti's stock bcs and took mine off thinking that was my previous issue, either that or I put my stock 04 one back on and have the 06 one sitting at home either way I ran it just fine, should be good if you still want to try that first Tglazed.
Old 10-04-2010, 02:36 PM   #20
True Tune, LLC
Vendor
Member#: 259639
If it's a car we've tuned, and nothing has been changed to the vehicle, check ups are free. We don't want a mechanical issue to be blamed for a bad map. Since we are a full functioning shop, with a mechanic, we'll be able to tell what the problem is. He had some airflow restrictions, with the short ram intake, which could mean a number of items. Unfortunitly, with the FMIC, he can't put the stock intake back on, which would be much better, having the consistant airflow, from the outside, to his MAF sensor. I'll keep you posted.
Old 10-04-2010, 02:42 PM   #21
Mush04
Member#: 191705
2007 Limited STi
Swp
oh right on, sorry I didn't know you guys tuned him.
Old 10-04-2010, 02:44 PM   #22
Tglazed
Member#: 231216
Well hopefully at 2 we can figure it out. If this is logan which I think it is. How muchwould it be to buy a bcs from you guys, you guys said you have some left over.
Old 10-04-2010, 03:20 PM   #23
True Tune, LLC
Vendor
Member#: 259639
We'll swap yours with one we have and see. It won't take long to decipher if it's a mechanical problem.
Old 10-04-2010, 03:22 PM   #24
True Tune, LLC
Vendor
Member#: 259639
No worries
Old 10-04-2010, 08:13 PM   #25
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Or adjust the MRP maf comp table, this will get even intake free set ups dialed in
Bad Turbo? Bad Ringlands? Bad PCV? emsfd125 Newbies & FAQs 33 06-16-2014 07:38 AM
oil in turbo inlet signs of bad turbo? Adrenalinecrisis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-09-2010 10:54 PM
Bad Turbo ? PumpsGOTAWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-26-2004 12:12 AM
Bad turbo! 1fastsube Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-17-2004 04:40 PM
Bad Turbo?..how can you tell? FatCatTurbo Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-26-2003 09:16 PM
