Old 10-03-2010, 08:16 PM   #1
slizanbro
Member#: 158899
2000 OBS swapped
two tone
Default harness questions
Ok, I have looked and cannot seem to locate this exact info. I have a 98 Legacy gt with the 2.5 dohc engine. Bottom is shot. I got a killer deal from a member on here for a same year 2.2 sohc engine with ecu. My question is will my harness work with the 2.2 and the 2.2 ecu.
slizanbro is offline   Reply With Quote
Old 10-03-2010, 09:57 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
According to my FSM, the wiring diagram shows the same schematic for both the EJ22 and EJ25. The pin voltage chart shows the EJ25 having pin #35 assigned for the vent control solenoid and the EJ22 calls it a drain valve. They probably do the same thing. If not, you'll have a CEL for it.
The EGR control valve goes to pin #71 on the EJ25 ECU, but it's not used on the EJ22.
I'm 99.9% sure the EJ22 will run with no codes by simply removing the EJ25 ECU and plugging in the EJ22 unit. The engine harness uses the same shape plugs, so you won't need to change anything there.
The exhaust manifold will be singleport, and different than the EJ25 manifold....you'll need to source one if you don't already have it.
Jay
Old 10-04-2010, 10:41 PM   #3
slizanbro
Member#: 158899
2000 OBS swapped
two tone
thanks for the info. I am searching for a single port as we speak. I appreciate the help.
Old 10-06-2010, 10:44 PM   #4
subarumafia700
Member#: 150288
1998 Impreza Sedan
Dark Green
heres another thought...
look at the intake manifold bolt pattern.. if its the same, just us the dohc manifold on the 2.2l, we have done this a number of times at the shop i work at. car runs like a champ and redlines higher i think.. the 2.2 is like a small block.. you can throw rpms and redlines at it all day long and its not going to complain.
subarumafia700 is offline   Reply With Quote
harness questions TYPE wRx Interior & Exterior Modification 0 11-10-2001 02:30 AM
ECU/Wiring Harness Questions... Herbie Normally Aspirated Powertrain 1 05-01-2001 01:15 PM
4pt harness questions... Blindeye_03 Normally Aspirated Powertrain 29 04-23-2001 08:08 PM
Headlight Harness Question D General Forum Archive 0 03-19-2001 01:26 AM
Harness questions for ChrisF & Andre Vandenburg!!! Bohanan Technical Forum Archive 0 06-15-2000 04:28 PM
