Old 10-03-2010, 09:29 PM   #1
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
Default Front "U-Subframe": anyone taken measurements for the pick-up points?
I have lost access to a truly square table to measure on, for the foreseeable future. I was wondering if anyone had measurements for the 02-07 Impreza/WRX pick up points?
I want to use this as my next welding project. I thought about getting the tubing I will use for the bolt sleeves, weld up the bases, lay them out, measure it up on the OE sub frame, tack it up... test, tweak, test repeat.. etc.
Just checkin' to see if there was a great starting point.
Thanks!
Rob
TXwrxWagon is offline   Reply With Quote
Old 10-06-2010, 09:28 PM   #2
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
sounds good to me, i would love to do the same just ahve not gotten around to measureing and putting on together, but i do have a basic design in my head
seanathanq83 is offline   Reply With Quote
Old 10-10-2010, 02:13 AM   #3
TIGWERKS
Member#: 256615
You mean something like this? (SolidWorks)
TIGWERKS is offline   Reply With Quote
Old 10-11-2010, 03:59 PM   #4
tobylazur
Member#: 150289
2006 SV650N
1972 Travelall
you wouldn't happen to have and .IGES file you'd like to share would you?
tobylazur is online now   Reply With Quote
Old 10-16-2010, 09:34 PM   #5
TXwrxWagon
Member#: 191557
2004 WRX Wagon
^^ what he said! Also in a dork-version/Home Depot version... LOL
Rob
Old 10-18-2010, 11:13 AM   #6
racerfab1
Member#: 91849
04 STi
verynize! I like!
racerfab1 is offline   Reply With Quote
Old 10-18-2010, 11:21 AM   #7
TXwrxWagon
Member#: 191557
2004 WRX Wagon
I think this would be the PERFECT welding practice project. Great for learning all types of welding techniques.
Especially since my front frame rails are tweaked ever so slightly that if they pull any more it will 99% chance over pull, I'd rather make a 1-off piece to shore it up.
If I had access to a TIG I would learn to TIG & do it in ALuminum.
Rob
Old 10-19-2010, 03:44 PM   #8
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Yes, Subaru has. Look in the service manual for datum points to see if it has all the ones you would be interested in.
turboICE is offline   Reply With Quote
Old 10-23-2010, 10:53 PM   #9
Ray cunningham
Member#: 176751
hey tig works, is that your design?
Ray cunningham is offline   Reply With Quote
Old 10-24-2010, 02:37 AM   #10
TIGWERKS
Member#: 256615
yes, first prototype has been made, but will be making a few slight tweaks. Whole unit is cnc bent and laser notched.
Im also 50% done making a jig for for the engine cradle. Will be tubular and have some lasered cnc bent sheet metal pieces as well.
After that rear subframe-
Old 10-29-2010, 08:17 PM   #11
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
xdrian is offline   Reply With Quote
Old 11-01-2010, 05:54 PM   #12
gtasti
Member#: 152036
2004 Sti
ur better off just buying a sub frame from oswald its not that expensive at all
gtasti is offline   Reply With Quote
Old 11-02-2010, 09:58 PM   #13
TXwrxWagon
Member#: 191557
2004 WRX Wagon
^^ gtasti....
with all due respect did you even READ what I said?
I want to use this as a welding project.
$600 shipped is "not that expensive at all"..... what company do you work for? I apparently need to move to Ontario.. because $600 here in Tx is 1/2 a months rent & nearly 2 electric payments this time of year.
The "therapy" of a welding project is priceless.
some people just don't "get" DIY... <sigh>
Rob
Old 11-02-2010, 10:01 PM   #14
TXwrxWagon
Member#: 191557
2004 WRX Wagon
Missed this...
thank you SOOO much for using my post to dodge the NASIOC vendor rules. WTF!!!!
You cannot advertise projects for $$ gain without being a Vendor, Goofus.
I started to ask about your plot/pick up points, but I want nothing to do this this...
step out... bu-bye.
Rob
909 Ontario 2003 Front seats and carpet good condition 150.00 picked up!!!!! Nettalp SCIC Private Classifieds 1 11-15-2007 05:00 PM
Anyone take bump/droop travel measurements for the KW's? BIGSKYWRX Brakes, Steering & Suspension 14 09-19-2007 11:12 AM
04 WRX front seats, 04 STi Carpet-swaybars, misc...local pick-up preferred crystalhelix Private 'For Sale' Classifieds 14 03-29-2005 03:54 PM
New Kaminari front lip $150 for local pick up Reservoirdog Texas Impreza Club Forum -- TXIC 11 09-03-2003 03:20 PM
Anyone taken classes at the bartender school in arlington??? VSM EXtasy Mid Atlantic Impreza Club -- MAIC 9 05-20-2003 06:08 PM
