Old 10-03-2010, 10:16 PM   #1
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
Default Idle solenoid flow (02 WRX) compared to throttle body?
Hiya folks,
Looking to see if anyone knows how much (max) volume the idle solenoid (ISC) of a 2002 WRX will flow when compared to the throttle body? Clearly, it's a sizeable difference, but what I'm looking for is something like:
the solenoid will flow x% of the volume of the throttle body.
The reason is that I'm looking to use the ISC as the entire volume of air for an anti-lag setup, but need to ensure that it flows enough air (15-20%) so that I don't need to mess with cooking up a tune that has the throttle plate open (at 15-20%) all of the time. The ECU I'm using allows me to use the same solenoid that's use to control idle to control air bypass for anti-lag... just need to know the volume.
Anyone ever done a flow comparison?
-Eric
Geek Guy is offline   Reply With Quote
Old 10-04-2010, 05:35 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
idle air control valve...
it right on top of your throttle body..
Old 10-04-2010, 08:50 AM   #3
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
It's almost certainly not capable of enough flow for anti-lag use. All the AL setups i've seen used a solenoid of some sort that bypassed the throttle body.
CKxx is offline   Reply With Quote
Old 10-04-2010, 09:45 AM   #4
Geek Guy
Member#: 8151
2002 WRX Rally Car
Well, maybe not for max flow and effectiveness, but I'm curious if anyone has done the flow test.
I'm trying to figure out if it's worth my time to get a linear solenoid, rig it up to the cruise control spot on the throttle plate, add relays, etc. or to just do the 'easy' way and use the stock air bypass.
Old 10-05-2010, 01:42 PM   #5
Geek Guy
Member#: 8151
2002 WRX Rally Car
Just curious if anyone else has any input on this issue.
Old 10-05-2010, 02:31 PM   #6
WRteXan
Member#: 223894
I've seen IACV DC's ranging from 35-45% on a completely stock motor. I'd figure that's approximately 35-45% of its flow capacity. I guess 'every bit helps,' but I doubt it would be worth it.
Something you might look into is either a DBW conversion or an 06 air injection conversion and finding a way to run the air injection pump on command.
WRteXan is offline   Reply With Quote
Old 10-15-2010, 09:16 AM   #7
Geek Guy
Member#: 8151
2002 WRX Rally Car
So, I got the answer I needed from a fellow competitor.
Just run the ISC as the ALS bypass. It has PLENTY of flow to run ALS effectively.
<burns>Excellent!</burns>
Wanted, IC to Throttle body hose! wRxbeater11 Tri-State Area Forum 0 08-03-2004 06:26 PM
WTB hose from intercooler to Throttle body (stock is fine) instant Canada Region Forum 3 07-27-2004 12:33 PM
WTB: Intercooler to Throttle Body Intercooler hose -=Ice-T=- Private 'Wanted' Classifieds 0 05-28-2004 09:20 PM
Intercooler to throttle body hose L2W Private 'Wanted' Classifieds 2 09-03-2003 03:56 PM
Intakes connected to plenum VS. Intakes Connected to throttle body - opinions pls. JaiMak Normally Aspirated Powertrain 16 10-19-2000 10:04 AM
