Old 10-03-2010, 11:55 PM   #1
Prevent
Member#: 149114
Default Prevents Build, wont change the name again. I promise.
With work cutting hours and being a college student.. Sometimes things don't get done as fast as you hoped.
The parts...
2007 EJ257
Eagle H-Rods
CP 99.75mm 9:1 CR coated skirt/dome
ACL Standard Mains, HX Rods
2009 STi crank nitrided
ARP headstuds
09 11mm Oil Pump
Covert Performance Oil Pickup
Every OEM gasket i would ever need....
Just a simple 2.5L rebuild with new and forged parts. Motor will be ran on a VF39 over winter to break it in and to also wait until the summer blend of E85, when it will be switched to a *possible* VF37/20G hybrid twinscroll on E85.
splitting the block
Damage of the spare block... #4 and #2 both had crack ringlands
For having two cracked ringlands, the cylinder walls were perfect... very minimal skirt wear, much less than the other block i had., cross hatching was very apparent. I'd estimate the motor had 15k miles tops.
got the pistons in the mail (Thanks Real Street Performance)
The Rods, was going to go EJ257 0 mile rods, decided $200 extra was worth the security and weight savings!!
The combo
New 09 crank... worth every penny seeing how nice it is..
The parts
I has coated pistons!! yah great work by Lo-Ko here in Chicago.
Block goes to the machine shop sometime this week, whenever i have a day off work.
Prevent is offline   Reply With Quote
Old 10-03-2010, 11:57 PM   #2
Prevent
Member#: 149114
Too seal the block should i buy subaru's stuff or just use some hondabond? afaik hondabond is plenty cheaper... and is just as good if not better.
Old 10-04-2010, 06:51 PM   #3
mazemonster
Member#: 259877
2005 WRX STI
looks good! im geting ready to rebuild.
mazemonster is offline   Reply With Quote
Old 10-04-2010, 10:44 PM   #4
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
AFAIK this stuff: http://www.permatex.com/products/Aut...sket_Maker.htm
=Fujibond grey. Just don't use it where you should use red.
RicersWetDream is offline   Reply With Quote
Old 10-04-2010, 11:17 PM   #5
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
what size pistons??You have all your bearings yet??subscribed!Is this your first build on a ej257??Looking to learn.
EROCS04SBRUSTI is offline   Reply With Quote
Old 10-04-2010, 11:23 PM   #6
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Zack, I've used Honda Bond in over twenty motors.. It's just as good .. Use it w/ confidence
sense of nature is offline   Reply With Quote
Old 10-04-2010, 11:25 PM   #7
sense of nature
Member#: 112759
SexyRP
DO NOT use any Permatex... speaking from a bad experience. I used the Grey stuff & had a motor spin a bearing in 40 minutes, the stuff never cured even after 2 months of sitting & when it came in contact w/ heat & oil, it turned to jello & got sucked up by the oil pick up ..
Old 10-05-2010, 02:28 AM   #8
Prevent
Member#: 149114
99.75mm
Yes, all bearings are acquired
Nice, looks like i'll have to stop by honda dealership
Anyone have a part # for the red stuff?
o.O
http://forums.nasioc.com/forums/show....php?t=1699876
http://forums.nasioc.com/forums/show...ight=fuji+bond
Old 10-05-2010, 03:56 AM   #9
MartinSTi05
Member#: 145145
2006 wrx STi
I have had nothing but good luck with permatex.
MartinSTi05 is offline   Reply With Quote
Old 10-05-2010, 10:35 AM   #10
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
Did you use too much????
Old 10-05-2010, 01:45 PM   #11
Prevent
Member#: 149114
Anyone know if there is a difference between wrx fuel rails and 07 sti fuel rails? im converting to top-feed. I already have wrx top-feed tgvs that i deleted but i need some fuel rails.....
Old 10-06-2010, 10:49 AM   #12
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
They are the same.
Jasper.
jkopinga is offline   Reply With Quote
Old 10-09-2010, 04:29 PM   #13
Prevent
Member#: 149114
Got a little problem here.
I want to do a hard break in, but i will be on a brand new clutch....
by hardbreak in i mean, for the first 25-50miles it will see no boost. And the motor will be done with the break in at 350miles or less.
Old 10-09-2010, 05:05 PM   #14
Jakubgt
Member#: 233051
1995 SVX
All the parts are gorgeous. Good luck with the build! Post a video when it's done for us.
Jakubgt is offline   Reply With Quote
Old 10-09-2010, 07:39 PM   #15
sense of nature
Member#: 112759
SexyRP
Just don't launch it, that's what does the most damage to the disc, once your rollin you can get in it It should be fine, done it many times b4
Old 10-09-2010, 07:49 PM   #16
MartinSTi05
Member#: 145145
2006 wrx STi
As long as you don't slip the clutch you will not hurt it. All the way off the clutch and tip in
Old 10-12-2010, 12:26 PM   #17
Prevent
Member#: 149114
Anyone know the part # for OEM case bolts, and the two long bolts that attach to the motor and transmission, that stay in the motor.. took them out and realized i wanted to replace. (you can see them in the first pic)
Old 10-14-2010, 12:58 PM   #18
Prevent
Member#: 149114
Got em
800210990 / 800610010 oem.
Car threw P0304 today, Smoke out of oil cap, vacuum lines, exhaust on startup and now P0304. Looks like the time is coming soon.
Old 11-20-2010, 04:21 PM   #19
Prevent
Member#: 149114
I dropped the motor off at the machine shop on the first.
Still waiting for it, should be getting it back tomorrow....
And in other news for the car, motor is completely done. No more driving.
Old 11-20-2010, 10:08 PM   #20
sense of nature
Member#: 112759
SexyRP
Here's a Q we all wanna know..... Who's gonna be the tuner? Andy,Jorge,Jr,AMS? .. I'm sure there is someone else I'm forgetting
Old 11-20-2010, 10:27 PM   #21
Prevent
Member#: 149114
Andy will be doing my tuning, from basemap to break-in and pump. But im kinda thinking about letting Junior tune my car on E85. Both are capable, but Junior just has more "proven" cars in the 11's with E85.
I ran 12.6@ 106mph at the 2009 shootout, for 2011, im shooting for a very low number...
We'll see. Due to availability andy will probably just tune both pump and E85 plus he's been a good friend for several years now.
Old 11-20-2010, 11:36 PM   #22
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
That Jr guy sucks!!!
What are you doing for PTW? Are you going to gear your ring/ptw clearances more toward the e85 or just an all around pump setup?
Junior2JZ is offline   Reply With Quote
Old 11-20-2010, 11:38 PM   #23
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Oh and make sure you measure the big ends on your rods vs the crank and then the bearing gap before you throw a full set of HXs in the motor. You might end up with some very loose clearance.
Jr
Old 11-20-2010, 11:48 PM   #24
sense of nature
Member#: 112759
SexyRP
Really Cuz I thought he was fair to mediocre
How much different is the psw clearances for pump to say race gas?(100 -116 oct) & E85? Looser or tighter? & I thought rings gaps was more dependent on boost levels being run ?
Please enlighten me
Old 11-21-2010, 01:51 AM   #25
Prevent
Member#: 149114
PTW clearance is at .0030" according to CP, they're also coated from Lo-Ko.
Jr
I told the machinist to call me if the clearances were too lose, it was one of the biggest things i emphasized i told him "Hey most eagles run tight for subarus, so here are some HX's let me know if anything is wrong i can order standard" For his domestic motors they've ran looser. But last i talked to him on wednesday everything appears good.
http://forums.nasioc.com/forums/show...0&postcount=13
Is what i was talking about with Eagle's
***ONLY*** the rod end is HX, the crank is STANDARD
Finally got all my parts changed out PIX of damaged goods and car xEclipsE RaceRx Brakes, Steering & Suspension 3 12-31-2004 04:03 AM
Finally got all the state meet pics gjhsu Texas Impreza Club Forum -- TXIC 13 12-15-2003 03:00 PM
I think i got all my parts for a stage 4. Have another $375, do i need anyting else? Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 12-14-2003 06:33 PM
Geek: Finally got all my communications hooked up (ham/CB) Kha0S New England Impreza Club Forum -- NESIC 11 11-21-2001 11:52 AM
Finally got all my toys JS Texas Impreza Club Forum -- TXIC 2 09-28-2001 12:49 PM
