Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 10-04-2010, 01:45 PM   #1
subarumafia700
Member#: 150288
1998 Impreza Sedan
Dark Green
Default 2.2t heads on 2.5l block
hey guys im thinking of putting together a new engine before this winter as my current engine is lacking a little compression, and is knocking something terrible.. i hear that the 2.2 head 2.5 block combo bumps up compression and is still really relyable.
my question is what head gasket should i use?
subarumafia700 is offline   Reply With Quote
Old 10-04-2010, 06:22 PM   #2
renob123
Member#: 41986
'06 STI/'85 Brat
You should use the gasket that would go with the block you're using. I'd get new ones from the dealer, since they have revised the head gasket design a couple times.
Have you read the High Compression Frankenstein thread? If not, you should. You may find that the EJ22T heads are not the best for you. I'm not sure they'd be the best for any setup, honestly.
Jacob
renob123 is offline   Reply With Quote
Old 10-04-2010, 07:52 PM   #3
grafton
Member#: 187936
97 Legacy w/12:1CR
07 WRB STi
cometic makes a headgasket for the na ej22e heads with a 2.5l bore just for the frankenmotors (i've got a set )
grafton is offline   Reply With Quote
Old 10-04-2010, 10:56 PM   #4
subarumafia700
Member#: 150288
1998 Impreza Sedan
Dark Green
have you now?
Old 10-04-2010, 11:29 PM   #5
subarumafia700
Member#: 150288
1998 Impreza Sedan
Dark Green
so i just read the frankinstein thread. and thats kinda what im looking at doing. Only, i have read that using a smaller displacement block with hight displacement heads will drop compression ratio..thus why the ej22t block with the ej25d heads is a popular combo for a low compression turbo build. there is actually a guy with this combo out there thats making like 450whp with this setup, and pushing like 30psi.
My understanding has always been bigger bore smaller head. A local shop used a 2.2l block with 1.8l heads and i think a 2.5l intake manifold and made like 12.5 or 13:1cr
So i kinda wanted to go the same rt only with a bigger block.
Ive read that the ej22t heads only flow a little less then the wrx heads, and they are dual port which is nicer over the single ej22e.
I have what i believe is a set of perfectly fine ej22t heads with low milage, and i need to find an ej25 block that needs like rings maybe. I dont wanna have to go internal if at all possible, other then like rings, thats cut and dry and cheap.
Let me know what you think, im probley going to give this a shot, i dont really have much to loose, i have plenty of time on my hands out here at school, and just about anything would be better then the engine currently getting abused
Old 10-05-2010, 11:01 AM   #6
subarumafia700
Member#: 150288
1998 Impreza Sedan
Dark Green
anyone have any input at all? Am i totally mistaken here? Is there something maybe im over looking?
Old 10-05-2010, 11:22 AM   #7
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
are you talking EJ22t SOHC or DOHC heads? The SOHC heads are crap with very small valves....a NA SOHC head has better valves
http://forums.nasioc.com/forums/show...light=crap+box
dangerousatom is online now   Reply With Quote
Old 10-05-2010, 11:40 AM   #8
renob123
Member#: 41986
'06 STI/'85 Brat
I hear NABISCO's heaviest activity is during the day. You may not get a lot of responses at night. It doesn't mean that nobody will ever respond
As to your questions, it looks like in one post you want to use 22T heads on a 2.5 block. In another post, it's 2.5 heads on a 22T block. Either that, or you totally misunderstood the Frankenstein thread, and you should go back an reread all of it.
Jacob
Old 10-05-2010, 04:11 PM   #9
subarumafia700
Member#: 150288
1998 Impreza Sedan
Dark Green
I will reread it, but to clear what i had said before
I have read a thread both here and on bbslegacy.com that you can make a very nice hybrid low compression engine using a smaller block and bigger heads.
So i would like to do the opposite and use the bigger block and smaller heads to get high compression without having to get pistons.
I know of an impreza in VT that has (if i remember correctly) a 2.2l block with 1.8l heads and a 2.5l intake manifold and they are getting close to 13:1CR.
So, i am planning to do the same only with a 2.5l block and 2.2 heads.
Hope this makes sense.
Old 10-05-2010, 04:25 PM   #10
renob123
Member#: 41986
'06 STI/'85 Brat
Ok, as long as you promise to read all of the pages of that thread...Yes, you can put 2.2 heads on a 2.5 block to get more displacement and a higher compression ratio. The Frankenstein thread is filled with people who have done that same thing, including me. The Delta cams I threw in at the time helped make that motor pretty impressive, considering how little work/money goes into it.
My setup (phase I block, phase I heads) yields 10.8:1 compression, from what I understand. I do not know of a way to get the compression ratio you mentioned without custom pistons, but then, I'm not sure why you would want it that high anyway.
People will probably caution you against using the EJ22T heads because they don't flow very well. Also, the Frankenstein motor make sense pretty much only for someone who has a 1.8 or 2.2 motor in the car already. My 2.2 blew a ring or something, so I put in a 2.5 block and reaped the benefits.
Jacob
Old 10-05-2010, 04:36 PM   #11
dangerousatom
Member#: 70710
Old 10-06-2010, 01:25 AM   #12
grafton
Member#: 187936
97 Legacy w/12:1CR
07 WRB STi
the na ej22 heads have bigger valves, add a set of delta cams in there and they should flow ok, still nowhere near the sohc heads but much better than what the ej22t heads should flow
Old 10-06-2010, 06:11 PM   #13
subarumafia700
Member#: 150288
1998 Impreza Sedan
Dark Green
cool thanks for the help
Old 10-07-2010, 05:57 PM   #14
SequentialTT
Member#: 254651
good info
SequentialTT is offline   Reply With Quote
Old 10-17-2010, 06:56 PM   #15
mihsub
Member#: 261181
Lightbulb ej22 singel port on ej25 block
so im not trying to take over this post but wanted to know if i can put ej22 single exhaust heads on an ej25 block and with block would work the best
mihsub is offline   Reply With Quote
Old 10-17-2010, 11:17 PM   #16
dangerousatom
Member#: 70710
Yes ...but why?
Depending on the year and motor the ej25 SOHC heads are almost always better than the ej22.
If this is a matter of keeping the stock header for the single port heads then your better off getting a new header to go with the better ej25 heads.
Old 10-04-2011, 08:22 PM   #17
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
Sorry to bump this old thread, but I have a question about EJ255 SB + EJ22 SOHC heads.
What are you guys running for EM? How do you tune these engines?
Thanks!
Ferraz is offline   Reply With Quote
Old 10-04-2011, 11:57 PM   #18
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
No tune needed if you use this in an EJ22 car, direct bolt in affair. Of course if you could tune it you could gain more.
~Josh~
Old 10-06-2011, 04:02 PM   #19
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Old 10-07-2011, 11:15 PM   #20
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
~Josh~
Thanks for the info, Josh.
Assembly: 2.0L Heads on 2.5L block Kingpin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 110 09-26-2014 07:58 AM
STi Cams in 2.0L heads on 2.0L motor. OUScooby Newbies & FAQs 6 08-18-2010 01:09 AM
STI cams in 2.0 heads on 2.0 block? OUScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-06-2010 11:05 PM
2.5RS Heads on a EJ20 block? jayfressh Subaru Conversions 8 07-10-2005 11:29 AM
('93-'01) 2.5 heads on 2.2 block? Murray Impreza Forum 4 06-22-2002 03:13 PM
