Old 10-04-2010, 01:43 PM   #1
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
Default Throttle Body Orientation
Is there any reason (wire lengths and bolt holes aside) that I couldn't rotate the throttle throttle body on my RS say 45 degrees. I can't think of any problems it would cause but I wanted to get some feedback.
Its for a supercharger setup FYI.
Y_I_K_E_S is offline   Reply With Quote
Old 10-04-2010, 01:46 PM   #2
RaineMan
Member#: 256727
2007 2.5I Wagon
Why not just use a coupler or tube with a 45-degree bend before the TB? Would be a lot simpler than custom fabbing a spacer.
RaineMan is offline   Reply With Quote
Old 10-04-2010, 02:20 PM   #3
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
Whoops... I guess I should have specified 45 degrees on axis. I'm setting it up to pull through the TB rather than blow through so I have to fab up a manifold between the SC inlet and the TB. Things might fit a little easier is I rotate it somewhat.
Old 10-04-2010, 03:16 PM   #4
RaineMan
Member#: 256727
2007 2.5I Wagon
Okay... now you are confusing me.
What kind of blower are you using? Centrifugal, roots, etc? That will help me to better picture what you are talking about.
Old 10-04-2010, 03:42 PM   #5
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
It is a roots blower. But that aside, here is a drawing of what I'm asking TB-wise.
What I'm after should be clear now. If not, I'm working on an interpretative dance to try next
Old 10-04-2010, 03:44 PM   #6
Skidd
Member#: 1853
GC6 Supercharged
STM
Given that I've completely relocated my TB all together, the answer to your question is no, there is no reason why should not be able to rotate your TB. In fact, my relocated TB is literally upside down from oem. It's rotated 180 degrees.
Skidd is offline   Reply With Quote
Old 10-04-2010, 03:45 PM   #7
RaineMan
Member#: 256727
2007 2.5I Wagon
Ah... I see.
No, rotating the TB like that won't make a bit of difference.
What blower are you using? M62?
Old 10-04-2010, 03:49 PM   #8
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
Cool. Thanks.
I guess I'll save the dance for some other occasion then...
Old 10-04-2010, 03:53 PM   #9
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
Yep. M62. It's going to be sort of a cross between Skidd's and reddevil's builds. I'm using a lot of the lessons they have learned and been gracious enough to post in detail to keep the headaches to a minimum. Now I just have to stay at home long enough to do more than one weld/braze/oil change/etc. at a time.
Old 10-04-2010, 03:57 PM   #10
RaineMan
Member#: 256727
2007 2.5I Wagon
Nice... the M62 is a nice unit but watch out, they throw a lot of heat at higher boost levels.
I do have a tiny bit of experience with them....
Have fun!
USDM Throttle Body, JDM Throttle Body, USDM IACV scooterforever Engine/Power/Exhaust 0 08-19-2006 05:38 PM
2.0 Twin turbo throttle body versus 2.2 NA throttle body reddevil Pre-2002 Factory Turbo Powertrain 3 06-23-2006 01:06 PM
IACV sensor, Throttle body sensor, or entire used throttle body! annointed Private 'Wanted' Classifieds 1 05-15-2006 06:11 PM
Sticky Throttle/Throttle Body Cleaning - Warrenty? 85258 Normally Aspirated Powertrain 7 10-17-2003 08:45 AM
Remove Throttle Shaft from Throttle Body WRX03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-16-2003 05:14 PM
