Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > 1993 - 2001 Impreza Specific Parts
Old 10-04-2010, 03:38 PM   #1
mtcs
Member Sales Rating: (29)
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Default Vishnu Rotated Turbo Downpipe/Up-pipe + Tial 38mm External wastegate
Well, it's time to do some upgrading. I have had this setup for the last few years and it has always worked great for me.
I am upgrading to a bigger turbo and have come to the conclusion that a 44mm wastegate is a better fit for me at this point. I was having surge issues at about 40psi on my old turbo. Turned the boost down and it was fine. I have just reached the limitations of a 38mm. I am currently in the process of building a tubular exhaust manifold and full V-band Dp/Up pipe, so I don't need this setup anymore. Open Dump FTW.
Thing is though, I could use this setup on my new build, but it was custom made by Vishnu Performance for their Stage 3 kit and instead of hacking it up to get a 44mm wastegate to fit, I rather it go to a fellow turbo 2.5rser.
Few specs:
- Complete rotated setup
- I had two turbos on this DP/UP/wastegate. A GT30R and PTE6262. Both of them fit perfectly
- It is a T3 4 Bolt
- Fits a .63ar or .82ar turbo exhaust housing
- 2.5" SS Up-pipe
- 3" SS downpipe w/v-band clamp connection
- Everything covered with DEI exhaust wrap and spray
- Tial 38mm Wastegate w/fresh rebuild. Dump tube merges back into exhaust. Sorry, no Open dump here.
- Fits the stock 2.5rs crossmember. No need to go out and buy a turbo crossmember.
- Three threaded spots on the DP to hook up your wideband or O2 sensors.
- Direct bolt-on except for the other end of the DP. It uses a 3" V-band connection to attach to the rest of the exhaust system.
- Uses the oem exhaust manifold. I used the oem manifold for a while until I moved to a Borla header. But any 2.5rs manifold will work. (see pics)
You get:
- Vishnu 3" rotated downpipe
- Vishnu ss 2.5" up-pipe
- Tial 38mm wastegate
Also available:
- 3" vband testpipe
- high flow cat vband
- 3" axle back vband
- magnaflow muffler with vband connections
Trying to sell everything as a packaged deal.
sold!!!
Got questions? PM me or AIM: Benjamindmarcus
Few new pictures:
OLD PICTURES:
mtcs is offline   Reply With Quote
Old 10-04-2010, 03:42 PM   #2
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Btw...
I am willing to include the rest of the exhaust if the price is right...
After the DP, I have a full 3" to the testpipe to magnaflow mufler with all V-band clamps. Test pipe is held in place with V-band connections and the aftermarket cat+O2 sensor can be swapped in in less than 2 minutes.
Old 10-05-2010, 03:48 PM   #3
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
PMs replied
Old 10-08-2010, 01:49 AM   #4
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Sold!!!
FS: Tial 38mm external wastegate... 06_Silver_LGT Engine/Power/Exhaust 8 11-30-2007 03:50 AM
TiAL 38mm External Wastegate (NEW) inphinity1 Engine/Power/Exhaust 2 11-25-2007 12:43 PM
Garrett T3/T04E, TiAL 38mm External Wastegate, UR 3" Downpipe & More. inphinity1 Engine/Power/Exhaust 67 09-13-2007 04:28 PM
TurboXS downpipe + UR up-pipe/Tial 38mm EWG (will it fit) StiPete Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 05-22-2006 05:29 PM
FS: NY Tial 38MM External Wastegate 9vapors Tri-State Area Private Classifieds 2 05-19-2006 08:46 AM
