Old 06-26-2002, 02:58 PM   #1
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Default How to set up Timing Curve?
What do most people use for their timing curve. The first map I made I had the timing go up from 1000rpm - 4500rpm then down to redline. It worked good and didnt knock. Then I redid the map and tried to stay close to the original map that came with the link. It increases the timing from 1000rpm - redline. I dont have knock with this map either, but with both maps my max timing is around 30 degrees BTDC. At WOT the first map would drop off to 26 degrees BTDC, and my second map stays at 28 degrees BTDC from 4000rpms up. All timing numbers are 10 static degrees plus map values ie 10 + 16 = 26. How do you guys do it?
-Chav
Chav is offline   Reply With Quote
Old 06-26-2002, 03:36 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i wrote a timing map for another car...@ WOT you could advance up to about 26-28 degrees till redline...however i'd start pullin ga degree or 2 near redline to keep it from wanting to just bounce the limiter. you should have about 12 degrees-14 degrees @ idle and about 40 @ cruising speed.
jeremy
Old 06-26-2002, 04:06 PM   #3
Chav
Member#: 3269
RSTi
Ok, Thank you Jeremy.
-Chav
Old 06-26-2002, 04:42 PM   #4
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
If you send me your email, I'll send you a copy of the map that I have been using in my car...
Basiclly, my timiing goes:
Row 1: up to 25 at 2500rpm all the way across
Row 2: up to 23 at 2500rpm all the way across
Row 3: up to 21 at 3000rpm all the way across
Row 4: up to 13 at 3000rpm all the way across
Row 5: up to 10 at 3500rpm all the way across
Then it drops on degree per row after that.
Just for the record, I'm running 8.5 pounds from a Legacy turbo, with stock injectors and internals. If I increase the timing more, it will just knock, and even with more fuel, it still knocks.
Let me know if you want to check it out
Impreza Rider is offline   Reply With Quote
Old 06-26-2002, 07:57 PM   #5
Delicious Tuning
Member#: 1990
Impreza Rider,
I think you might want to try this.
At higher RPM's and higher MAP readings you will actually want to advance your timing a little. The reason for this is because as the RPM's rise the spark will start to fire later and later because the engine is running much faster. So to get optimal performance, you will want to advance your timing to as RPM's rise under WOT. I would say by the time you are at 6000 RPM's you will want to be at about 18 advanced, maybe more or less depending on your setup.
Of course try this slowly, but I bet you will notice a difference in your top end.
Hope that helps.
~Bill
Delicious Tuning is offline   Reply With Quote
Old 06-26-2002, 10:36 PM   #6
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
I'll give that a try. I've been hesitant to do much tuning the last week or so, because it's been about 95 degrees here, with like 70-80% humidity.
Old 06-27-2002, 02:39 AM   #7
Chav
Member#: 3269
RSTi
Thanx Impreza Rider. I'm not boosting yet so your map wont work for me. Jeremy was your map set up for 87 octane? If it was how much more timing can I run with 93?
-Chav
How to set up my sign? The_Prodigy Newbies & FAQs 5 08-03-2006 12:16 PM
How to set up a Spec Miata or Spec Focus in GT4?? Davenow Motorsports 2 04-19-2006 02:27 PM
do you know how to set up and work postfix/sasl?? Sephro Off-Topic 4 05-06-2005 09:31 AM
How to set up a proxy TheRex Off-Topic 10 12-08-2003 07:59 PM
know how to set up a web server? Like beer? Davenow New England Impreza Club Forum -- NESIC 12 07-15-2003 05:10 AM
