Old 10-04-2010, 05:32 PM   #1
cvalianos02
Member#: 253766
2002 wrx
black
Default Grinding noise when shifting into 4th gear? Help
I have an 02 wrx and when im shifting into 4th gear it grinds or clicks and it only does that when i shift into that gear no other gear does that...any thoughts of what that could be?
cvalianos02 is offline   Reply With Quote
Old 10-04-2010, 05:35 PM   #2
SubaruWrxNewb
Member#: 236017
Years of use. Maybe a bad synchro?
SubaruWrxNewb is offline   Reply With Quote
Old 10-04-2010, 05:39 PM   #3
f1speeder
Member#: 138854
2011 WRX
That's what it is. That means if you have it open change 3 and 5 as well, or look for a good used trans.
f1speeder is online now   Reply With Quote
Old 10-04-2010, 05:41 PM   #4
cvalianos02
Member#: 253766
2002 wrx
black
How much do you think this will cost me to change that in those gears?
Old 10-04-2010, 05:41 PM   #5
3rdsubaru
Member#: 242862
2011 STi Sedan w/nav
Satin White Pearl
bad syncros bro.
3rdsubaru is offline   Reply With Quote
Old 10-04-2010, 05:45 PM   #6
Ghost650
Member#: 233668
2005 Impreza WRX
Probably the synchronizer on that gear is dead if thats the only gear doing it. That would be a transmission rebuild if that is the problem. I had a car with a 6 speed that would only grind into 3 and 4, other gears were fine. That problem was the synchros on 3 and 4 were dead. I think it was $800 to replace those two synchros on that car, most of that is labor. Transmission rebuilds are not to be tackled by the faint of heart.
Ghost650 is offline   Reply With Quote
Old 10-04-2010, 05:53 PM   #7
Badler
Member#: 133597
Try a quality lube for starters. Search around here. Plenty of guys band-aid it for awhile with new fluids.
Badler is offline   Reply With Quote
Old 10-04-2010, 06:00 PM   #8
parabellum9x19
Member#: 255720
2008 Impreza WRX
Absolutely have the trans fluid swapped out, use the OEM Subaru Extra-S.
That stuff is hard to find, so take it (I rarely recommend this) to your local dealer and have them swap out the fluid.
The 5MT trans is a bit touchy in these cars, my 5th gear will sometimes feel slightly crunchy in hot weather when the trans fluid gets really warm....cooler weather and its like velvet.
Swap out the fluid, if that doesn't do it...get ready for a trans rebuild.
parabellum9x19 is offline   Reply With Quote
Old 10-04-2010, 06:06 PM   #9
cvalianos02
Member#: 253766
2002 wrx
black
All right ill swap out the fluid and if that doesnt work i guess I better start working a lot to get it rebuilt
Old 10-04-2010, 06:08 PM   #10
Badler
Member#: 133597
I bet the fluid will do the trick for awhile.
Old 10-04-2010, 06:18 PM   #11
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
My 4th gear syncro was replaced under warranty in my '02.
When going from 3rd to 4th try this: clutch in, move gear selector from 3rd to neutral, release clutch, push clutch back in and move gear selector to 4th. With a little practice you will be able to do the gear change without a crunch. Same thing when going from 5th to 4th, except you will need to blip the gas while the clutch is out and shifter is in neutral. For the downshifts, I'd just go straight to 3rd, though.
Stanley is offline   Reply With Quote
Old 10-04-2010, 06:47 PM   #12
parabellum9x19
Member#: 255720
2008 Impreza WRX
Oh the old doubleclutch...its been a LONG time since I drove anything without synchros in it...
Old 10-04-2010, 06:55 PM   #13
toph
Member#: 78640
14 KTM SuperDuke
15 STi CWP | 02 STi Wagon
I had the same issue. Changed to Redline Lightweight Shockproof and Motul300 per Andrewtech's recommendation. Car shifts mint now, no problems whatsoever.
toph is offline   Reply With Quote
Old 10-04-2010, 07:37 PM   #14
Cletus989
Member#: 244158
2004 wrx
wrb
+1
This is what i did too
Cletus989 is offline   Reply With Quote
Old 10-04-2010, 07:42 PM   #15
cvalianos02
Member#: 253766
2002 wrx
black
Do they have this Redline Lightweight Shockproof and Motul300 per Andrewtech's at the dealership to change it?
Old 10-04-2010, 07:43 PM   #16
tmeultraman
Member#: 49610
why scare the guy. he doesnt need a expensive rebuild unless the sound bothers him. ive had a 4th gear grind for 80000 miles and still no issues. im also on stock clutch at 115000 miles. like others have said, change your fluids religiously and or double clutch going into the gear and you will be fine.
tmeultraman is offline   Reply With Quote
Old 10-04-2010, 07:59 PM   #17
Cletus989
Member#: 244158
2004 wrx
wrb
I don't know I bought mine online and changed it my self. Mine would grind at higher rpms going into 4th and once in awhile going into 1st when not at a dead stop. Both went away after new fluid
here's a good how to if you want to do it yourself
http://www.clubwrx.net/forums/powert...id-change.html
Old 10-04-2010, 08:41 PM   #18
bluesmobile440
Member#: 247485
2006 WRX TR
I run the OEM Extra S. I've noticed that the 3rd and 4th gear grind is very temperature dependent. Some days it's like buttah, other days not so much. Btw, check grimmspeed or fred bean's parts for gear oils. They usually have great selections and prices.
bluesmobile440 is offline   Reply With Quote
Old 10-05-2010, 11:42 AM   #19
parabellum9x19
Member#: 255720
2008 Impreza WRX
What was the mix/ratio for those again?
I may try that cocktail if I swap my fluid out for new OEM fliud and my 5th gear grind in hot weather persists.
Stuff like that annoys the bejeezus out of me.
Old 10-05-2010, 01:14 PM   #20
toph
Member#: 78640
14 KTM SuperDuke
Buy 3QT of Redline and 1QT of Motul, (4QT of Redline if you're going to change the rear end). Put in almost 3 full quarts of Redline, saving just about an inch or less of the last quart. Dump in the full quart of Motul. Make sure you clean off all the crap on the drain plug, no gaskets or anything on this one like on the engine drain plug. I believe the tranny takes 3.8QT's or right around there. Best way to get it in there is to buy a funnel that can screw on to the top of the bottle. They had one at Advanced Auto and I think I paid like 6 or 7 bucks.
I bought my mix from AndrewTech the first time but it was pricey ($88 bucks shipped). This time I ordered the same thing off of Amazon and it was like $83 shipped, but I got an extra quart of Redline.
Good luck, if you have any more questions shoot me a PM.
Old 10-05-2010, 03:07 PM   #21
parabellum9x19
Member#: 255720
2008 Impreza WRX
And how did you like the results?
I"m torn between trying this easy DIY, and just having the dealer swap in the OEM fluid.
Old 10-05-2010, 03:48 PM   #22
toph
Member#: 78640
14 KTM SuperDuke
The results were great. No more grind (more notchyness than a grind), and could go into 1st at like 10-15mph which I could never do before.
If you're going to swap this fluid in yourself, why would you pay the dealer to swap in OEM fluid? It's the same procedure, without mixing 2 fluids. I believe on your car, if it is an 08, you will have to get a T70 torx bit, they can be had on amazon for like $5.
Old 10-05-2010, 04:00 PM   #23
parabellum9x19
Member#: 255720
2008 Impreza WRX
Well, you sold me, I just ordered 3 quarts of RL light shockproof and one of Motul 300.
And I have a fluid extractor, I can suck all the trans fluid out through the dipstick hole and never have to crawl under the car at all.
OH, and the only reason I was considering letting the dealer do it, was because I can't get the Extra-S fluid ANYWHERE...but ****, they want $200 for the job, so forget that, I'll DIY it.
Old 10-05-2010, 04:16 PM   #24
toph
Member#: 78640
14 KTM SuperDuke
I personally wouldn't ever use a fluid extractor, but that's just me. Just put the car up on ramps, it will probably be quicker.
Old 10-05-2010, 04:20 PM   #25
parabellum9x19
Member#: 255720
2008 Impreza WRX
Mercedes factory techs use them every day, have for 30 years.
I did every single fluid change on my last BMW with an extractor (trans and engine oil), over 80,000 miles and never had a single problem.
The key to making sure an extractor is safe, especially for oil changes is to STILL pull the drain plug after you extract, and see what is left....if its measurable, you should not use the extractor.
But in the case of my BMW, what was left post extraction was less than a table spoon of fluids.
They are pretty safe IF you know how to make sure they work for the specific application.
Grinding when shifting into 2nd gear dapple Transmission (AT/MT) & Driveline 8 08-13-2010 07:05 AM
shifting into 4th gear issues WheelieMonster Transmission (AT/MT) & Driveline 21 08-17-2009 03:52 PM
High Pitch Grinding Sound When Shifting Into 4th Gear mcrawford Newbies & FAQs 3 10-09-2007 01:10 PM
I get an odd grinding noise when throwing into 4th Gear? VIRULENT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 04-25-2007 10:55 AM
Transmission grind when shifting into 4th. ShaneC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-19-2004 01:24 PM
