Old 10-04-2010, 06:54 PM   #1
mazemonster
Member#: 259877
2005 WRX STI
Default STI GT35 motor rebuild question. (AMS KIT and more)
Hello all. After my search for the perfect STI i found my 05 STI. I purchased it with a long list of mods and needed some experienced guidance.
the main mods to worry about are my
Garrett GT35 Turbo, Turbo XS rotated mount kit,
Turbo XS FMIC,
Turbo XS down and mid pipe,
DC sports cat back,
Koyo Radiator,
Zero Sports Thermostat,
TiTek 850 cc injectors,
Walbro fuel pump,
Perrin fuel rails and lines,
Perrin light weight crank shaft pulley,
JDM TGV deletes,
Custom oil cooler, braided lines, sandwich plate,
Cusco catch can,
Sun Auto Hyper voltage system GT & Hyper ground wire kit,
Cusco and Stant coolantcaps,
Whiteline anti-lift kit.
there is more suspension work done but not really relevant.
to the point. i'm looking at rebuilding the bottom end to hold a solid 500 HP.
i found the AMS rebuild kit
AMS EJ25 Advanced Engine Rebuild Kit - Automotosports, Inc.
Includes
JE Pistons + Upgraded JE Wrist Pins
Clevite Main and Rod Bearings
OEM Subaru Engine Gasket Kit
Manley H-Beam Rods
ARP 11mm EJ Head Studs
it states that the kit will support 600WHP
"Developed for power levels from stock to 600whp and a 8500rpm"
(not looking to rev that high)
My question is this.
What do i need to do to the head or other components to support this type of power?(keep in mind i'm looking at making 450-500 whp DD)
and any other mods that are needed for this motor to handle this.
springs, oil/water pump ext.
thanks for your help
even if you can point me to a forum with the info. thank you much
mazemonster is offline   Reply With Quote
Old 10-05-2010, 03:21 PM   #2
zackdick
Member#: 251606
2003 Wrx
Wr blue
Stronger head studs for sure an cams since your build is pretty deep already, I'd go for cosworth 280s. Port an polished heads with titanium valves and springs for sure an retainers, local tuner shop should be able to do it, it'll cost you but with Tht build your gonna need reliable stuff to hold up on power, heads should take Tht over 475 maybe 500 depending on tune and how your timing gets placed
zackdick is offline   Reply With Quote
Old 10-05-2010, 03:43 PM   #3
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Good suggestions, if you are going this deep the heads really should get some treatment. Pnp with cams sounds like a good plan along with all the fixings, and do some ARP studs.
Who are you having tune the car?
Have you looked into smaller supporting mods to fill out your build?? Phenolic spacers, Boost control solenoid/MBC, and does that turbo XS have a header?
Will
GrimmSpeed is offline   Reply With Quote
Old 10-05-2010, 05:27 PM   #4
mazemonster
Member#: 259877
2005 WRX STI
Will
not sure on the control solenoid, but im pretty sure it does not have headers. and im looking into a place called garage tuning to do the work unless some one knows a better place. and im not looking to get in over my head in price. if i can stay at 400 450 and be safe with the bottom end build ill be happy for now.
http://garagetuning.com/inhouse.html
Old 10-05-2010, 06:46 PM   #5
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
have you looked into possible turbo switch i know the GT35 turbos are nice but i have also heard the FP red turbo is like having Chuck Noris kick your car in the backside all the way down the highway
emsbuff124 is offline   Reply With Quote
Old 10-05-2010, 06:48 PM   #6
mazemonster
Member#: 259877
2005 WRX STI
right now im just trying to get every thing bullet proof at 450 HP thats it. im not looking for crazzy numbers
Old 10-05-2010, 07:35 PM   #7
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
understandable but thats why i mentioned the FP red turbo, its a good solid platform with target #s just were you are looking to hit on the dyno
Old 10-06-2010, 05:46 PM   #8
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
The heads do not need to be rebuilt to hold more power, however you will need new stronger valvesprings to rev higher than 7500rpm. I would suggest doing cams at the same time as it won't take much more once it's all disassembled.
If you have any questions please let me know!
-Ty
AMS is offline   Reply With Quote
Old 10-07-2010, 05:20 PM   #9
mazemonster
Member#: 259877
2005 WRX STI
so do you think the GT35 is to big for those numbers?
the GT35 is fairly new and i dont see much reason for doping $1000+ for a new turbo to achieve the same thing.
Old 10-07-2010, 05:21 PM   #10
mazemonster
Member#: 259877
2005 WRX STI
-Ty
im looking at staying a stock rev limit for now. but thank you i will keep that in mind
Old 10-08-2010, 01:53 AM   #11
RexRexRex
Member#: 37389
2003 gt35r wrx
Built not bought
don't get the turbo xs rotated kit! save your money and get the ams or p&l kit
RexRexRex is offline   Reply With Quote
Old 10-08-2010, 11:46 AM   #12
mazemonster
Member#: 259877
2005 WRX STI
read the thread thats all stuff i have
Old 10-08-2010, 02:08 PM   #13
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
GT35 are nice turbos too from what i am heard just never had alot of time with them.
is yours a twin scroll or just a normal one?
Old 10-08-2010, 05:01 PM   #14
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Why?
project_skyline is offline   Reply With Quote
Old 10-08-2010, 05:22 PM   #15
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
Originally Posted by project_skyline View Post
Why?
miss a gear blow the motor the honda boys know that story all to well
Old 10-08-2010, 10:38 PM   #16
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
That has nothing to do with the rev limit. IF you miss a gear the rev limit isn't going to do anything because the gear is physically forcing the motor to rev higher.
You could rev 7500-8000 if your motor is balanced and your valve train can handle it.
Bigger turbo needs more anyway to keep a better power band.
Old 10-08-2010, 10:45 PM   #17
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
I understand were your coming from, I just always been around engine builder that more or less say if you spend your money right and build correct( in there eyes, qouting them) you dont need a crazy reving motor. When you have an 85 hundo or more reving motor alot of things can go wrong fast. I personally myself agree to an extent but it depends on the situation too. granted i grew up around to 67 camaros that never need to rev past 65 hundo to rip the road apart but granted they are a 396 v8 big block and a 350 v8 small block. I have also seen turbos out there that have a quicker spool time for a more mangable power band
Old 10-09-2010, 11:05 PM   #18
mazemonster
Member#: 259877
2005 WRX STI
its normal (non twin scroll)
Old 10-09-2010, 11:11 PM   #19
mazemonster
Member#: 259877
2005 WRX STI
Why?
I'm on a bit of a budget but still want to do it right. so trying to live within my means.
this is what im looking at from garagetuning
http://www.garagetuning.com/inhouse.html
this is installed
2.5 STi engine rebuild
All installation labor included
Oversized Mahle forged pistons
ACL Race Bearings
Subaru 08 STi high flow oil pump
Gates Racing Teflon timing belt
Subaru water pump
Subaru timing belt tensioner
3 angle valve job/head rebuild
NGK iridium spark plugs
fluids
$4500.00
+Forged rods option $400
Old 10-09-2010, 11:22 PM   #20
mazemonster
Member#: 259877
2005 WRX STI
Will
i picked up the car and it does have Borla heders.
I LOVE THE F#$!ING CAR!!!!!
Old 10-10-2010, 12:56 PM   #21
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
ah yeah the twin scrolls are nice but will make you go broke after you have to install the custom set up. Like i said im not familar with your turbo to much but here is a few things to keep in mind
you dont wanna push your turbo to much to reach your #s try to keep it safe and conservitive. sometimes is better to over build and down tune a bit then it is to have an agressive tune.
also to i would work closely with the tuner that is going to be tuning your car they will know alot about there dyno and what you need to do to reach the target numbers you want
Old 10-10-2010, 11:32 PM   #22
mazemonster
Member#: 259877
2005 WRX STI
ya this guy is good and i know the gt35r with these mods have put down a lot more power then the targets im shooting for.
Old 10-12-2010, 02:39 AM   #23
REVNU
Member#: 82147
2005 WRX Sedan
I'd spend your money elsewhere... PM me if you want more details.
REVNU is offline   Reply With Quote
Need Help. 04 STi built motor fueling question Converted STi Built Motor Discussion 10 05-06-2010 12:39 PM
Tons of Motor Parts, Exterior, Clutch Kits, and More. MUST GO AlineDriver SWIC Private Classifieds 0 11-12-2009 07:17 PM
FS - MA - 2005 STi Stock Stuff (Intake, Downpipe, TMIC, VF39 and More) ZOMG.STi NESIC Private Classifieds 79 09-01-2009 06:10 PM
04 STI Cylinderheads with Cams (ALSO- AVCS Gears and More) 02Toyowrx Private 'For Sale' Classifieds 7 07-24-2006 01:28 AM
Motor Rebuild questions E30M3Pilot Normally Aspirated with bolt-on Forced Induction Powertrain 6 11-18-2004 04:52 PM
