Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 10-04-2010, 09:21 PM   #1
iluvdrt
Member#: 46248
82 Brat
Tan
Default Cooling issues (not a HG)
98 LGT wagon 2.5L
At highway speeds it runs about 190-195 which is about 20 warmer then my t-stat is at. When I idle it will over heat and get up to 210-220 in no time. If I rev it up it cools back off for awhile.
Things I have done:
I have replaced the t-stat with a new one, and the fans do work. I powerwashed the front of the radiator to ensure the fins werent dirty. The air flow is good.
Noticables:
not pushing coolant, NO coolant loss. Oil is fine, and hydrocarbon anylysis on the radiator is good. NOT A HG.
Looking at the car, the left side of the radiator is very hot, but the right side is very cold, even after a long drive.
The higher the engine revs the colder it will stay.
fans do work
Pressurizes fine
Educated guess:
I think the radiator has a clog in it. The car has over 212K mi on it and AFAIK it is the original radiator. It doesn't have air in it, and the heater does work. I have driven it about 3000 miles since the new t-stat. On the highway it is a little hotter then I'd like, but at idle it scares me. BTW the ambient outside temp is 54, so it is def not overworking. Any other thoughts? Thanks.
iluvdrt is offline   Reply With Quote
Old 10-05-2010, 01:49 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
When was the water pump replaced? They do wear out eventually.
Barring that, clogged radiator sounds like a thing to try.
Old 10-05-2010, 02:24 AM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
sounds like good advice to me. Not even sure how to test the radiator.
Tim Sanderson is offline   Reply With Quote
Old 10-05-2010, 02:39 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
My first guess would be to remove the radiator and pour water in at the top with a hose and make sure it comes out faster than you can put it in. Other than that, get a known-good one I guess.
Old 10-05-2010, 03:49 PM   #5
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
Yeah, it definately sounds like your radiator is clogged. I'd pop it off and have it back flushed and see what comes out.
Y_I_K_E_S is offline   Reply With Quote
Old 10-06-2010, 12:16 PM   #6
iluvdrt
Member#: 46248
82 Brat
Tan
Water pump was done about 55K ago with the t-belt.
I am going to remove the rad today, and fill it up with a strong degreaser then let it set for awhile. I'll then back flush it with hot water. Maybe something will come out.
If not maybe its the water pump.
Old 10-06-2010, 01:10 PM   #7
GrundleJuice
Member#: 165749
Get ready for a rancid smelling slap in the face.
Old 10-06-2010, 02:15 PM   #8
RaineMan
Member#: 256727
2007 2.5I Wagon
Why not just replace the radiator? They're not that expensive. Might as well replace the hoses while you are at it.
RaineMan is offline   Reply With Quote
Old 10-06-2010, 02:28 PM   #9
iluvdrt
Member#: 46248
82 Brat
Tan
LOL, I know. It is def clogged. it took 5 min just to fill it up with degreaser LOL.
Thats what I'll have to do I guess. Thought I would try to save a buck, but that isn't going to happen. Time to call Koyo and get a nice aluminum one, might as well get a cool safe t-stat too.
Onto bigger news though, since I had the rad out I decided to check my t-belt. One of the idlers is about to grenade. There is metal dust everywhere and the seal on the bearing fell off. This sucks because I just did all this about 3 years ago.
Oh well, you play/you pay I guess. Might as well put in a new water pump as well.
Thanks for the reply's guys!!
Old 10-06-2010, 03:46 PM   #10
RaineMan
Member#: 256727
2007 2.5I Wagon
Isn't rebuilding fun? I did new radiator, thermostat, water pump and timing set on my fiancee's truck back in January... then we sold it in March. What a waste.
Old 10-06-2010, 04:58 PM   #11
iluvdrt
Member#: 46248
82 Brat
Tan
Well I don't mind doing it, it just happens at the most inconvienant time...like when I am broke or we have to spend money on a big bill or something.
Old 10-07-2010, 11:35 AM   #12
RaineMan
Member#: 256727
2007 2.5I Wagon
Oh **** only breaks when you can least afford it... seems to be Murphy's Law at work.
Old 10-07-2010, 12:30 PM   #13
VIsubi
Member#: 187834
06 2.5i impreza
Red
210-220 isn't over heating and your fan should come on by then. I usually run between 190-195 all the time. Sure it might be your water pump but did you do the radiator for bubbles test yet...kinda hard though cause coolant trys to push its way out of the radiator cap trying to overflow to the coolant catach can..but as long as theres no bubbles its not your HG
VIsubi is offline   Reply With Quote
HELP! Cooling issues, not sure what it could be silentt Normally Aspirated Powertrain 11 10-24-2006 12:31 AM
cool or not cool 949 Southern California Impreza Club Forum -- SCIC 34 12-03-2004 12:15 AM
cool idea...not cool to land on someones patio twinbrd Off-Topic 30 03-31-2004 12:46 AM
Cool or not cool? - Clothes DLC228 Off-Topic 19 04-18-2003 09:42 PM
