Old 10-05-2010, 03:52 PM   #1
ThaPuertoRican15
Member#: 245018
06 Forester
SGM
Default aftermarket cams
does anyone know where i can get some good yet cheap cams?
i want to make more power in my 96L-02TS swapped car. i need SOHC cams for the 02TS. i want a bigger rise and longer duration.
anyone have any info on some good stuff?
ThaPuertoRican15 is offline   Reply With Quote
Old 10-05-2010, 03:55 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Search.
Delta Cams has been mentioned eleventybillion times over the years.......
Old 10-05-2010, 04:07 PM   #3
t3rror
Member#: 133249
2006 Forester XT
SGM
rs25.com usually has some used ones for a really good price. I picked up some Delta 2000 cams for 165 shipped.
But you can contact Delta and they have a few regrinds available.
t3rror is offline   Reply With Quote
Old 10-05-2010, 04:59 PM   #4
watchdoc
Member#: 104821
2015 Outback LTD
Delta is running an October sale. Check the vendor section for camtoberfest. $160 shipped + cores. Pretty smokin deal.
watchdoc is offline   Reply With Quote
Old 10-05-2010, 07:24 PM   #5
ThaPuertoRican15
Member#: 245018
06 Forester
SGM
i cant seem to find this...lol.
im .
Old 10-05-2010, 08:36 PM   #6
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
I hear everyone talking about delta cams. How are they in comparison to the cams from rallitek? Because I was going to go with them but I really never hear much about the rallitek ones.
07ImprezaMB is offline   Reply With Quote
Old 10-05-2010, 08:39 PM   #7
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I believe the Deltas are cheaper. I know with Delta, they send you a camshaft that has been "reground," as in someone sent them a camshaft and they changed it's profile. I don't know if this is how rallitek does it too.
chazly413 is offline   Reply With Quote
Old 10-05-2010, 08:43 PM   #8
ThaPuertoRican15
Member#: 245018
06 Forester
SGM
i honestly have no idea...
im starting to do some extensive research...
im losing my license thursday. so since my car is going to see about 11 months of down time i figure it would be a great time to build my 25TSL.N/A to a 2.5TSL.Turbo.
any info from anyone else would be great!
Old 10-05-2010, 08:45 PM   #9
ThaPuertoRican15
Member#: 245018
06 Forester
SGM
how do you "regrind" something to give it as bigger rise or duration? it would only make it smaller...im confused and in the dark
someone show me the light! lol
Old 10-05-2010, 09:07 PM   #10
bhilly82
Member#: 254417
09 Impreza
Peperika
the weld to the lobes and regrind an new profile to it.
bhilly82 is offline   Reply With Quote
Old 10-05-2010, 09:23 PM   #11
ThaPuertoRican15
Member#: 245018
06 Forester
SGM
oh ok, i see.
so do you give them the specs of the rise and duration and they do it that way or do they have set specs and sell them that way only?
Old 10-05-2010, 10:01 PM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
....and then there was light......
http://deltacam.com/
When regrinding Subaru cams, they typically take material off the BASE CIRCLE, which effectively increases the lift, but requires the valve clearances to be readjusted. The duration can be manipulated as well by altering the profile.
Some cams (EJ25D for instance) need to have the base circle left alone to keep from having to replace the shims for correct valve clearance. On these, they weld material onto the existing lobes and grind them back down to the correct profile.
Delta has a youtube channel illustrating the process quite clearly.
Jay
Old 10-06-2010, 01:02 AM   #13
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You want the 1000 Grind, not the 2000 Grind.
Is $160 a good deal now? I think I paid about that when I had my 1000s made and that was full price.
Old 10-06-2010, 07:54 AM   #14
ThaPuertoRican15
Member#: 245018
06 Forester
SGM
Originally Posted by williaty View Post
You want the 1000 Grind, not the 2000 Grind,
ok, so whats the major differences between the 1k grind and the 2k grinds?
Old 10-06-2010, 10:45 AM   #15
t3rror
Member#: 133249
2006 Forester XT
SGM
You said you were going the turbo route? Maybe you should ask for a forced induction type cam. I believe the profiles are a little different from N/A to F/I.
The 2K grind is a little more aggressive.
Old 10-06-2010, 11:46 AM   #16
renob123
Member#: 41986
'06 STI/'85 Brat
From what I understand:
-The Rallitek cams are very very similar in every aspect (including method of manufacture). The difference is the price. Don't quote me, because I've never seen both at the same time, but that's my understanding from my research.
-For my EJ22, Delta (at the time) had 2 grinds. I went for the one that moves the power to the lower RPMs. It's pretty nuts to get power at 1200RPM. If you search, some pretty widely respected NA gurus will recommend that grind for 95% of the people on this site for a variety of reasons. Heck, maybe even 99% of the people on this site.
Jacob
renob123 is offline   Reply With Quote
Old 10-06-2010, 12:56 PM   #17
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Where the power band is. The 1000's produce a fun powerband within the stock rev limit that works for everyday driving and for giving it hell on the weekends. The 2000's produce a powerband that necessitates raising the rev limit to get much of anything out of the cams and is too high for street use.
Old 10-06-2010, 01:08 PM   #18
renob123
Member#: 41986
'06 STI/'85 Brat
Would you say that people with decent headwork could get some gains out of the 2000s, but everyone else should probably stick with the 1000s?
Jacob
Old 10-06-2010, 01:08 PM   #19
Bio248
Member#: 223032
2006 Impreza 2.5i
CGM
what is 'too high' for street use? the stock cams dont make any power past 4k and it sucks. i drive my car hard and would rather make more power up top than down low.
Bio248 is offline   Reply With Quote
Old 10-06-2010, 01:16 PM   #20
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Jacob
Good headwork would help either cam. The real issue is how fast do you want to spin your engine before it makes power. If you want to stick with the stock valvesprings and the stock redline, you need to use the 1000s. If you're willing up upgrade to the Supertech valvesprings and retainers (probably $700+ retail, plus install) and raise the rev limit 1000RPM+ over stock and have to spin it that high to get it to do anything, then you run the 2000s.
When I had the 2000s in, I made nothing (as in less than stock) until almost 5000RPM and had to spin the car to 7000RPM every day to get it to go anywhere. With the 1000s in, I make stock below 4000RPM and significantly above stock from 4000RPM to 7000RPM.
Old 10-06-2010, 01:44 PM   #21
renob123
Member#: 41986
'06 STI/'85 Brat
Thanks. Don't get me wrong. I'm sticking with the 1000s I have. I'm very happy with them since I don't feel any need to win some horsepower/dyno battle at 7,000RPM. Jerking my head back at 1,500RPM from all the torque is more my style
Jacob
Old 10-09-2010, 03:36 PM   #22
subi400
Member#: 216984
1996 Impreza outback
Green
Hi everyone,
I have a 96 impreza 2.2 and have been thinking of doing 11:1 pistons over the stock 9:1 along with some possible light weight rods just for kicks. Then doing some port and polish in the heads and intake with some delta 1000 grind cams. Then getting a better intake along with a good header and a high flow cat as I still want to be legal
Now my problem is trying to figure out how to tune my car since it is a 2nd generation car with a maf based system
subi400 is offline   Reply With Quote
Old 10-09-2010, 10:28 PM   #23
iluvdrt
Member#: 46248
82 Brat
Tan
Originally Posted by subi400 View Post
Hi everyone,
You can get an apexi AFC controller. That will help with fuel and air. In order to do timing you would need something with more features like a Ralitek P6 or an Emanage.
iluvdrt is offline   Reply With Quote
Old 10-10-2010, 02:40 AM   #24
subi400
Member#: 216984
Green
^^ Thanks for the info I am going to be checking more about this stuff in the near future.
Old 10-13-2010, 04:09 PM   #25
watchdoc
Member#: 104821
2015 Outback LTD
CAMTOBERFEST
http://www.rs25.com/forums/f168/t143...toberfest.html
I ordered the 1500 grinds myself which seem to be their current hot seller.
Keep the stock WRX cams or go with aftermarket cams? triguy Built Motor Discussion 11 09-21-2006 05:41 AM
gas mileage with aftermarket cams ClimbinNBouldern Normally Aspirated Powertrain 11 06-05-2004 10:18 AM
ProTorque Torque Converter and Aftermarket Cams Kevin Thomas Transmission (AT/MT) & Driveline 0 05-10-2004 07:02 PM
aftermarket cams ? rabbitnutz Normally Aspirated Powertrain 5 04-06-2004 10:43 PM
JDM Head Valvetrian and aftermarket cam question roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-10-2004 04:40 PM
