Old 10-05-2010, 05:39 PM   #1
gleesamo
Member#: 143346
03 wrx 285 whp
white
Default injector issues
Alright guys, help me out. I am having a problem and needs help. My car has been running like crap for a while now and found out cyl # 3 is at 75lbs so replacing the shortblock.
My issue now is the injector on cyl 1. Cyl 1 is running WAY lean, when I pulled the spark plug it was white white. So figured faulty injector. My buddy came over from seattle to help me trouble shoot noticed my injector on 1 was making a loud ticking noise, louder then normal. Sooooo, I bought some pinks from fellow nasioc member and still have the same loud ticking noise from injector on cyl 1!?!?!
Where do I go from here? Should I pull off my intake and make sure the fuel lines are clean? Do injectors make a louder ticking noise if they are dry firing? Any info is appriciated!
mods:16g turbo, pinks, full exhaust, front mount, utec, up/down pipe.
gleesamo is offline   Reply With Quote
Old 10-05-2010, 07:25 PM   #2
gleesamo
Member#: 143346
03 wrx 285 whp
white
b u m p
Old 10-05-2010, 10:35 PM   #3
gleesamo
Member#: 143346
03 wrx 285 whp
white
bee you em pee
Old 10-06-2010, 10:35 AM   #4
gleesamo
Member#: 143346
03 wrx 285 whp
white
anybody?
Old 10-20-2010, 12:19 PM   #5
DeatschWerks
NASIOC Manufacturer
Member#: 87358
Have you tried moving injectors around to see if the problem follows the injector or stays on cylinder 1?
Are you sure you are getting fuel to cylinder 1? Are you getting fuel to cylinder 3?
DeatschWerks is offline   Reply With Quote
Injector issue DreamEvil Engine Management & Tuning 1 01-03-2010 02:59 PM
Modified Blue Injectors - Issue BlackEyeBugEye Open Source Reflashes 17 07-30-2008 10:37 PM
02 wrx hesitation/ poss fueling/injector issue? 95lwrx Factory 2.0L Turbo Powertrain 1 04-19-2008 08:56 PM
Injector issues. Adictwrx Mid Atlantic Impreza Club -- MAIC 4 03-05-2008 08:51 PM
Sti Injector issue please help WRC WRX Factory 2.0L Turbo Powertrain 0 03-01-2003 12:45 PM
Message Board Statistics All times are GMT -4. The time now is 08:21 AM.
