Old 10-05-2010, 06:25 PM   #1
bz7202
Member#: 223761
2002 wrx
Default Hybrid bulid
Currently in the process of building my hybrid motor and want to know if the stock 2.0 tune will work. The car will be my daily driver and i dont want any issues while driving to and form work every day.
Current set up:
-Brand new EJ257
-Stock 2.0 heads (all new parts)
-ARP head studs w/ STI gaskets coated with copper spray
-stock td04 & injectors
-Cold air intake
-Turbo xs BOV
-Aftermarket Catback exhaust (greddy i think)
I will not be running any more boost then factory and will be running pemium fuel.
Any answers or additional ideas will be greatly appricated.
bz7202 is offline   Reply With Quote
Old 10-05-2010, 06:27 PM   #2
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
No...
AWDWRXLOVER is offline   Reply With Quote
Old 10-06-2010, 10:37 AM   #3
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
As above. NO.... You are not taking counter measures against the raised compression. You do not have the heads machined. This would be highly recommended. Perhaps have a look at Equilibrium Tuning's new CNC process for WRX heads. There are also others that do this though.
In a nutshell a 2.5L likes to run richer and more retarded timing than a 2.0L so on both apects it doesn't match with the stock tune you have.
Cheers,
Jasper Kopinga
CS Racing
Taiwan.
jkopinga is offline   Reply With Quote
Old 10-06-2010, 02:32 PM   #4
Ryan314
Member#: 82989
Hybrid EJ257
You will need at least STI 565cc injectors.
Ryan314 is offline   Reply With Quote
Old 10-06-2010, 05:46 PM   #5
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
As long as you stay on the td04 with pump gas you shouldn't need new injectors but you will definitely need a new tune for the 2.5. If you do see your self going to a larger turbo down the line then it might not hurt to do the injectors and a fuel pump now though.
Mike
GrimmSpeed is offline   Reply With Quote
Old 10-06-2010, 05:59 PM   #6
bz7202
Member#: 223761
2002 wrx
will i need to buy a tuner and have someone tune it or will i be able to have a shop tie into my factory ECU and make the nessary tweeks?
Old 10-07-2010, 02:05 AM   #7
CamTunedSti
Member#: 231697
wont he also need side feed injectors since its the 257 block?
CamTunedSti is offline   Reply With Quote
Old 10-07-2010, 03:37 AM   #8
03BugEyeRex1121
Member#: 160763
2003 JDM FAIL WRX
Molested By Drunkmann
No, the injectors he uses are relative to the intake manifold/tgv's he is using. Which is more than likely his stock 2.0l stuff.
03BugEyeRex1121 is offline   Reply With Quote
Old 10-07-2010, 09:20 AM   #9
bugeye_fever
Member#: 232503
2002 WRX Hybrid Swap
WRB JDM fo sho! 6MT DSS'd
Default No boost
I agree with the above posts, you should definetly not push the motor with the 2.0 map. However, I have a similar setup, 'cept forged pistons, and i'm 3 hours away from my tuner. He suggested that for breaking the motor in I would be ok running an ots cobb stage 2 map, but to stay out of boost. Long story short i drove it 1000 miles with that map out of boost to break in the motor. No problems, again I definetly agree with above posters, and I do not believe it is the best route. But with those stipulations it worked fine for me. Worst part was staying off the gas for 1k mi.
Ray
bugeye_fever is offline   Reply With Quote
Old 10-08-2010, 12:02 PM   #10
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
You need to find a tuner that you trust and ask him what he recommends. The tune is the most important decision you will make in this process as it will dictate how long this engine will last. As far as the tune is concerned, don't cut any corners and get it done as soon as possible.
slowmike is offline   Reply With Quote
My Wrx surges back and forth when it bulids boost!!!!!! Help!!!! Drewbaru04 North West Impreza Club Forum -- NWIC 22 12-29-2008 09:58 AM
Hybrid vehicles' overall energy costs exceed those of comparable non-hybrids Mike Wevrick Off-Topic 144 04-04-2008 05:26 PM
RSTi Bulid help wrxej25 Built Motor Discussion 6 09-26-2007 01:08 PM
Honda To Stop Production of Insight Hybrid, Introduce New Hybrid in 2009 NYCshopper Non-Subaru News & Rumors 26 06-16-2006 01:55 PM
Buliding my own turbo kit? ImprezedRS Normally Aspirated with bolt-on Forced Induction Powertrain 13 11-12-2001 02:59 PM
