Old 10-05-2010, 06:54 PM   #1
leg1999
Member#: 201993
99 legacy 30th anv
Low and slow, RIP, 97 LGT
Default P0102 engine code
Apparently my MAf sensor went out. I replaced it with a reman. from shucks because they're so damn expensive! Before fighting with the people at shcucks telling them that the reman. MAf I got is bad, I would like to know if anybody knows what could be causing my problems. The car starts and will idle fine when you give it the gas it will lug for a second and then kick up to power. I have the p0102 check engine light code on which means MAF circuit low input. I've checked the wires, hoses, air leaks and I can't find anything. Anything else I should be checking before I warranty this "new" one?
leg1999 is offline   Reply With Quote
Old 10-06-2010, 11:38 PM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Make sure you do an ECU reset by disconnecting both battery terminals and touching them together for about 10 seconds to clear the system of all charge.
PhilSine is offline   Reply With Quote
Old 10-07-2010, 03:38 PM   #3
leg1999
Member#: 201993
99 legacy 30th anv
ohhh, I didn't take off both battery terminals, I only disconnected one. I'll try that, thanks!
Old 10-07-2010, 04:43 PM   #4
RedMonkey999
Member#: 191476
2002 2.5RS AW
2007 FXT OBP
You can also just take one off and depress the brake pedal for 30 seconds or so (discharges capacitors using the brake light).
RedMonkey999 is offline   Reply With Quote
Old 10-07-2010, 07:55 PM   #5
leg1999
Member#: 201993
99 legacy 30th anv
Well, I pulled off both termianls and she is still running bad. I forgot to mention, the first MAf I got wasn't working right. I picked up another remanned which is working correct and my car still bring up the p0102 code and i've also been recieving misfires on cylinders 1,2 and 3.
Old 10-07-2010, 08:37 PM   #6
leg1999
Member#: 201993
99 legacy 30th anv
I'm thinking the computer is having problems. I've replaced spark plugs, coil pack, MAf sensor, don't see any leaks, any frayed wires. Looks like I need to do a full wrx swap..
Old 10-10-2010, 12:20 AM   #7
leg1999
Member#: 201993
99 legacy 30th anv
Reading a p0103 code now. Very confused.
Old 10-10-2010, 03:15 AM   #8
renyo
Member#: 93577
98 Impreza
When my MAF died it was throwing both a P0102 and a P0103 code at the same time. When I got a new MAF everything worked fine.
renyo is offline   Reply With Quote
Old 10-10-2010, 06:52 PM   #9
leg1999
Member#: 201993
99 legacy 30th anv
Hmm, it seems like my maf has been going "bad". I was running 35% fuel to air before i put the reman. MAF in and my car would barely run. It would jump when giving it the gas and sputter and would die when at idle. Did this happen to you? i've replaced the MAF and have continuing problems, codes and the car is still jumpy and doesn't have full power.
Old 10-10-2010, 11:00 PM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
It's a possibility that your MAF sensor is fine but the wiring is bad. Take a MAF sensor out of a working car and test it in yours. If the problem persists, the wires are the culprit.
Old 10-11-2010, 08:02 AM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Also check the integrity of the tubing before and after the MAF. The '99 MAF is not a robust unit. Little things as an over oiled airfilter have been known to kill them quickly. IIRC, the sensor itself can be bought separately from the housing....for much less than a complete unit.
Jay
Old 10-11-2010, 11:52 AM   #12
leg1999
Member#: 201993
99 legacy 30th anv
My father and I checked the wiring yesterday all the way back to the ECU. I'm stumped, he thinks I need a factory MAF so I believe that's what's going to happen.
Old 06-26-2011, 06:12 PM   #13
08wrx08
Member#: 243481
i have the same problem with my 08 wrx. there is a cut in a wire going to the connector. double check your wires. i did wire testing a couple times and it was reading fine the first time and second time the bad wire was only reading intermittly.
08wrx08 is offline   Reply With Quote
Where is the engine code on the block engine for a wrx or sti? ejcivicdee Newbies & FAQs 3 08-12-2009 08:37 PM
No engine codes, then bam! 4 codes tamadrumr88 Normally Aspirated Powertrain 10 07-22-2009 05:56 PM
Does anyone know the engine code for the WRX? DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-21-2001 10:49 AM
Check engine codes Kruf General Forum Archive 1 12-17-2000 05:46 AM
