Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 10-06-2010, 01:08 PM   #1
KenSekiguchi
Member#: 175331
2002 WRX STi - WRB
JDM V7 EJ207/13' Felt Z85
Exclamation Issue Related to Head Gasket? Take A Look...
So, there's a possibility that I may have to break down and rebuild my V7 EJ207. Here's some history.
Earlier this week on Thursday, I pulled into a gas station after work to check some lottery tickets. When I got out of the car, the temperature gauge was slightly over the half way mark (needle was right below the thermometer icon) where it usually is. I come back out about five minutes later and the temperature gauge was almost at the three quarters mark. So I shut her down and wait a few minutes, open up the radiator cap on the reservoir, and it's almost empty. I fill it up about half way, start her up, squeeze the upper radiator hose while slowly filling the rest of the reservoir. For the remainder of the drive home, the temperature was normal. Over the next two days, I check the reservoir before I leave for work and before I head home, it was about half empty, top it off each time, but the car was not overheating. On Sunday and Monday, everything was normal, coolant level in the reservoir was fine, no fluid missing.
Today I change my oil. Oil looks fine, dark, definitely not "milky". Open up the coolant reservoir while the car is warming up, it's about half empty and the worst part, bubbles . So I do a compression test on the driver's side cylinder bank (#4 and #2) and I get 135-137 on each cylinder . I'll finish the passenger side bank (#1 and #3) tomorrow morning.
Overall, the car runs fine. No loss of power, very smooth through 8K, and a very stable idle. The V7 was bought about two years ago with approximately 5K kilometers on the engine. Since this is my daily driver, I do not beat on it, but once in a while I'll open her up on the highway.
I would like to get some opinions before I pull the engine and get it rebuilt.
Here are all my modifications. Thanks for your time.
V7 EJ207
JDM V7 ECU 10
JDM V8 STI TMIC
Tomei Equal Length Exhaust Manifold (DEI wrapped)
Tomei Up Pipe (DEI wrapped)
Invidia 3" Bellmouth Catless Downpipe (DEI wrapped)
HKS 3" Carbon-Ti Cat-Back Exhaust (DEI wrapped)
VF30
Samco Turbo Inlet
K & N Panel Air Filter
JDM STi 565CC Pink Injectors
Denso 288lph Fuel Pump
Koyo Aluminum Radiator
Samco Radiator Hoses
Samco Ancillary Hoses
Power Enterprises Kevlar Timing Belt
Tomei Timing Belt Guide
Group N Motor Mounts
Group N Transmission Mount
Beatrush Pitch Stop
Cusco Front Shifter Bushing
Kartboy Rear Shifter Bushing
Exedy Light Weight Flywheel
Exedy Stage 1 Clutch
Stainless Steel Braided Clutch Line
Cusco 22mm Adjustable Rear Sway Bar
Cusco 22mm Front Sway Bar
Group N Top Hats
JDM V7 STI Pink Struts
JDM V7 STI Springs
SPT Aluminum Lower Control Arms
Whiteline Sport ALK
Ken Sekiguchi
KenSekiguchi is offline   Reply With Quote
Old 10-06-2010, 01:51 PM   #2
jays05
Member#: 78165
05 STI 35r + e85
Weird, this guy has the same problem: http://forums.nasioc.com/forums/show....php?t=2066700
jays05 is offline   Reply With Quote
Old 10-06-2010, 06:19 PM   #3
Csquared33
Member#: 198053
93 2JZ something
no headstuds? do any 5th gear pulls lately?
Csquared33 is offline   Reply With Quote
Old 10-06-2010, 09:26 PM   #4
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
What r the chances of that ?
sense of nature is offline   Reply With Quote
Old 10-06-2010, 11:16 PM   #5
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
What do you guys recommend to keep the head gasket in place? I mean not blowing head gaskets , ARP studs?
Warranty issues w/ blown head gasket and minor mods? calib17a Southern California Impreza Club Forum -- SCIC 34 07-05-2010 12:01 PM
FS (MD): TGV to head gaskets - Part# 14035AA421 kts262 MAIC Private Classifieds 2 02-27-2009 10:37 AM
Anyone have issues with Cosworth head gaskets? methaddict Built Motor Discussion 6 06-28-2008 03:30 PM
cobb '06 wrx , was there a low-boost issue related to one of the maps? jkoc AccessPort 2 02-17-2006 11:24 PM
warranty issues w/ blown head gasket and minor mods? calib17a Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-22-2004 08:34 PM
